When i use optimus-manager garuda animation broke and boot work on 50/50
Hi. when i do command "optimus-manager --switch nvidia" garuda animation broke. and when i reboot boot work 50/50.
Kernel: 6.4.11-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=52c85688-8cdc-43e4-9fc4-e3b10b1b9ad1 rw rootflags=subvol=@
resume=UUID=d945079a-848b-4d6e-af7e-bc7487d05fe1 loglevel=3 ibt=off
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk0xxx
Mobo: HP model: 85FC v: 42.47 serial: <superuser required> UEFI: Insyde
v: F.63 date: 04/06/2023
ID-1: BAT1 charge: 37.2 Wh (97.9%) condition: 38.0/52.5 Wh (72.3%)
volts: 12.9 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3774 high: 3826 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 3826 2: 3519 3: 3802
4: 3802 5: 3819 6: 3813 7: 3816 8: 3802 bogomips: 38400
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 535.98
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Lite-On HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04ca:707f
Monitor-1: eDP-1 model: LG Display 0x062e built: 2019 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k6.4.11-zen2-1-zen status: kernel-api with: aoss
lanes: 1 port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
chip-ID: 10ec:b822 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 0bda:b00b
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 21.26 GiB (1.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC511 HFM256GDJTNI-82A0A size: 238.47 GiB block-size: physical: 512 B
fw-rev: HPS0 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0E scheme: GPT
ID-1: / raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
used: 20.68 GiB (9.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-4: /var/log raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-5: /var/tmp raw-size: 229.37 GiB size: 229.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.48 GiB used: 2.45 GiB (32.8%)
System Temperatures: cpu: 97.0 C pch: 76.0 C mobo: N/A
Processes: 325 Uptime: 1h 1m wakeups: 33107 Memory: total: 8 GiB note: est.
available: 7.48 GiB used: 5.55 GiB (74.2%) Init: systemd v: 254
pm: pacman pkgs: 1878 libs: 549 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
System install date:     2023-08-22
Last full system update: 2023-08-23
What is “Garuda animation”?
What is “boot work 50/50”?
my laptop will either turn on or it won't turn on.
animation - the animation of the icons is very fast to spin the progress bar, the animation of the movement of the windows is very slow. and more
Afaik we explicitly recommend not using optimus-manager because of frequent issues when using it. For reference:
Quite often, software such as “optimus-manager” or “optimus-switch” is used instead of PRIME. Although they feature “hybrid mode”, they also feature modes that exclusively switch to the dedicated or iGPU. Using these modes is an usually not recommended, because
  1. If your NVIDIA driver ever fails to load, your system will be unable to enter a graphical session
  2. In NVIDIA mode, the dedicated GPU is always used and therefore always turned on even if no software that could properly take advantage of it is running. The iGPU is much better suited for running low power common desktop applications.
  3. Switching modes requires logging out and logging back in or otherwise restarting X11. Meanwhile PRIME can be used without restarting X11.
i need work nvidia always,i have one monitor and laptop. when i used optimus-manager i do "optimus-manager --switch nvidia" and all work. but when i use ur method my monitor doesnt work. i need always active only nvidia
To use Nvidia only you can follow the configuration instructions here:
https://wiki.archlinux.org/title/NVIDIA_Optimus#Use_NVIDIA_graphics_only
Use NVIDIA graphics only
The proprietary NVIDIA driver can be configured to be the primary rendering provider. It also has notable screen-tearing issues unless you enable prime sync by enabling NVIDIA#DRM kernel mode setting, see [1] for further information. It does allow use of the discrete GPU and has (as of January 2017) a marked edge in performance over the nouveau driver.
First, install the NVIDIA driver and xorg-xrandr. Then, configure /etc/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf the options of which will be combined with the package provided /usr/share/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf to provide compatibility with this setup.
Note: On some setups this setup breaks automatic detection of the values of the display by the nvidia driver through the EDID file. As a work-around see #Resolution, screen scan wrong. EDID errors in Xorg.log.
Section "OutputClass"
Identifier "intel"
    MatchDriver "i915"
    Driver "modesetting"
EndSection
Identifier "nvidia"
    MatchDriver "nvidia-drm"
    Driver "nvidia"
    Option "AllowEmptyInitialConfiguration"
    Option "PrimaryGPU" "yes"
    ModulePath "/usr/lib/nvidia/xorg"
    ModulePath "/usr/lib/xorg/modules"
EndSection
Next, add the following two lines to the beginning of your ~/.xinitrc:
~/.xinitrc
xrandr --setprovideroutputsource modesetting NVIDIA-0
xrandr --auto
Now reboot to load the drivers, and X should start.
If your display dpi is not correct add the following line:
xrandr --dpi 96
If you get a black screen when starting X, make sure that there are no ampersands after the two xrandr commands in ~/.xinitrc. If there are ampersands, it seems that the window manager can run before the xrandr commands finish executing, leading to a black screen.
okay. i fix and nvidia always on but animation broke
