When connecting headphones via aux, audio doesn't connect automatically
Hello! As the title says, application’s audio (such as firefox or steam games) won’t work when I connect my headphones with my aux cord. In fact, in order to even get the headphones working, I have to go to my settings and switch my playback device from “Speakers” to “Headphones (unplugged)”. I then have to pull up qpwgraph and connect each individual application to my ““speakers”” (my headphones in this case). Playing the test audio does work, and both my headphones and the aux work perfectly fine on other devices.
This is really tedious to do, and after some research I found something that kind of works:
The issue with this solution is that while the headphones automatically connect and work, audio also plays from the speakers…
I’ve updated the system and its packages and restarted my computer multiple times.
I dualboot Windows 11 and Garuda Linux and the inxi is below! (‘u’)b
Kernel: 6.7.6-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=78472b41-65a2-468f-90ff-97c68ad19967 rw rootflags=subvol=@
Type: Laptop System: LENOVO product: 82B1 v: Lenovo Legion 5 15ARH05H
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05H
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN
serial: <superuser required> part-nu: LENOVO_MT_82B1_BU_idea_FM_Legion 5
15ARH05H uuid: <superuser required> UEFI: LENOVO v: FSCN26WW
date: 09/09/2022
ID-1: BAT0 charge: 49.5 Wh (100.0%) condition: 49.5/60.0 Wh (82.4%)
volts: 17.3 min: 15.4 model: SMP L19M4PC0 type: Li-poly serial: <filter>
status: full cycles: 1465
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
serial: <filter> charge: 5% (should be ignored) rechargeable: yes
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600104
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1662 high: 4077 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1369 4: 1398 5: 1398 6: 4077 7: 1470 8: 1400 9: 1400 10: 1400 11: 1400
12: 1400 13: 1397 14: 1400 15: 1400 16: 2900 bogomips: 92623
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Lenovo
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none off: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 174f:244c
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
s-diag: 391mm (15.39")
Monitor-1: eDP-1 mapped: DP-2 note: disabled model: AU Optronics 0xb78d
built: 2019 res: 1920x1080 hz: 144 dpi: 142 gamma: 1.2
modes: 1920x1080
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.3.276 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 550.54.14
device-ID: 10de:1f15 surfaces: xcb,xlib
Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
API: ALSA v: k6.7.6-zen1-2-zen status: kernel-api with: aoss
vendor: Lenovo RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-3:5 chip-ID: 8087:0029
Report: btmgmt ID: hci0 rfk-id: 4 state: up address: <filter> bt-v: 5.2
Local Storage: total: 476.94 GiB used: 140.06 GiB (29.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFS512GD9TNI-L2A0B size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11010C10 temp: 51.9 C scheme: GPT
ID-1: / raw-size: 244.14 GiB size: 244.14 GiB (100.00%)
used: 140.04 GiB (57.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 27.1 MiB (10.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 244.14 GiB size: 244.14 GiB (100.00%)
ID-4: /var/log raw-size: 244.14 GiB size: 244.14 GiB (100.00%)
ID-5: /var/tmp raw-size: 244.14 GiB size: 244.14 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.49 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 100.9 C mobo: N/A gpu: nvidia temp: 90 C
Memory: total: 16 GiB available: 15.49 GiB used: 4.82 GiB (31.1%)
Processes: 426 Power: uptime: 11m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: org_kde_powerdevil,
Packages: 1494 pm: pacman pkgs: 1475 libs: 473 tools: octopi,paru
pm: flatpak pkgs: 19 Compilers: gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2023-12-17
Last full system update: 2024-03-01
That’s probably key. Windows hijacks your adaptor and assigns a MAC address. You reboot into Linux, which says WTF?, and it needs to be re-acquired.
@tbg is more familiar with what you might do, I dunno.
I know it says one issue per topic, but I believe this is related. When using obs, my mic works just fine, but when i plug my headphones in, I once again have this issue. Using qpwgraph doesnt seem to be helping, either.
