Give them your little finger, and they will rip your arm off.
Reich ihnen den kleinen Finger und sie werden dir den Arm abreißen.
This may help keep you arm, but you will miss a finger as there is 2 errors I don’t know how to fix.
Keep your arm! Feel free to use and change as anyone would like.
Benefits:
-c|--country
and -s
to command lineCOUNTRY
$HOME/.config/garuda/garuda-update.conf
Errors:
--country
Stuck in loop if disable lines 87-90. Will not pass the country if not disabled. #!/bin/bash
set -e
update_keyrings() {
local packages=("archlinux-keyring" "chaotic-keyring" "garuda-hotfixes")
if $PACMAN -Qq blackarch-keyring &> /dev/null; then
packages+=("blackarch-keyring")
fi
if [ ! -z "$($PACMAN -Qu ${packages[@]} 2>&1)" ]; then
echo -e "\n\033[1;33m-->\033[1;34m Applying keyring updates before starting full system update..\033[0m"
SNAP_PAC_SKIP=y SKIP_AUTOSNAP= $PACMAN -S --needed --noconfirm ${packages[@]} || false
fi
self_update() {
# Let the update script self update
if [ -z "$GARUDA_UPDATE_SELFUPDATE" ]; then
[ "$DATABASE_UPDATED" != "true" ] && $PACMAN -Sy && DATABASE_UPDATED=true || true
$PACMAN -Qu garuda-update &> /dev/null && SNAP_PAC_SKIP=y SKIP_AUTOSNAP= $PACMAN -S garuda-update --needed --noconfirm && GARUDA_UPDATE_SELFUPDATE=1 exec /usr/bin/garuda-update "$1" || true # whatever, it is how it is
# Check if we have received sigint and should exit
$INT
fi
show_changelog() {
# Show update notices if the notices file exists
if [ -e "/var/lib/garuda/tmp/update_notices" ]; then
echo -e "\033[1;32mUpdate notices:\n\033[1;34m$(cut -f2 /var/lib/garuda/tmp/update_notices)\n\033[0m"
rm /var/lib/garuda/tmp/update_notices
fi
# Some funny stuff with reflector makes it not exit on sigint, we set up our own sigint handler for that
INT=true
trap "INT=false" INT
# Elevate once and stop asking for the password constantly
if [[ $EUID -ne 0 ]]; then
exec sudo --preserve-env="SKIP_MIRRORLIST,UPDATE_AUR,PACMAN_EXE,HOME" /usr/bin/garuda-update "$@"
exit 1
fi
# Run the "I'm too lazy to fix it myself all in one" script
if [ "$1" == "remote" ]; then
exec bash -c "VERSION=5 . <(wget -qO- https://gitlab.com/garuda-linux/themes-and-settings/settings/garuda-common-settings/-/snippets/2147440/raw/main/remote-update) \"$2\" \"$3\""
fi
if [ ! -z "$PACMAN_EXE" ]; then
PACMAN="$PACMAN_EXE"
else
PACMAN="pacman"
fi
DATABASE_UPDATED=false
self_update "$@"
if [ -f /etc/garuda/garuda-update/config ]; then
source /etc/garuda/garuda-update/config
fi
if [ -f $HOME/.config/garuda/garuda-update.conf ]; then
source $HOME/.config/garuda/garuda-update.conf
fi
# Parse CLI options
PARSED_OPTIONS=$(getopt --options="a,s,c" --longoptions="aur,skip-mirrorlist,country" --name "$0" -- "$@")
if [[ $? -ne 0 ]]; then
echo -e "\033[1;31m\nFailed to parse CLI options\n\033[0m"
fi
eval set -- "$PARSED_OPTIONS"
while true; do
case "$1" in
-a|--aur)
UPDATE_AUR=1
shift
-s|--skip-mirrorlist)
SKIP_MIRRORLIST=1
shift
-c|--country)
shift
COUNTRY=${@:2}
shift
shift
break
echo "Programming error"
exit 3
esac
done
if [[ ! -v SKIP_MIRRORLIST ]]; then
# Refresh mirrorlists
if [ -x /usr/bin/reflector ]; then
if [[ $COUNTRY ]]; then
echo -e "\n\033[1;33m-->\033[1;34m Refreshing mirrorlists using reflector for $COUNTRY, please be patient..\033[0m"
reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --country $COUNTRY --save /etc/pacman.d/mirrorlist \
&& $INT && cat /etc/pacman.d/mirrorlist && echo "" \
&& $PACMAN -Syy && DATABASE_UPDATED=true || { echo -e "\033[1;31m\nFailed to update mirrorlist\n\033[0m"; }
$INT
else
echo -e "\n\033[1;33m-->\033[1;34m Refreshing mirrorlists using reflector, please be patient..\033[0m"
reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist \
$INT
fi
elif [ -x /usr/bin/rate-mirrors ]; then
echo -e "\n\033[1;33m-->\033[1;34m Refreshing mirrorlists using rate-mirrors, please be patient..\033[0m"
MIRRORLIST_TEMP="$(mktemp)" && rate-mirrors --allow-root --save=$MIRRORLIST_TEMP arch --max-delay=21600 &> /dev/null \
&& chmod 644 /etc/pacman.d/mirrorlist $MIRRORLIST_TEMP && \mv $MIRRORLIST_TEMP /etc/pacman.d/mirrorlist && $PACMAN -Syy && DATABASE_UPDATED=true || { echo -e "\033[1;31m\nFailed to update mirrorlist\033[0m"; }
$INT
fi
fi
self_update "$@"
update_keyrings
# Run pre-update routines and hotfixes
/usr/lib/garuda/garuda-update/pre-update-routines
pacman_args=("-Su")
if [ "$DATABASE_UPDATED" == false ]; then pacman_args+=("-y"); fi
if [ -x /usr/bin/expect ]; then
LANG=C /usr/lib/garuda/garuda-update/auto-pacman $PACMAN "${pacman_args[@]}" || { [ "$?" != "134" ] && false; }
else
fi
if [[ -v UPDATE_AUR ]]; then
# Check for AUR helper
if [ -x /usr/bin/paru ] && [[ ! -z "$SUDO_UID" ]]; then
echo -e "\n\033[1;33m-->\033[1;34m Updating AUR packages with paru..\033[0m"
sudo -u "#$SUDO_UID" paru -Sua || { echo -e "\033[1;31m\nParu exited with error code $?\n\033[0m"; }
elif [ -x /usr/bin/yay ] && [[ ! -z "$SUDO_UID" ]]; then
echo -e "\n\033[1;33m-->\033[1;34m Updating AUR packages with yay..\033[0m"
sudo -u "#$SUDO_UID" yay -Sua || { echo -e "\033[1;31m\nYay exited with error code $?\n\033[0m"; }
else
echo -e "\n\033[1;33m--> UPDATE_AUR specified but no supported AUR helper found\033[0m"
fi
$INT
fi
# Update mlocate index in the background
if [ -x /usr/bin/locate ]; then
systemctl start updatedb.service
fi
# Update fish completions
if [ -x /usr/bin/fish ] && [ ! -z "$SUDO_UID" ]; then
echo ""
sudo -u "#$SUDO_UID" fish -c fish_update_completions
fi
# Update micro plugins
if [ -x /usr/bin/micro ] && [ ! -z "$SUDO_UID" ]; then
echo ""
sudo -u "#$SUDO_UID" micro -plugin update
fi
echo -e "\n\033[1;32mSystem updated! 🐧\n\033[0m"
show_changelog
