Guys while trying to install comfortaa font. I replaced some preinstalled fonts, now i cant see special symbols, they appear square box[] , i cant see the dragon next to startmenu.
inxi -faa if its any help
System: Kernel: 5.13.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=99c4694c-a63d-4e07-8562-56bdc42b086b rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Machine: Type: Laptop System: LENOVO product: 80U0 v: Lenovo Yoga710-15ISK
serial: <filter> Chassis: type: 10 v: Lenovo Yoga710-15ISK serial: <filter>
Mobo: LENOVO model: Lenovo Yoga710-1 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: 0GCN24WW(V1.08) date: 06/22/2018
CPU: Info: Dual Core model: Intel Core i5-6200U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 4E (78) stepping: 3 microcode: EA cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
bogomips: 19200
Speed: 2700 MHz min/max: 400/2800 MHz Core speeds (MHz): 1: 2700 2: 2719
3: 2719 4: 2740
Type: l1tf
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Realtek EasyCamera type: USB driver: uvcvideo bus-ID: 1-5:4
chip-ID: 0bda:57f8 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: i915
note: n/a (using device driver) display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70
Sound Server-1: ALSA v: k5.13.13-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Network: Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel port: 4040
bus-ID: 01:00.0 chip-ID: 8086:24f3 class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-7:5 chip-ID: 8087:0a2b class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
rfk-block: hardware: no software: yes address: <filter>
Drives: Local Storage: total: 238.47 GiB used: 55.04 GiB (23.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: HFS256G39MND-3310A
type: SSD serial: <filter> rev: 2P00 scheme: GPT
Partition: ID-1: / raw-size: 90 GiB size: 90 GiB (100.00%) used: 54.91 GiB (61.0%)
fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 131 MiB (51.2%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 90 GiB size: 90 GiB (100.00%) used: 54.91 GiB (61.0%)
ID-4: /var/log raw-size: 90 GiB size: 90 GiB (100.00%) used: 54.91 GiB (61.0%)
ID-5: /var/tmp raw-size: 90 GiB size: 90 GiB (100.00%) used: 54.91 GiB (61.0%)
ID-1: swap-1 type: zram size: 7.62 GiB used: 98.5 MiB (1.3%) priority: 100
Sensors: System Temperatures: cpu: 47.0 C mobo: N/A
Info: Processes: 228 Uptime: 2h 47m wakeups: 1 Memory: 7.62 GiB
used: 4.49 GiB (58.9%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1560 lib: 433 flatpak: 0
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
