inxi -Faz : https://termbin.com/m0an
When i click apply after i have selected the applications, it doesn't get installed. I tried: going into octopi and checking if there are packages to install, doing a pacman -Syu and running it from the command line, the output of the command line is here: https://termbin.com/5zqc
please help me, i know i can pacman -S them but i want to try the gui
Welcome,
you can post terminal output, as text, in your post.
Icon theme "gnome" not found.
libpng warning: iCCP: known incorrect sRGB profile
System: Kernel: 5.14.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=0b1a0c9b-bfd7-49e3-a105-6916ebe06cf1
systemd.unified_cgroup_hierarchy=1 resume=UUID=f29008b3-5294-46a8-8303-ebcd2f60af1a loglevel=3
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: GL10CS v: 1.0 serial: <filter> UEFI: American Megatrends
v: GL10CS.311 date: 04/21/2020
CPU: Info: 8-Core model: Intel Core i7-9700K bits: 64 type: MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: C (12) microcode: EA cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57600
Speed: 4801 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 4801 2: 4893 3: 4554 4: 4852
5: 4845 6: 4824 7: 4739 8: 4801
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: NVIDIA TU116 [GeForce GTX 1660 Ti] vendor: ASUSTeK driver: nvidia v: 470.74
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2182 class-ID: 0300
Device-2: Lenovo FHD Webcam type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-1:2
chip-ID: 17ef:4831 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9") s-diag: 610mm (24")
Monitor-1: DP-0 res: 1920x1080 hz: 144 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: N/A v: N/A direct render: N/A
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Device-3: Lenovo FHD Webcam type: USB driver: snd-usb-audio,uvcvideo bus-ID: 1-1:2
Sound Server-1: ALSA v: k5.14.8-zen1-1-zen running: yes
Network: Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus-ID: 1-14:7 chip-ID: 8087:0aaa class-ID: e001
Drives: Local Storage: total: 1.32 TiB used: 12.79 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: RBUSNS8154P3256GJ size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: E8FK11.C temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST380211AS size: 74.53 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: N/A serial: <filter> rev: B scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST380211AS size: 74.53 GiB block-size:
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
serial: <filter> rev: CC43 scheme: MBR
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Toshiba model: TransMemory size: 28.87 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw-size: 65.47 GiB size: 65.47 GiB (100.00%) used: 12.79 GiB (19.5%) fs: btrfs
dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 65.47 GiB size: 65.47 GiB (100.00%) used: 12.79 GiB (19.5%) fs: btrfs
ID-4: /var/log raw-size: 65.47 GiB size: 65.47 GiB (100.00%) used: 12.79 GiB (19.5%) fs: btrfs
ID-5: /var/tmp raw-size: 65.47 GiB size: 65.47 GiB (100.00%) used: 12.79 GiB (19.5%) fs: btrfs
ID-1: swap-1 type: zram size: 7.69 GiB used: 327 MiB (4.2%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb3
maj-min: 8:19
Sensors: System Temperatures: cpu: 53.0 C mobo: N/A gpu: nvidia temp: 47 C
Fan Speeds (RPM): cpu: 900 gpu: nvidia fan: 33%
Info: Processes: 291 Uptime: 33m wakeups: 0 Memory: 7.69 GiB used: 3.52 GiB (45.8%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1146 lib: 274 Shell: fish
v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.08
Use
update
or in Garuda Assistent "Refresh Mirror List"
Seems you never update your system after installation.
i updated it just before installation, some 385 packages updated installed it one hour back
This does not affect the installation.
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
warning: garuda-update-1.3.1-1 is up to date -- skipping
there is nothing to do
Refreshing mirrorlists using reflector, be patient please..
[2021-11-09 19:56:36] WARNING: failed to rate http(s) download (https://mirror.telepoint.bg/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-09 19:56:42] WARNING: failed to rate http(s) download (https://archlinux.mailtunnel.eu/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-09 19:56:48] WARNING: failed to rate http(s) download (https://mirror.f4st.host/archlinux/community/os/x86_64/community.db): Download timed out after 5 second(s).
[2021-11-09 19:57:00] WARNING: failed to rate http(s) download (https://mirror.chaoticum.net/arch/community/os/x86_64/community.db): Download timed out after 5 second(s).
################# Arch Linux mirrorlist generated by Reflector #################
# With: reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When: 2021-11-09 14:27:00 UTC
# From: https://archlinux.org/mirrors/status/json/
# Retrieved: 2021-11-09 14:26:30 UTC
# Last Check: 2021-11-09 14:07:04 UTC
Server = https://mirror.cyberbits.eu/archlinux/$repo/os/$arch
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
Server = https://mirror.chaoticum.net/arch/$repo/os/$arch
core 137.9 KiB 118 KiB/s 00:01 [------------------------------------] 100%
extra 1568.6 KiB 647 KiB/s 00:02 [------------------------------------] 100%
community 5.8 MiB 1247 KiB/s 00:05 [------------------------------------] 100%
multilib 150.3 KiB 128 KiB/s 00:01 [------------------------------------] 100%
chaotic-aur 1597.5 KiB 786 KiB/s 00:02 [------------------------------------] 100%
Checking for keyring update before starting full system update..
warning: garuda-hotfixes-1.0.4-1 is up to date -- skipping
warning: archlinux-keyring-20211028-1 is up to date -- skipping
warning: chaotic-keyring-20210617-1 is up to date -- skipping
Updating mlocate index..
Parsing man pages and writing completions to /home/hr/.local/share/fish/generated_completions/
3215 / 3215 : zramctl.8.gz
Checking for plugin updates
Nothing to install / update
System updated! 🐧
this is the output of update
*after sorry
Kernel: 5.14.16-zen1-1-zen x86_64
Your kernel is 5.14.8.
IDK what the problem in your system is.
Was that intentional to choose a name similar to an admin?
Usually it should install the packages after clicking apply. What exactly happens when you execute this?
Rebooted yet?
I can not work like this.
Ich kann so nicht arbeiten.
no i never visited the forums before
Hold up, wait a minute. i rebooted and it worked????? have i accidentally installed windows lol
Kernel updates need reboot.
yeah, but then why wasnt garuda gamer installing???
