I guess I'm missing some icons because I have a weird question mark beside my KDE Dr460nized text. I'll include a screenshot.
Plus, I found a solution for the same problem on the forum but that didn't work in my case.
What did you try precisely?
Maybe https://forum.garudalinux.org/t/missing-icons/13396/12?
Did you tried also installing noto-color-emoji-fontconfig
Could you please provde also your inxi -Faz
use kde's edition mode, and custom the text after dragon icon
yeah i had similar issue, make sure you have a file called local.conf
inside /etc/fonts/
if you don't have it you could try to fix it the way i did:
A moderator has requested you to please provide your system information. If your next post on this help request does not include this information your thread will be locked and further assistance will not be provided.
Kindly provide this information as specified in the help request template and as requested by a forum moderator.
