Hi All,
I am having a strange display issue with the wifi notification area, where there is a blank black space in the wifi ssid selection screen between "configure" and metrics like "speed" as shown in the image attached.
Firstly, results of
Kernel: 5.18.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f62e142c-a8a4-489e-8e20-b394425d0b8b rw [email protected]
resume=UUID=d2c61c50-8a16-47bb-b34f-7eb8d5d1ee85 loglevel=3 pci=realloc
Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: Micro-Star product: GS66 Stealth 10UG v: REV:1.0
Mobo: Micro-Star model: MS-16V3 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16V3IMS.111 date: 09/28/2021
ID-1: BAT1 charge: 88.2 Wh (92.6%) condition: 95.2/95.0 Wh (100.2%)
volts: 16.9 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: N/A
Info: model: Intel Core i7-10870H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 2 microcode: 0xF0
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4676 high: 4709 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 4598 2: 4695 3: 4667
4: 4689 5: 4701 6: 4685 7: 4699 8: 4692 9: 4690 10: 4666 11: 4709
12: 4709 13: 4678 14: 4696 15: 4622 16: 4633 bogomips: 70399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA GA104M [GeForce RTX 3070 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 515.48.07
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:249d class-ID: 0300
Device-3: Acer HD Camera type: USB driver: uvcvideo bus-ID: 1-11:3
chip-ID: 5986:2127 class-ID: 0e02 serial: <filter>
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: AU Optronics 0x328e built: 2019 res: 1920x1080
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: NVIDIA GA104 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228b
Sound Server-1: ALSA v: k5.18.5-zen1-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2725
IF: wlp61s0 state: up mac: <filter>
Device-2: Intel driver: igc v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
port: N/A bus-ID: 3e:00.0 chip-ID: 8086:3101 class-ID: 0200
IF: enp62s0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-14:4 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 2.77 TiB used: 41.19 GiB (1.5%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung model: SSD 980 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7
temp: 45.9 C scheme: GPT
model: PC SN720 SDAQNTX-2T00-1032 size: 1.86 TiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 10204122 temp: 49.9 C scheme: GPT
ID-1: / raw-size: 896.93 GiB size: 896.93 GiB (100.00%)
used: 41.19 GiB (4.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:8
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:7
ID-3: /home raw-size: 896.93 GiB size: 896.93 GiB (100.00%)
ID-4: /var/log raw-size: 896.93 GiB size: 896.93 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.93 GiB size: 896.93 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.17 GiB used: 1.2 MiB (0.0%)
ID-2: swap-2 type: partition size: 34.28 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:9
System Temperatures: cpu: 66.0 C pch: 55.0 C mobo: N/A
Processes: 377 Uptime: 48m wakeups: 5 Memory: 31.17 GiB
used: 6.19 GiB (19.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1978
lib: 559 Shell: fish v: 3.4.1 running-in: konsole inxi: 3.3.18
Garuda (2.6.4-1):
System install date: 2022-06-21
Last full system update: 2022-06-21 ↻
Steps I tried to fix:
- Remove panel system-tray and re-add
- Restore default Garuda config for latte
- Reinstall the OS (fixes temporarily until the install additional KDE apps screen)
Any ideas would be welcome.
