Weird Rotation when switching display
Kernel: 6.16.0-arch1-1-znver3 arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver3
root=UUID=9b96c5b3-cd06-4f28-97a4-93bdac58ed2e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.4.4 tk: Qt v: N/A info: frameworks v: 6.17.0
Mobo: ASUSTeK model: ROG CROSSHAIR VII HERO (WI-FI) v: Rev 1.xx
UEFI: American Megatrends v: 5404 date: 03/18/2024
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3878 min/max: 567/4955 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3878 2: 3878 3: 3878
4: 3878 5: 3878 6: 3878 7: 3878 8: 3878 9: 3878 10: 3878 11: 3878 12: 3878
13: 3878 14: 3878 15: 3878 16: 3878 17: 3878 18: 3878 19: 3878 20: 3878
21: 3878 22: 3878 23: 3878 24: 3878 bogomips: 177594
Device-1: NVIDIA AD104 [GeForce RTX 4070 Ti] vendor: ASUSTeK driver: nvidia
v: 575.64.05 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
status: current (as of 2025-04) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: none off: HDMI-A-2
empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 0a:00.0 chip-ID: 10de:2782
Monitor-1: HDMI-A-2 model: LG (GoldStar) SDQHD serial: <filter>
built: 2022 res: mode: 2560x2880 hz: 60 scale: 133% (1.33) to: 1920x1707
dpi: 140 gamma: 1.2 size: 465x523mm (18.31x20.59") diag: 700mm (27.6")
modes: max: 2560x2880 min: 640x480
API: EGL v: 1.5 platforms: device: 1 drv: swrast surfaceless: drv: swrast
wayland: drv: swrast x11: drv: swrast inactive: gbm,device-0
API: OpenGL v: 4.5 vendor: mesa v: 25.1.7-arch1.1 note: incomplete (EGL
sourced) renderer: llvmpipe (LLVM 20.1.8 256 bits)
API: Vulkan v: 1.4.321 layers: 15 device: 0 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM
Device-1: NVIDIA AD104 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 10de:22bc
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: SteelSeries ApS Arctis Pro Wireless
lanes: 1 mode: 1.1 bus-ID: 1-3.3:7 chip-ID: 1038:1294 class-ID: 0300
API: ALSA v: k6.16.0-arch1-1-znver3 status: kernel-api with: aoss
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 06:00.0
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw88_8822be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: c000 bus-ID: 07:00.0 chip-ID: 10ec:b822 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Device-3: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4
chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
Device-1: ASUSTek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 0b05:185c
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 2.73 TiB used: 365.66 GiB (13.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 38.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 047 scheme: GPT
used: 365.66 GiB (39.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 616 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 62.68 GiB used: 8.7 MiB (0.0%) priority: 100
System Temperatures: cpu: 70.0 C mobo: 38.0 C
Fan Speeds (rpm): cpu: 0 case-1: 0 case-2: 1483 case-3: 0 fan-1: 0
Power: 12v: 12.15 5v: N/A 3.3v: N/A vbat: 3.21
Memory: total: 64 GiB note: est. available: 62.68 GiB
used: 16.41 GiB (26.2%)
Processes: 588 Power: uptime: 3h 54m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.01 GiB services: org_kde_powerdevil,
Packages: 2414 pm: pacman pkgs: 2408 libs: 562 tools: octopi,paru
pm: flatpak pkgs: 6 Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 13/14
Shell: Bash v: 5.3.3 default: fish v: 4.0.2 running-in: konsole
inxi: 3.3.38
Garuda (2.8.1-2):
System install date:     2025-03-08
Last full system update: 2025-08-21 ↻
22/23 checks run in 0.79 seconds ⌛
Powered by garuda-health 🦅
I use a 9:8 monitor, rotated on its side so that it is 8:9. However, I’d like to fit a 16:9 display, it works perfectly when doing it without rotation (on the 9:8) display, however when rotating the display instead of a horizontal bar I get a vertical bar.
  • Garuda-inxi is telling you through this sign ↻ that you should reboot the system.
    You should also only post garuda-inxi afterwards.
Your bios is out of date. Ver. 5602 is out. Please remember to use the correct BIOS settings afterwards. (uefi not csm /fastboot secure boot off /AHCI mode / resize bar enabled)
Weird rotation problem
Pls post again after reboot garuda-inxi + pacman -Qs nvidia
Kernel: 6.16.2-arch1-1-znver3 arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
quiet loglevel=3
Speed (MHz): avg: 1731 min/max: 567/4955 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1731 2: 1731 3: 1731
4: 1731 5: 1731 6: 1731 7: 1731 8: 1731 9: 1731 10: 1731 11: 1731 12: 1731
13: 1731 14: 1731 15: 1731 16: 1731 17: 1731 18: 1731 19: 1731 20: 1731
21: 1731 22: 1731 23: 1731 24: 1731 bogomips: 177605
v: 580.76.05 alternate: nouveau,nvidia_drm non-free: 550-570.xx+
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.76.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4070 Ti/PCIe/SSE2
memory: 11.71 GiB display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 15 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4070 Ti driver: nvidia v: 580.76.05 device-ID: 10de:2782
surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 20.1.8 256 bits)
driver: mesa llvmpipe v: 25.1.7-arch1.1 (LLVM 20.1.8)
API: ALSA v: k6.16.2-arch1-1-znver3 status: kernel-api with: aoss
Local Storage: total: 2.73 TiB used: 371.32 GiB (13.3%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 24.9 C
used: 371.32 GiB (39.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 62.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C mobo: 25.0 C
Fan Speeds (rpm): cpu: 0 case-1: 0 case-2: 1250 case-3: 0 fan-1: 0
Memory: total: 64 GiB note: est. available: 62.68 GiB used: 5.4 GiB (8.6%)
Processes: 483 Power: uptime: 6m states: freeze,mem,disk suspend: deep
Packages: 2415 pm: pacman pkgs: 2409 libs: 562 tools: octopi,paru
inxi: 3.3.38
Garuda (2.8.1-2):
Last full system update: 2025-08-24
22/23 checks run in 0.85 seconds ⌛
local/cuda 12.9.1-2
NVIDIA's GPU programming toolkit
local/egl-gbm 1.1.2.1-1
The GBM EGL external platform library
local/egl-wayland 4:1.1.20-1
EGLStream-based Wayland external platform
local/egl-x11 1.0.3-1
NVIDIA XLib and XCB EGL Platform Library
local/garuda-hardware-profile-nvidia 1.1.1-2
Garuda Linux hardware profile with nvidia drivers
local/gwe 0.15.9-1.1
A system utility for controlling NVIDIA GPUs
local/lib32-libvdpau 1.5-3
Nvidia VDPAU library
local/lib32-nvidia-utils 580.76.05-1
NVIDIA drivers utilities (32-bit)
local/lib32-opencl-nvidia 580.76.05-1
OpenCL implemention for NVIDIA (32-bit)
local/libvdpau 1.5-3
local/libxnvctrl 580.76.05-1
NVIDIA NV-CONTROL X extension
local/linux-firmware-nvidia 20250808-1
Firmware files for Linux - Firmware for NVIDIA GPUs and SoCs
local/nvidia-open-dkms 580.76.05-4
NVIDIA open kernel modules - module sources
local/nvidia-prime 1.0-5
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-settings 580.76.05-1
Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 580.76.05-4
local/opencl-nvidia 580.76.05-4
local/xf86-video-nouveau 1.0.18-1 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
All the stuff for nvidia is installed
Opengl problem is history
No bios update ? You like security risks and perhaps other problems or ?
Testet with other port ?
I’ve updated the bios now (was looking for a usb drive :melting_face:)
quiet loglevel=3
UEFI: American Megatrends v: 5602 date: 01/13/2025
model-id: 0x21 (33) stepping: 2 microcode: 0xA201213
21: 1731 22: 1731 23: 1731 24: 1731 bogomips: 177602
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:10
Local Storage: total: 2.73 TiB used: 371.87 GiB (13.3%)
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 34.9 C
used: 371.86 GiB (39.9%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 59.0 C mobo: 30.0 C
Fan Speeds (rpm): cpu: 0 case-1: 0 case-2: 1473 case-3: 0 fan-1: 0
Power: 12v: 12.15 5v: N/A 3.3v: N/A vbat: 3.18
Memory: total: 64 GiB note: est. available: 62.68 GiB used: 5.52 GiB (8.8%)
Processes: 533 Power: uptime: 2m states: freeze,mem,disk suspend: deep
inxi: 3.3.38
Garuda (2.8.1-2):
local/cuda 12.9.1-2
Attempted all other HDMI ports, problem persists. (Can’t upload images, new user) https://drive.google.com/drive/folders/1fyR4AISuwHKpb0PWMyS7dirICfI8mCNy?usp=sharing
Not only hdmi.. you have a dp port, also.
Your Monitor 27,6 Zoll Ergo DualUp Monitor is a little bit special (my mind)
It’s a special format 16:18 default with native 2.560 x 2.880, (then 2x 8x9) but sorry 9:8 and default you should use 8:9. Perhaps i understand this wrong. (9:8)
You use the default native resolution and all is fine
→ switch to 16:9 with 3840x2160
That’s not native and you have this result. (rotated, pic 2)
Of course it’s works perfect without the rotation…and not if rotated.
How should this possible if 3840 ? The “metal” must set this to vertical (my mind, but perhaps i understand this totaly wrong)
I don’t have this metal..more help from my side.. sorry.. not possible
