Hello there,
I’ve just now installed Garuda Linux Gnome Edition and noticed something strange.
I’m using two montiors and whenever I touch the right side of my second (right) montior. All displays move a little bit to the left.
I can do this however long I want until the window/workspace that previously was on my second screen, now is on my main screen.
The Workspace/windows I had on my main screen got pushed out of the display to the left.
Kernel: 6.5.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=43b24c17-d93b-422c-86a9-512969a67d2a rw rootflags=subvol=@
Desktop: GNOME v: 44.5 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3601
date: 05/26/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3775 high: 3800 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800
3: 3800 4: 3800 5: 3610 6: 3800 7: 3800 8: 3600 9: 3800 10: 3800 11: 3800
12: 3800 13: 3800 14: 3800 15: 3800 16: 3800 bogomips: 121606
Device-1: NVIDIA GM200 [GeForce GTX 980 Ti] driver: nvidia v: 535.104.05
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 0a:00.0 chip-ID: 10de:17c8
Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2
chip-ID: 046d:08e5 class-ID: 0102
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: :1 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x286mm (60.00x11.26")
s-diag: 1551mm (61.05")
Monitor-1: DP-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 92
Monitor-2: DP-3 pos: right res: 1920x1080 hz: 60 dpi: 92
Monitor-3: None-1-1 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.104.05 renderer: NVIDIA GeForce GTX 980
Ti/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GM200 High Definition Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:0fb0
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
Device-4: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 5-2:2 chip-ID: 1235:8202 class-ID: 0102
API: ALSA v: k6.5.4-zen2-1-zen status: kernel-api with: aoss
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 8087:0029
Local Storage: total: 5.68 TiB used: 13.23 GiB (0.2%)
fw-rev: 3B2QEXM7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: Q300. size: 223.57 GiB
serial: <filter> fw-rev: 12.3 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-5: /dev/sdd maj-min: 8:48 vendor: Verbatim model: STORE N GO
size: 7.47 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.0
scheme: MBR
used: 13.23 GiB (1.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 40.0 C mobo: 29.0 C gpu: nvidia temp: 44 C
Fan Speeds (rpm): cpu: 0 gpu: nvidia fan: 22%
Processes: 400 Uptime: 26m wakeups: 0 Memory: total: 32 GiB
available: 31.25 GiB used: 4.12 GiB (13.2%) Init: systemd v: 254
pm: pacman pkgs: 1414 libs: 496 tools: pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.29
System install date: 2023-09-23
Last full system update: 2023-09-23
I’ve made a full screenshot here:
In which you can see that there appears to be a third screen which is just entirely black. This would also explain the “Unknown Display” I see in my Settings here:
Sadly I can’t make a video or anything related to better showcase the issue since the displays are being moved as a whole, so you wouldn’t notice in a video.
Is there anything I can do to resolve this issue? Or is it some kind of strange “feature”?
