Hi,
I just bought a new router because my old one was very slow. I tried it on windows and the download speed was about 50 mb/s on the torrent app . On Garuda it is limited to 10 mb/s (that was the max speed of the old router), I looked in the setting but i saw no speed limit, neither in the torrent app.
Thanks in advance.
Kernel: 5.17.2-254-tkg-bmq arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux517-tkg-bmq
root=UUID=4c27e197-bd40-4566-9ca4-d959713ef278 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: Micro-Star model: B450M-A PRO MAX (MS-7C52) v: 1.0
serial: <superuser required> BIOS: American Megatrends LLC. v: 3.C0
date: 05/19/2021
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4007 high: 4199 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4162 2: 4034
3: 4171 4: 4171 5: 4181 6: 3794 7: 4199 8: 3713 9: 3775 10: 3814 11: 3967
12: 4105 bogomips: 86404
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 29:00.0 chip-ID: 10de:21c4 class-ID: 0300
Device-2: KYE Systems (Mouse Systems) Genius Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2 chip-ID: 0458:6006
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.70x13.43")
s-diag: 692mm (27.24")
Monitor-1: HDMI-0 res: 3840x2160 hz: 60 dpi: 163
size: 600x340mm (23.62x13.39") diag: 690mm (27.15") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1660 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel bus-ID: 5-1:2 v: kernel pcie: chip-ID: 0458:6006
gen: 3 class-ID: 0102 serial: <filter> speed: 8 GT/s lanes: 16
bus-ID: 29:00.1 chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: KYE Systems (Mouse Systems) Genius Webcam type: USB
Sound Server-1: ALSA v: k5.17.2-254-tkg-bmq running: yes
Sound Server-3: PipeWire v: 0.3.53 running: yes
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 1.82 TiB used: 434.35 GiB (23.3%)
rev: 2B2QEXM7 temp: 40.9 C scheme: MBR
model: WDS100T2B0A-00SM50 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00WD
used: 434.35 GiB (46.6%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.61 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A gpu: nvidia temp: 39 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1662 fan-3: 0 fan-4: 0 fan-5: 0
gpu: nvidia fan: 55%
Power: 12v: N/A 5v: N/A 3.3v: 3.34 vbat: 3.36
Processes: 323 Uptime: 21m wakeups: 0 Memory: 15.61 GiB
used: 5.87 GiB (37.6%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 2048
lib: 555 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-02-17
Last full system update: 2022-07-07
Failed units: bluetooth-autoconnect.service nmb.service
