Hey there,
I just today discovered a weird freezing problem on my system, which I just triggered via clicking on the icon of telegram client (kotatogram) on latte.
I looked at dmesg and I think this is my problem:
(The newest stuff is at the top)
https://termbin.com/mzbm
Lsusb showed this:
Bus 004 Device 002: ID 05e3:0620 Genesys Logic, Inc. USB3.0 Hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 004: ID 046d:0825 Logitech, Inc. Webcam C270
Bus 003 Device 003: ID 0c45:652f Microdia Backlit Gaming Keyboard
Bus 003 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0d8c:9700 C-Media Electronics, Inc. USB Microphone
Bus 001 Device 002: ID 046d:c332 Logitech, Inc. G502 Proteus Spectrum Optical Mouse
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
3-3 is my keyboard - This can't be the issue, can it?
Is there a way to solve this?
Thanks!
System: Kernel: 5.14.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=2a555427-5d35-463f-8011-b023a855b928
rw rootflags=subvol=@ loglevel=3 quiet splash lsm=lockdown,yama,apparmor,bpf
Desktop: KDE Plasma 5.23.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2
dm: Ly 0.5.3.r0.g4094d21 Distro: Garuda Linux base: Arch Linux
Machine: Type: Desktop System: Gigabyte product: AX370-Gaming 3 v: N/A serial: <filter>
Mobo: Gigabyte model: AX370-Gaming 3-CF v: x.x serial: <filter>
UEFI-[Legacy]: American Megatrends v: F50a date: 11/27/2019
CPU: Info: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86225
Speed: 4009 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 4009 2: 4094
3: 3850 4: 3852 5: 4063 6: 3924 7: 3978 8: 3988 9: 3906 10: 3930 11: 4146 12: 3985
Graphics: Device-1: AMD Baffin [Radeon RX 550 640SP / RX 560/560X] vendor: ASUSTeK driver: amdgpu
v: kernel bus-ID: 08:00.0 chip-ID: 1002:67ff class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-3:4
chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 3600x1200 s-dpi: 96 s-size: 952x317mm (37.5x12.5") s-diag: 1003mm (39.5")
Monitor-1: HDMI-A-0 res: 1680x1050 hz: 60 dpi: 90 size: 474x296mm (18.7x11.7")
diag: 559mm (22")
Monitor-2: DVI-D-0 res: 1920x1200 hz: 60 dpi: 99 size: 495x310mm (19.5x12.2") diag: 584mm (23")
OpenGL: renderer: Radeon RX 560 Series (POLARIS11 DRM 3.42.0 5.14.12-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media USB Microphone type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-2:3 chip-ID: 0d8c:9700 class-ID: 0300 serial: <filter>
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-3:4
Sound Server-1: ALSA v: k5.14.12-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169
v: kernel port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives: Local Storage: total: 2.96 TiB used: 1.7 TiB (57.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD20EFRX-68EUZN0 size: 1.82 TiB
serial: <filter> rev: 0A82 scheme: GPT
Partition: ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 71.7 GiB (36.7%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /home raw-size: 736.18 GiB size: 736.18 GiB (100.00%) used: 125.07 GiB (17.0%) fs: btrfs
dev: /dev/sda3 maj-min: 8:3
ID-3: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 71.7 GiB (36.7%) fs: btrfs
ID-4: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 71.7 GiB (36.7%) fs: btrfs
ID-1: swap-1 type: zram size: 31.3 GiB used: 2.27 GiB (7.3%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 41.5 C mobo: N/A gpu: amdgpu temp: 36.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1419
Info: Processes: 409 Uptime: 8h 22m wakeups: 14 Memory: 31.3 GiB used: 9.91 GiB (31.7%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 2121 apt: 0 pacman: 2114
lib: 473 snap: 7 Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.07
