Hello Again, Friends!,
I am a little unsettled to ask this because I know I am just overlooking something silly, but I must have pressed a shortcut key or changed something in the desktop configuration because each time I close and re-open my browser and enter into a video host site (such as YT), my sound will be muted. It happens in any web browser that I choose to use and my only known thing to fix this is to select 'play all audio via this device' within my HDMI volume slide. I have to repeat this process to regain the browser sound each time I close and open the web browser. Sorry friends...I am not used to the highly configurable attributes of Garuda and KDE. I love this distro! It really is slick!!!
Best Regards,
Jeff
Kernel: 5.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=f07ccfee-40f0-4a31-9de0-a05752169b9c rw [email protected]
Type: Desktop Mobo: Micro-Star model: MAG Z490 TOMAHAWK (MS-7C80) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.A0
date: 10/19/2021
Info: model: Intel Core i7-10700K bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 5 microcode: 0xF0
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 5013 high: 5115 min/max: 800/5100 scaling:
driver: intel_pstate governor: performance cores: 1: 4926 2: 5000 3: 5092
4: 5103 5: 5001 6: 5002 7: 5001 8: 5001 9: 5001 10: 4984 11: 4987
12: 5115 13: 5002 14: 5002 15: 5003 16: 5002 bogomips: 121596
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN 4
ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-D-1 bus-ID: 01:00.0
Screen-1: 0 s-res: 2560x1080 s-dpi: 96 s-size: 677x285mm (26.65x11.22")
s-diag: 735mm (28.92")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Viewteck GNV29CB built: 2020
res: 2560x1080 hz: 60 dpi: 96 gamma: 1.2 size: 680x288mm (26.77x11.34")
diag: 738mm (29.1") modes: max: 2560x1080 min: 720x400
OpenGL: renderer: AMD Radeon RX 570 Series (polaris10 LLVM 13.0.1 DRM
3.46 5.18.3-zen1-1-zen)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 16.0 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
Device-3: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8812 class-ID: 0280
Device-1: Realtek Bluetooth 5.1 Radio type: USB driver: btusb v: 0.8
bus-ID: 1-1:2 chip-ID: 0bda:a725 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 21.53 GiB (2.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7
temp: 39.9 C scheme: GPT
ID-1: / raw-size: 296.1 GiB size: 296.1 GiB (100.00%)
used: 21.51 GiB (7.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 29.5 MiB (30.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 296.1 GiB size: 296.1 GiB (100.00%)
ID-4: /var/log raw-size: 296.1 GiB size: 296.1 GiB (100.00%)
ID-5: /var/tmp raw-size: 296.1 GiB size: 296.1 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.54 GiB used: 114.2 MiB (0.7%)
System Temperatures: cpu: 27.8 C pch: 41.0 C mobo: N/A gpu: amdgpu
temp: 54.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 425
Processes: 429 Uptime: 2d 3m wakeups: 0 Memory: 15.54 GiB
used: 4.75 GiB (30.5%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1532
lib: 364 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.18
Garuda (2.6.3-2):
System install date: 2022-06-06
Last full system update: 2022-06-15 ↻
Refusing to post the output of the required "garuda-inxi" on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki's, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum's search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
