Hello,
I am trying to launch Goxel. And I am presented with this error message:
╭─[email protected] in ~
╰─λ goxel
glfw error 65544 (Wayland: Failed to connect to display)
glfw error 65537 (The GLFW library is not initialized)
goxel: /build/glfw/src/glfw-3.3.8/src/monitor.c:445: glfwGetVideoMode: Assertion `monitor != NULL' failed.
fish: Job 1, 'goxel' terminated by signal SIGABRT (Abbruch)
so, I tought that goxel wants to start on wayland, which I thought is default.
To check, I ran:
╭─[email protected] in ~ took 347ms
[ ] × echo $XDG_SESSION_TYPE
x11
Somewhere on the web, I read that changing to sddm (wich I also thought, its the default) would activate wayland:
╰─λ sudo systemctl enable --now sddm.service
[sudo] Passwort für voidbyte:
Failed to enable unit: File /etc/systemd/system/display-manager.service already exists and is a symlink to /usr/lib/systemd/system/sddm-plymouth.service.
I guess I was wrong. Sadly, I have no other Idea how to start the program now.
Does anyone have an Idea what to do?
Thanks
Please post the output of garuda-inxi
╭─[email protected] in ~ took 15ms
[⚡] × garuda-inxi
Kernel: 6.1.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=38d11f49-afe0-4b6b-953b-9addc52154a9 rw [email protected]
resume=UUID=6d7a35cf-7ffb-4292-914c-96f115fef57f loglevel=3 ibt=off
Type: Desktop System: Gigabyte product: H97-D3H v: N/A
Mobo: Gigabyte model: H97-D3H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F7 date: 09/19/2015
Info: model: Intel Core i7-4790K bits: 64 type: MT MCP arch: Haswell
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 4306 high: 4410 min/max: 800/4400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 4370 2: 4328 3: 4400
4: 3775 5: 4365 6: 4410 7: 4400 8: 4400 bogomips: 63858
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ZOTAC driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 91 s-size: 535x301mm (21.06x11.85")
s-diag: 614mm (24.17")
Monitor-1: DVI-I-1 pos: primary res: 1920x1080 hz: 60 dpi: 92
Monitor-2: HDMI-0 size-res: N/A modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX
970/PCIe/SSE2 direct render: Yes
Device-1: Intel 9 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 3-9:6 v: kernel chip-ID: 08bb:2902
bus-ID: 00:1b.0 class-ID: 0300 chip-ID: 8086:8ca0 class-ID: 0403
Device-2: NVIDIA GM204 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:0fbb class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec type: USB
Sound API: ALSA v: k6.1.1-zen1-1-zen running: yes
Device-1: Intel Ethernet I217-V vendor: Gigabyte driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: f020
bus-ID: 00:1f.2 chip-ID: 8086:2822 rev: class-ID: 0104
Local Storage: total: 2.05 TiB used: 55.68 GiB (2.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS541075A9E680
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: B480 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Hitachi model: HDP725050GLA360
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A52A scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 vendor: Hitachi model: HDT725050VLA360
type: N/A serial: <filter> rev: A7BA scheme: MBR
ID-1: / raw-size: 681.23 GiB size: 681.23 GiB (100.00%)
used: 55.68 GiB (8.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 681.23 GiB size: 681.23 GiB (100.00%)
ID-4: /var/log raw-size: 681.23 GiB size: 681.23 GiB (100.00%)
ID-5: /var/tmp raw-size: 681.23 GiB size: 681.23 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 3.2 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.11 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 51 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 63%
Processes: 264 Uptime: 24m wakeups: 0 Memory: 15.56 GiB
used: 2.98 GiB (19.2%) Init: systemd v: 252 default: graphical
pkgs: 2096 libs: 570 tools: pamac,paru Shell: fish v: 3.5.1
Garuda (2.6.12-1):
System install date: 2022-11-28
Last full system update: 2022-12-22
It looks like there is a Wayland back end that is causing grief for some folks (here , here ). The referenced workaround is to replace glfw-wayland
with glfw-x11
sudo pacman -S glfw-x11
That solved the problem in an instant. Thank you!
system
Closed
24 December 2022 14:36
#6
