Hello! I tried to use wayland with KDE Dr460n1zed by installing plasma-wayland-session and everything kinda became half-dead. Latte dock bottom panel is just a black box and hovering over it just showed a box with "dolphin" written on it, rofi opened and didn't close, ulauncher didn't work, my second monitor got stuck at login screen etc. I had to switch back to x11 to fix everything. It seems that optimus-manager-qt didn't autostart. Any idea why this might be? I suspect thats due to me not doing a very simple step as always.
Thanks for helping!
System: Kernel: 5.11.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=babfeca7-69ba-4aac-bc94-681f770f0c20
systemd.unified_cgroup_hierarchy=1 loglevel=3 sysrq_always_enabled=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Desktop Mobo: Micro-Star model: H310M PRO-VDH (MS-7B29) v: 1.0 serial: <filter>
UEFI: American Megatrends v: 1.20 date: 03/30/2018
CPU: Info: Quad Core model: Intel Core i3-8100 bits: 64 type: MCP arch: Kaby Lake note: check
family: 6 model-id: 9E (158) stepping: B (11) microcode: DE L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28800
Speed: 3600 MHz min/max: 800/3600 MHz Core speeds (MHz): 1: 3600 2: 3600 3: 3600 4: 3600
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel 8th Gen Core Processor Gaussian Mixture Model vendor: Micro-Star MSI
driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e91 class ID: 0380
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 460.56
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c82 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: modesetting,nvidia
display ID: :0 screens: 1
Screen-1: 0 s-res: 3286x1080 s-dpi: 96 s-size: 867x285mm (34.1x11.2") s-diag: 913mm (35.9")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7")
Monitor-2: DP-1-1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348 class ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1
chip ID: 10de:0fb9 class ID: 0403
Device-3: Logitech Webcam C310 type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-14:7
chip ID: 046d:081b class ID: 0102 serial: <filter>
Sound Server: ALSA v: k5.11.7-zen1-1-zen
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: 4000 bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Realtek RTL8188EE Wireless Network Adapter driver: rtl8188ee v: kernel port: 3000
bus ID: 03:00.0 chip ID: 10ec:8179 class ID: 0280
Bluetooth: Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB driver: btusb v: 0.8
bus ID: 1-1:2 chip ID: 0a12:0001 class ID: e001
Report: ID: hci0 state: up running bt-v: 2.1 lmp-v: 4.0 sub-v: 22bb hci-v: 4.0 rev: 3120
address: <filter>
Info: acl-mtu: 640:4 sco-mtu: 64:8 link-policy: rswitch hold sniff park link-mode: slave accept
Drives: Local Storage: total: 1.72 TiB used: 30.88 GiB (1.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DX001-1NS162-SSHD size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: HP76 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Gigabyte model: GP-GSTFS31240GNTD size: 223.57 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter>
rev: 61.2 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: HP model: v221w size: 14.86 GiB block size:
physical: 512 B logical: 512 B serial: <filter> rev: 1100 scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital model: WD6400BPVT-16HXZT1
size: 596.17 GiB block size: physical: 512 B logical: 512 B rotation: 5400 rpm serial: <filter>
rev: 2.12 scheme: GPT
Partition: ID-1: / raw size: 48.85 GiB size: 48.85 GiB (100.00%) used: 23.06 GiB (47.2%) fs: btrfs
dev: /dev/sdb5 maj-min: 8:21
ID-2: /boot/efi raw size: 953 MiB size: 951.1 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat
dev: /dev/sdb6 maj-min: 8:22
ID-3: /home raw size: 587.07 GiB size: 587.07 GiB (100.00%) used: 7.82 GiB (1.3%) fs: btrfs
dev: /dev/sdd2 maj-min: 8:50
ID-4: /var/log raw size: 48.85 GiB size: 48.85 GiB (100.00%) used: 23.06 GiB (47.2%) fs: btrfs
ID-5: /var/tmp raw size: 48.85 GiB size: 48.85 GiB (100.00%) used: 23.06 GiB (47.2%) fs: btrfs
ID-1: swap-1 type: zram size: 3.88 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 3.88 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 3.88 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 3.88 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: 1024 dev: /dev/sdd3
maj-min: 8:51
Sensors: System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 40%
Info: Processes: 258 Uptime: 50m wakeups: 0 Memory: 15.5 GiB used: 3.6 GiB (23.2%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: 1527 pacman: 1521 lib: 444 flatpak: 6
Shell: fish v: 3.1.2 running in: konsole inxi: 3.3.01
