Warning: performance-tweaks: local (2.1.2-3) is newer than garuda (2.1.2-1)
The last 3 times I have updated the system with garuda update I have received this message. Does it mean anything? I use Cinnamon.
Starting full system upgrade...
warning: performance-tweaks: local (2.1.2-3) is newer than garuda (2.1.2-1)
resolving dependencies...
  Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=2d0983be-bc3c-4098-a113-de7515b07f2c rw rootflags=subvol=@
  Desktop: Cinnamon v: 6.0.0 tk: GTK v: 3.24.38 wm: muffin vt: 7 dm: LightDM
    v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: B660M DS3H DDR4 v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: F20
    date: 10/25/2022
  Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
    microcode: 0x32
  Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
    cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
    L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
  Speed (MHz): avg: 819 high: 1197 min/max: 800/4800:4900:3600 scaling:
    driver: intel_pstate governor: performance cores: 1: 800 2: 800 3: 800
    4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 1197 13: 800
    14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 84480
  Device-1: Intel AlderLake-S GT1 vendor: Gigabyte driver: i915 v: kernel
    ports: active: HDMI-A-3 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2
    bus-ID: 00:02.0 chip-ID: 8086:4680 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.9 with: Xwayland v: 23.2.2 driver: X:
    loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
  Monitor-1: HDMI-A-3 mapped: HDMI-3 model: ASUS VP248 serial: <filter>
    built: 2019 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 770 (ADL-S
    GT1) device-ID: 8086:4680 memory: 122.63 GiB unified: yes
  API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
    UHD Graphics 770 (ADL-S GT1) driver: mesa intel v: 23.2.1-arch1.2
    device-ID: 8086:4680 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
  API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api with: aoss
    type: oss-emulator tools: alsactl,alsamixer,alsamixergui,amixer
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
  Local Storage: total: 2.73 TiB used: 258.69 GiB (9.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S1000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: SBJ00101 temp: 31.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
    used: 258.69 GiB (27.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 125.57 GiB used: 0 KiB (0.0%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
  System Temperatures: cpu: 35.0 C mobo: 28.0 C
  Processes: 382 Uptime: 14m wakeups: 0 Memory: total: 128 GiB note: est.
  available: 125.57 GiB used: 4.96 GiB (4.0%) Init: systemd v: 254
  Packages: pm: pacman pkgs: 1670 libs: 434 tools: pamac,paru Shell: Bash
  v: 5.2.21 running-in: terminator inxi: 3.3.31
Garuda (2.6.19-2):
  System install date:     2023-10-30
  Last full system update: 2023-12-01
It’s just a warning, and there should be nothing to be worried about.
I see recently this commit changed from 2.1.2-3 (your installed version) to an empty pkgver-1 (I guess this was a mistake in the recent new CI improvements).
Then here from empty pkgver-1 to 2.1.2-1 → so the mismatch.
But there was no content change in both…
If you would like to stop seeing that message you can probably just reinstall the package.
