"warnig" when updating
Hi everyone, this is my first topic and I hope to be as clear as possible.
when I update my system, I always get these warnings:
WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
I would like to understand how to solve the problem, thank you very much to whoever will help me.
I have attached the output of the garuda-inxi command.
Kernel: 6.6.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9bfdd030-1f2b-4093-8a17-2b4630d976e5 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: HP product: HP Laptop 15-dw1xxx v: Type1ProductConfigId
Mobo: HP model: 85F2 v: 37.29 serial: <superuser required> UEFI: Insyde
v: F.53 date: 10/15/2021
ID-1: BAT1 charge: 35.4 Wh (100.9%) condition: 35.1/41.0 Wh (85.6%)
volts: 12.7 min: 11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xF8
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3050 high: 4537 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 4426 2: 4537 3: 4300
4: 400 5: 1299 6: 957 7: 4298 8: 4190 bogomips: 36799
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
Device-2: NVIDIA GM108M [GeForce MX130] vendor: Hewlett-Packard
status: current (as of 2023-10; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:174d
class-ID: 0302
Device-3: IMC Networks HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 13d3:56c9
Monitor-1: eDP-1 model: AU Optronics 0x61ed built: 2018 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
device-ID: 8086:9b41 memory: 7.39 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:9b41 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce MX130 driver: nvidia v: 545.29.06
device-ID: 10de:174d surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
API: ALSA v: k6.6.4-zen1-1-zen status: kernel-api tools: N/A
lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:5 chip-ID: 0bda:b00a
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 585 GiB used: 38.1 GiB (6.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
ID-2: /dev/sdb maj-min: 8:16 vendor: SSSTC model: CV8-8E128-HP
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: V881 scheme: GPT
ID-1: / raw-size: 357.06 GiB size: 357.06 GiB (100.00%)
used: 38.09 GiB (10.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 357.06 GiB size: 357.06 GiB (100.00%)
ID-4: /var/log raw-size: 357.06 GiB size: 357.06 GiB (100.00%)
ID-5: /var/tmp raw-size: 357.06 GiB size: 357.06 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.56 GiB used: 512 KiB (0.0%) priority: 100
System Temperatures: cpu: 81.0 C pch: 52.0 C mobo: N/A
Processes: 265 Uptime: 12m wakeups: 0 Memory: total: 8 GiB
available: 7.56 GiB used: 3.15 GiB (41.6%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: pm: dpkg
pkgs: 0 pm: pacman pkgs: 1371 libs: 405 tools: octopi,paru,yay Shell: fish
v: 3.6.2 default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-10-21
Last full system update: 2023-12-06
Welcome aboard, as for those messages just means you don’t have those components. You can just ignore those messages.
okay thank you very much!!
Those are firmware modules for old, mostly outdated or “odd” hardware that the kernel no longer includes. Appropriate drivers can be installed for them if you happen to need them. Occasionally someone does. Additionally, if the warnings bug you too much, there is an AUR pkg to suppress their output. :smiley:
Sometimes it’s nice to know why something, especially a warning message, is given. :smiley:
