Hi there, so I was playing around with my noise cancellation in PulseAudio Arch wiki and I succeeded in it. But the issue now is that I have three entries for each device in my audio dropdown and it's getting kind of messy. Is there any way to set the speakers to one default and remove other noise-canceled options (for the speakers), I need it for the mics only.
╰─λ inxi -Faz
System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=873c951f-daf4-4fad-aecc-0961323840e3 rw
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Micro-Star product: GF63 Thin 10SC v: REV:1.0 serial: <superuser required> Chassis: type: 10
Mobo: Micro-Star model: MS-16R5 v: REV:1.0 serial: <superuser required> UEFI: American Megatrends v: E16R5IMS.104
date: 08/30/2021
Battery: ID-1: BAT1 charge: 25.5 Wh (59.9%) condition: 42.6/51.3 Wh (83.0%) volts: 12.0 min: 11.4 model: MSI BIF0_9
type: Li-ion serial: N/A status: Unknown
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake family: 6 model-id: A5 (165)
stepping: 2 microcode: EA cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 4372 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 4372 2: 4520 3: 4428 4: 4516 5: 4526 6: 4382 7: 4573
8: 4599 9: 4594 10: 4581 11: 4367 12: 4570
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm
bus-ID: 02:00.0 chip-ID: 10de:1f9d class-ID: 0302
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting unloaded: nvidia
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169 v: kernel
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
Drives: Local Storage: total: 1.14 TiB used: 370.11 GiB (31.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3256B-AI1 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: EDFK0S03 temp: 44.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
Partition: ID-1: / raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 48.59 GiB (48.5%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%) used: 27.9 MiB (9.4%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 48.59 GiB (48.5%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /var/log raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 48.59 GiB (48.5%) fs: btrfs
ID-5: /var/tmp raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 48.59 GiB (48.5%) fs: btrfs
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 64.0 C pch: 51.0 C mobo: N/A
Info: Processes: 363 Uptime: 24m wakeups: 1 Memory: 7.59 GiB used: 2.98 GiB (39.3%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1631 lib: 501 Shell: fish v: 3.3.1 default: Bash v: 5.1.12
running-in: konsole inxi: 3.3.09
