I believe you misunderstood. When I wake my computer I see that the wifi powers back on (from being powered off during sleep) and reconnects to the network as it is supposed to do and this is not the problem. The problem only happens for me if I manually turn off wifi myself by clicking the checkbox in the tray menu of Plasma.
Try this: Unplug the one ethernet cable you have plugged in (all of them if you have more than one) and only use the computer on wireless and see if that helps. It's a short in the dark since you're not using an ethernet adapter but why not try it?
Mine was able to wake up this morning so it looks like I've prevented the issue. I'll post if it happens again.
I have no ethernet connected at all. My desktop is using wireless at all times. I figured one more thing though - seems like it is not even about sleeping for me. It fails to come back from the screen being turned off as a screen saver option. Meaning - i turned off sleep, but just left turn screen off after 10 min inactivity and it fails to wake the screen up. I just updated the system again - not sure if any fixes flow in so'ill retest this again
I just noticed this issue with an old touch screen POS computer I'm playing around with. I can use the brightness down button on the computer to turn the screen all the way off and then it won't go back on/up. The only way to get the screen to come back on without restarting is to sleep the computer (using the power button) and then waking it.
I just tested the "screen off only" after full system update (garuda-update) - it worked. Now will test the sleep.
I've been having this issue for a while. I rarely put it to sleep mode so haven't bothered to dig in deeper. My WiFi is on.
But if there's a power outage; I generally have to do a hard reboot on wake-up.
Kernel: 6.4.2-x64v2-xanmod1-3 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw rootflags=subvol=@
loglevel=3 quiet intel_iommu=on iommu=pt ibt=off
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 42.5 Wh (100.0%) condition: 42.5/58.8 Wh (72.3%)
volts: 16.5 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3600 high: 3603 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3601 2: 3600 3: 3600
4: 3600 5: 3600 6: 3603 7: 3600 8: 3600 9: 3600 10: 3601 11: 3600 12: 3600
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 535.54.03
alternate: nvidiafb,nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-2 empty: DP-1 bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 15360x8640 s-dpi: 96
s-size: 4053x2280mm (159.57x89.76") s-diag: 4650mm (183.08")
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled model: AU Optronics 0x82ed
built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 394mm (15.5") ratio: 16:9 modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_cnl
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.4.2-x64v2-xanmod1-3 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 3.19 TiB used: 1.34 TiB (42.0%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 51.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 24.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 500.52 GiB (27.0%)
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
used: 500.52 GiB (27.0%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-1: swap-1 type: zram size: 15.45 GiB used: 126.8 MiB (0.8%)
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:4
System Temperatures: cpu: 68.0 C pch: 64.0 C mobo: N/A gpu: nvidia
temp: 62 C
Processes: 375 Uptime: 5h 24m wakeups: 1 Memory: available: 15.45 GiB
used: 6.34 GiB (41.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 alt: 11/12 clang: 15.0.7 Packages:
pm: pacman pkgs: 2131 libs: 560 tools: octopi,pamac,paru pm: appimage
pkgs: 0 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.27
System install date: 2021-11-24
Last full system update: 2023-07-10 ↻
After the latest full system update i was able to wake my system up from sleep - it sat in sleep overnight and came back - no problem. But it seems to be having problems going into sleep mode automatically. I had to force it. This is still better though even with the manual workaround
Well, it didn't come back from forced sleep again. No updates applied. The machine starts, but the screens are not coming up....
I'm curious if some of the apps that i have running affect the behavior... will continue to test to find patterns
may want to check the motherboard's BIOS power management settings to ensure they are set to be correctly compatible (S3 for power on sleep-S4 or 5 for hibernate) and not to 'auto'.
