Vscode or Vscodium unable to OPEN
After a fresh install of Garuda MOKKA, i installed visual-studio-code-bin, code and vscodium each after failed to render. It shows a blank window then prompts to close, wait or repoen.
Nothing fixes the issue.
Image of the blank window and prompt -
i have installed electron in case but no luck. Chromium renders fine. Please help.
    root=UUID=7fe30a13-9470-4e79-857e-9a79683aeb95 rw rootflags=subvol=@
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Laptop System: Acer product: Aspire A715-42G v: V1.08
  Mobo: LN model: Azalea_CAS v: V1.08 serial: <superuser required>
    part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.08
    date: 09/15/2021
  ID-1: BAT1 charge: 13.3 Wh (71.1%) condition: 18.7/47.8 Wh (39.2%)
    volts: 12.7 min: 11.2 model: LGC AP18C8K type: Li-ion serial: <filter>
    status: charging
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
    microcode: 0x8608108
    desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1113 min/max: 400/4056 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1113 2: 1113 3: 1113
    4: 1113 5: 1113 6: 1113 7: 1113 8: 1113 9: 1113 10: 1113 11: 1113 12: 1113
    bogomips: 50306
Your garuda-inxi seems to be truncated.
Short test with vscodium and visual-studio-code-bin on Garuda Mokka (x11 + wayland) in a VM: no issues.
Did you reboot after the installation? What happens when you start the stuff via terminal, any error messages visible in the terminal?
Did you also install the .net runtime and SDK?
See .NET on Arch
i have mokka on my metal machine and installed code over the terminal.
Same Kernel and did try also run code in X11.
i dont have any issue both are working and i dont have any error code in the terminal.
Did you started VS Code over the Terminal ? Is there some error message?
Well, i posted this yesterday, i cold booted now, and code works. Even all version works. Well doesn’t know how
did you install code directly after the reboot from the install? without updating first and reboot and then install vs code =)
No. i did reboot , updated my system then installed vscode. However it’s fixed after a cold boot
