Is there a command line option for apps in KDE to enable or disable VRR per app?
Since you generally ignore the template, read it here again:
Missing information requested in the template may result in not receiving assistance
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
in the body of the post (not linked externally, or collapsed with the “hide details” feature)- Format terminal output (including your
) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
Without garuda-inxi this request will be moved to 412 Precondition Failed
Do as nepti said,
But answer to your question is yes but via GUI,
Settings > Window management > Windows rule > Add new rule > Add property > Adaptive sync
Fill in the Name of rule and the app you want to apply the rule to.
