Absolutely not! Take your time, I’m just going to be checking on the volunteer tasks to make sure things are still on track and nobody lost interest ![]()
There’ll probably be another ISO refresh as soon as it’s ready. Another (very rare) garuda-hardware-tool bug snuck its way into today’s ISO.
I couldn´t help myself. I started translating to Swedish. But I have no prestige in this so if anybody wants it I can back off. @TNE
I made an edit to the original post, sorry. I’ve been set back with some hardware issues but I’m still trying to get the mic set up and I do plan on recording it as soon as that’s sorted out, which should be soon.
All good! Excited to hear!
Going to be away until the the 25th, so wanted to share the progress so far:
- The background is a placeholder.
- I made it a point not to reinvent the wheel, but to adapt what we had to the recent design trends set forth by the new website, start page and flagship editions.
- This is the opportunity to change the wording or order or to add more slides in case there’s something I described completely wrong or there’s another aspect I should highlight. I did some modifications on the existing slide’s wording while trying to preserve the overall meanings. The only addition I made is the slide about Firedragon.
Eager to hear the team’s feedback!
I think all of the garuda gamer features were absorbed into rani as well ![]()
Will remove and expand more about Rani. On that note I’m wondering, is the setup assistant going to stay relevant for long? Since most if not all of the software is also in Rani?
Honestly, the Setup Assistant’s software selection screen could go eventually if @dr460nf1r3 wants to implement it in Rani instead.
The Setup Assistant itself will likely stay though, because its main purpose is to update the system on first boot, detect if NVIDIA drivers are needed and prompt to install and do anything else in the future that might need to be done after the installation. It is coded to automatically restart itself after a system update too, in case it is updated. In theory, Rani could do all those things, but the Setup Assistant is unique in the way that it is a native application, meaning any electron or GPU bugs will not affect it.
@SGS can we give some kind of forum reward (maybe text next to the name?) for the excellent translation work to Swedish @Jernvrede has been doing? ![]()
Also LOOK @slash did an AMAZING job voice acting the installation guide video!
Hahaha… Although as a translator I must point out that “professional” means I´m getting paid… No money changed hands. ![]()
My Englisch is bad, and for me is professionell same like very good work.
Tell me a better “Name” for that.
@TNE Also for the video worker ![]()
No worries. Professional = good work, is common in Sweden too. I would be fine with “Swedish translator”. ![]()
slash
Garuda Voice Actor
Garuda Synchronsprecher
Just listened to the whole thing. Truly a professional job @slash and what a gift to the community and new users! And @TNE also amazing job on the script, the screen recording and the editing.
The question has come up whether it would be possible to serve a different version of the slideshow (different accent colors for the background), and possibly a different interface color for Calamares on the left, for each of the different editions. Or would that be over the top?
Complicated and probably not worth the effort. This is baked into Calamares settings, if I recall correctly.
@dr460nf1r3 ok I kind of thought that
as we have many d,e’s with many color variations. Do you have a color palette that would fit them all.
for the main background for sddm, then each slide could represent them all.
Iv,e made some arkwork but they do not fit by color ![]()
