Hello dear Garuda Team and everyone reading this. I use Garuda Linux KDE Dragonized and since the changes around pipewire and wireplumber my Garuda/KDE (idk which is responsible for this kind of issue) does not save my volume levels. So, for example, my headset volume is at 30% when I shut down my PC, and when I boot it again, it is at 74% again. Always. This is not a big problem, but it still annoys me, because I use a lot of different audio devices and microphones, and the gain of the microphones are also set to 74% everytime. Is there any solution to this problem?
I found this thread on the forum, but none of the suggested fixes worked for me, so I thought opening a new one specifiying the problem would be useful: Garuda is not saving volume levels
my inxi -Faz:
λ inxi -Faz
System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=6bf2fd60-5bcf-49a1-8f0a-55b3687cb794
systemd.unified_cgroup_hierarchy=1 resume=UUID=11eb62e4-36a7-43bd-a30b-df8ffca3446f loglevel=3
Desktop: KDE Plasma 5.23.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: PRIME B350-PLUS v: Rev X.0x serial:
UEFI: American Megatrends v: 0902 date: 09/08/2017
Battery: ID-1: hidpp_battery_0 charge: 48% condition: N/A volts: 3.8 min: N/A
model: Logitech G502 LIGHTSPEED Wireless Gaming Mouse type: N/A serial:
status: Discharging
CPU: Info: 6-Core model: AMD Ryzen 5 1600 bits: 64 type: MT MCP arch: Zen family: 17 (23)
model-id: 1 stepping: 1 microcode: 8001129 cache: L1: 576 KiB L2: 3 MiB L3: 16 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 91015
Speed: 3620 MHz min/max: 1550/3800 MHz boost: disabled Core speeds (MHz): 1: 3620 2: 3619
3: 3538 4: 3644 5: 3441 6: 3652 7: 3667 8: 3470 9: 3765 10: 3533 11: 3471 12: 3707
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] vendor: Gigabyte driver: amdgpu
v: kernel bus-ID: 24:00.0 chip-ID: 1002:73df class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1080 s-dpi: 96 s-size: 1185x285mm (46.7x11.2") s-diag: 1219mm (48")
Monitor-1: DisplayPort-1 res: 2560x1080 hz: 60 dpi: 81 size: 798x334mm (31.4x13.1")
diag: 865mm (34.1")
Monitor-2: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
diag: 547mm (21.5")
OpenGL:
renderer: AMD Radeon RX 6700 XT (NAVY_FLOUNDER DRM 3.42.0 5.15.5-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
Audio: Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT] driver: snd_hda_intel
v: kernel bus-ID: 24:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 26:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Realtek USB2.0 Microphone type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-2:3 chip-ID: 0bda:4937 class-ID: 0300 serial:
Device-4: SteelSeries ApS SteelSeries Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-4.1:3 chip-ID: 1038:12ad class-ID: 0300
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK PRIME B450M-A
driver: r8169 v: kernel port: f000 bus-ID: 1e:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp30s0 state: up speed: 1000 Mbps duplex: full mac:
IF-ID-1: anbox0 state: down mac:
Any ideas are appreciated!
