hi ,after update when my virtualbox fullsccreen not show my os show very lightly page after quit as fullscreen show my os.thanks
Hi there, welcome.
Could you please provide (as per topic template...) the output of inxi -Faz
as text, with ~~~ before and after the text block for readability/formatting?
In addition to that, you should try to understand what changed with the update.
If it was executed today, this could be with:
cat /var/log/pacman.log | grep 2021-10-27 | egrep -i 'installed|upgraded'
For example I recently upgraded:
[2021-10-25T07:22:26+0200] [ALPM] upgraded virtualbox-host-dkms (6.1.28-2 -> 6.1.28-3)
[2021-10-25T07:22:27+0200] [ALPM] upgraded virtualbox (6.1.28-2 -> 6.1.28-3)
[2021-10-25T07:22:27+0200] [ALPM] upgraded virtualbox-ext-vnc (6.1.28-2 -> 6.1.28-3)
[2021-10-25T07:22:27+0200] [ALPM] upgraded virtualbox-sdk (6.1.28-2 -> 6.1.28-3)
And this new version might have some different behaviour (I don't use VirtualBox much, you could search online)
thanks,
[2021-10-25T13:51:55+0330] [ALPM] upgraded virtualbox-host-dkms (6.1.26-1 -> 6.1.28-3)
[2021-10-25T13:51:57+0330] [ALPM] upgraded virtualbox (6.1.26-1 -> 6.1.28-3)
In which operating system does Virtualbox run and which operating system is not displayed correctly at full screen size?
You do not post the inxi -Faz.
I think there is somewhat language barrier and I am unable to fully understand what do you mean.
You can post in your native language in #languages category.
