VirtualBox secure boot kernel errors fix
I delayed running VirtualBox past year, because I thought I need to sign some kernel modules and was not a priority at the time.
Gives error: Kernel Driver Not Installed (rc=xxxx)
    root=UUID=4e384f16-0b74-4432-bb6f-69659831f5f9 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
    wm: kwin_x11 tools: avail: swaylock vt: 2 dm: SDDM Distro: Garuda
  Type: Desktop Mobo: ASUSTeK model: PRIME B450M-A v: Rev X.0x
    UEFI: American Megatrends v: 4604 date: 03/22/2024
  Info: model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
    L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 2904 high: 3727 min/max: 2200/4148 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3000
    3: 2200 4: 2855 5: 2873 6: 3727 7: 3520 8: 2930 9: 3119 10: 2200 11: 3516
    12: 2921 13: 2200 14: 3660 15: 3350 16: 2200 bogomips: 95816
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: ASUSTeK
    active: DP-1,DP-3 empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 0b:00.0
    chip-ID: 1002:73ff class-ID: 0300
  Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
    s-diag: 1064mm (41.9")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right
    model: Dell U2412M serial: <filter> built: 2011 res: 1920x1200 hz: 60
    dpi: 94 gamma: 1.2 size: 518x324mm (20.39x12.76") diag: 611mm (24.1")
    ratio: 16:10 modes: max: 1920x1200 min: 720x400
  Monitor-2: DP-3 mapped: DisplayPort-2 pos: left model: Dell U2412M
    serial: <filter> built: 2011 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (radeonsi navi23
    LLVM 17.0.6 DRM 3.57 6.9.7-zen1-1-zen) device-ID: 1002:73ff
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 24.1.2-arch1.1
    device-ID: 1002:73ff surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.2-arch1.1 (LLVM
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
    bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: C-Media CM6631A Audio Processor
    lanes: 1 mode: 2.0 bus-ID: 1-2:2 chip-ID: 0d8c:0004 class-ID: 0300
  API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api
  Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 08:00.0 chip-ID: 10ec:8168
  Device-2: Dell Alienware AW620m Wireless Gaming mouse Dongle
    driver: hid-generic,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 3-3:2 chip-ID: 413c:302d class-ID: 0300
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4
  Local Storage: total: 3.42 TiB used: 530.26 GiB (15.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
    model: SPCC M.2 PCIe SSD size: 476.94 GiB block-size: physical: 512 B
    fw-rev: H211011a temp: 40.9 C scheme: GPT
    model: WD20EARX-00PASB0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
    scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SUV400S37240G
    size: 223.57 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 96R9 scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 model: USB DISK 2.0 size: 7.46 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
    used: 242.86 GiB (51.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 27.6 MiB (9.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: zram size: 15.53 GiB used: 768 KiB (0.0%) priority: 100
  System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
    mem: 34.0 C
  Memory: total: 16 GiB available: 15.53 GiB used: 10.77 GiB (69.4%)
  Processes: 349 Power: uptime: 37m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,upowerd
  Packages: 1963 pm: pacman pkgs: 1955 libs: 538 tools: pacseek,paru,yay
    pm: flatpak pkgs: 8 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
    default: Bash v: 5.2.26 running-in: kitty inxi: 3.3.35
  System install date:     2023-12-25
  Last full system update: 2024-07-06
  Is partially upgraded:   Yes
The fix:
Just needed to enable AMD-V from bios and its called Core/Cpu virtualization on Asus Mobo.
VirtualBox runs on latest zen kernel with no issues.
