Virtual keyboards no longer work
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=cf4a4272-7f5a-48f5-a1ba-538597770f13 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop Mobo: ASRock model: X570S PG Riptide
serial: UEFI: American Megatrends v: P1.50
date: 02/23/2022
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 616 high: 2994 min/max: 400/4464 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 2994 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400
bogomips: 93427
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: HDMI-A-1 empty: DP-1,DP-2 bus-ID: 08:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 21.0 C
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.1
renoir LLVM 17.0.6 DRM 3.57 6.8.1-zen1-1-zen) device-ID: 1002:1638
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.3-arch1.1
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Realtek Killer E3000 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 03:00.0
chip-ID: 10ec:3000 class-ID: 0200
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac:
IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
Local Storage: total: 931.51 GiB used: 499.69 GiB (53.6%)
lanes: 4 tech: SSD serial: fw-rev: 5B2QGXA7 temp: 19.9 C
used: 499.69 GiB (53.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 14.99 GiB used: 234 MiB (1.5%) priority: 100
System Temperatures: cpu: 26.2 C mobo: N/A gpu: amdgpu temp: 21.0 C
Memory: total: 16 GiB note: est. available: 14.99 GiB used: 2.88 GiB (19.2%)
Processes: 275 Power: uptime: 3h 40m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.96 GiB services: org_kde_powerdevil,
Packages: 1439 pm: pacman pkgs: 1428 libs: 400 tools: octopi,paru
pm: flatpak pkgs: 11 Compilers: gcc: 13.2.1 Shell: garuda-inxi default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2022-10-07
Last full system update: 2024-03-20
After the upgrade to QT6 the virtual keyboards no longer work.
Onboard stopped working. Installed qt6-virtualkeyboard - that did not work either. Installed Maliit and set it as a virtual keyboard in the system settings - that did not work either. I need a virtual keyboard - Onboard is great.
Issues on
https://bugs.launchpad.net/onboard/+bugs?orderby=importance&start=0
Is it the same if you select x11 in the login screen?
Kernel: 6.8.1-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=fc62cc44-07ab-497b-ac89-15704c290993 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 systemd.show_status=auto
amd_pstate=active ibt=off
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Sorry, I don’t know what you mean. I am not very technical with linux.
Can I go back to X11 ? If so, how can I do that ?
Onboard works on KDE wayland (screenshot), but you can try also X11, change on login screen.
Please can you explain how I change to x11 at login. Thanks. The system just scrolls past quite quickly at login.
You can change the session type on the login screen by clicking the current session type and changing it.
If you are automatically logging in and do not normally see a login screen, you can change this in KDE’s System Settings instead. Search for “SDDM” , click on “Login Screen (SDDM)”, click on the “Behavior…” button up top. You’ll see session options there for your account that you automatically log in with.
OK I will try that. Actually, Onboard does not work after the update. When you press a letter - it opens a box with various versions of the letter - but it does not enter the letter into text.
I include a pic :
I switched to X11 and Onboard works OK.
Thanks for your help with this.
I will try Wayland again after a couple of updates.
Off topic, i do have garuda with gnome, but i wasnt able to find anything working under gnome, im speaking anout virtual keyboard
Can you guys propose anything?
There is a list here with quite a few options: https://wiki.archlinux.org/title/List_of_applications/Utilities#On-screen_keyboards
If you are using Wayland, squeekboard looks pretty good and is directly supported by the Gnome project.
sudo pacman -S squeekboard
thank you @BluishHumility i will check it
So, Onboard can’t be converted to run under Wayland ?
I wouldn’t hold your breath; it looks like the last release for Onboard was in 2017.
There is an issue open for it here: Bug #1826742 “onboard does not work with wayland” : Bugs : Onboard
Every couple years someone chimes in on the bug report to say, “It’s still not working.”
It looks like no one has commented from 2024 yet, if you’d like to be that guy. :wink:
Yes, I posted a request for someone to fix Onboard for Wayland.
Onboard is the only OSK that I really like and usually use every day. Back to X for me, as I really can’t live without onboard, (at least on my HTPC computers). Too bad, I was planning on giving wayland a fair shot.
