I have a question mostly about Aesthetics. I installed the qtile version so I'm not sure if this is true on other versions.
When I start vim to edit a python file, I get this nice highlighting effect that doesn't happen when I create a .vimrc file. I am trying to figure out where that hightlighting is coming from but have been unable to find it any of the default vimrc files.
I have looked at /etc/vimrc and /usr/share/vim/vimfiles/archlinux.vim, but I haven't found that Python highlighting config anywhere.
:version
system file: "/etc/vimrc"
user file: "$HOME/.vimrc" --does not currently exist
2nd user file: "~/.vim/vimrc"
defaults file: "$VIMRUNTIME/defaults.vim
system menu file: "$VIMRUNTIME/menu.vim"
fall-back for $VIM: "/usr/share/vim"
System: Kernel: 5.14.9-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=7bda3b14-f8fd-4850-bc94-366cbe221f09 rw
Desktop: Qtile 0.18.1 wm: LG3D vt: 1 dm: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20N20028US v: ThinkPad T490 serial: <filter> Chassis: type: 10
Mobo: LENOVO model: 20N20028US v: SDK0J40697 WIN serial: <filter> UEFI: LENOVO v: N2IET90W (1.68 ) date: 07/06/2020
Battery: ID-1: BAT0 charge: 48.9 Wh (100.0%) condition: 48.9/50.5 Wh (97.0%) volts: 12.8 min: 11.5 model: SMP 02DL008
type: Li-poly serial: <filter> status: Full cycles: 5
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: Discharging
CPU: Info: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: C (12) microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31999
Speed: 4316 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 4316 2: 4244 3: 4429 4: 4158 5: 4202 6: 4271 7: 4462
8: 4251
Graphics: Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Lite-On Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:3 chip-ID: 04ca:7070 class-ID: 0e02
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-60eb0 driver: loaded: intel unloaded: modesetting
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1013x570mm (39.9x22.4") s-diag: 1162mm (45.8")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
Monitor-2: DP2-2 res: 1920x1080 hz: 60 dpi: 79 size: 620x340mm (24.4x13.4") diag: 707mm (27.8")
Monitor-3: DP2-3-8 res: 1920x1080 hz: 60 dpi: 79 size: 620x340mm (24.4x13.4") diag: 707mm (27.8")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
Device-2: GN Netcom Jabra PRO 9470 type: USB driver: jabra,snd-usb-audio,usbhid bus-ID: 1-2.2:5 chip-ID: 0b0e:1042
Device-3: Lenovo ThinkPad USB-C Dock Gen2 USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-2.3.3.2:10 chip-ID: 17ef:a396 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.14.9-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel port: 3000 bus-ID: 00:14.3
chip-ID: 8086:9df0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel port: efa0 bus-ID: 00:1f.6
chip-ID: 8086:15be class-ID: 0200
Device-3: Lenovo USB-C Dock Ethernet type: USB driver: r8152 bus-ID: 2-2.1:4 chip-ID: 17ef:a387 class-ID: 0000
IF: enp0s20f0u2u1 state: down mac: <filter>
Drives: Local Storage: total: 357.98 GiB used: 12.09 GiB (3.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HBHQ-000L7 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 4M2QEXH7 temp: 22.9 C
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: Flash Drive FIT size: 119.51 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 1100 scheme: GPT
Partition: ID-1: / raw-size: 119.25 GiB size: 119.25 GiB (100.00%) used: 12.09 GiB (10.1%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 119.25 GiB size: 119.25 GiB (100.00%) used: 12.09 GiB (10.1%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 119.25 GiB size: 119.25 GiB (100.00%) used: 12.09 GiB (10.1%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw-size: 119.25 GiB size: 119.25 GiB (100.00%) used: 12.09 GiB (10.1%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: zram size: 7.43 GiB used: 5.2 MiB (0.1%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3525
Info: Processes: 263 Uptime: 4h 16m wakeups: 31 Memory: 7.43 GiB used: 5.48 GiB (73.7%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1149 lib: 299 Shell: Zsh v: 5.8
running-in: alacritty inxi: 3.3.06
