Just copy and paste, it is pulse not plus
Nothing appeared , after that i rebooted and still not fixed
Please, answer and post garuda-inxi again.
Don't know about oss-emulator
Kernel: 6.3.1-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=231adbe5-cbff-46a0-a133-7b383848afc1 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706ICB_FA706ICB
Mobo: ASUSTeK model: FA706ICB v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FA706ICB.307 date: 12/28/2022
ID-1: BAT1 charge: 36.7 Wh (41.6%) condition: 88.3/90.2 Wh (97.9%)
volts: 15.0 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
microcode: 0x8600106
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 2618 high: 2900 min/max: 1400/4299 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2900 2: 2900
3: 2900 4: 1397 5: 2900 6: 2900 7: 1397 8: 2900 9: 1397 10: 2900 11: 2900
12: 2900 13: 2900 14: 2900 15: 2900 16: 2900 bogomips: 92628
Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: ASUSTeK
driver: nouveau v: kernel non-free: 530.xx+ status: current (as of 2023-05)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:25a2
Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
temp: 44.0 C
Device-3: Sonix USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 322e:202c
class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: amdgpu,modesetting,nouveau
alternate: fbdev,nv,vesa dri: radeonsi,nouveau gpu: amdgpu display-ID: :0
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0a11 built: 2021
res: 1920x1080 hz: 144 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon Graphics (renoir LLVM
15.0.7 DRM 3.52 6.3.1-zen2-1-zen) direct-render: Yes
bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.3.1-zen2-1-zen status: kernel-api with: aoss
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:2 chip-ID: 13d3:3563
Local Storage: total: 476.94 GiB used: 11.91 GiB (2.5%)
fw-rev: FXM7201Q temp: 43.9 C scheme: GPT
ID-1: / raw-size: 94 GiB size: 94 GiB (100.00%) used: 11.88 GiB (12.6%)
used: 30 MiB (11.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 94 GiB size: 94 GiB (100.00%)
used: 11.88 GiB (12.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 94 GiB size: 94 GiB (100.00%)
ID-5: /var/tmp raw-size: 94 GiB size: 94 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.18 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 6 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 52.5 C mobo: N/A gpu: amdgpu temp: 44.0 C
Fan Speeds (RPM): cpu: 3100
Processes: 339 Uptime: 9m wakeups: 340 Memory: available: 7.18 GiB
used: 2.39 GiB (33.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: 3448 pm: pacman pkgs: 1724
libs: 519 tools: octopi,paru pm: rpm pkgs: N/A note: see --rpm tools: dnf
inxi: 3.3.27
System install date: 2023-05-04
Last full system update: 2023-05-13
Try disabling hardware acceleration in your browser.
How to do that?
In settings / general / performance (although this depends on the browser).
I kindly ask you to be a bit more "active": search, try, don't just wait...
with: aoss type: oss-emulator
This is just a wild guess but could this aoss be the issue. After trying out filo
âs suggestion try uninstalling aoss.
pacman -Qs aoss
should tell you the name of packages that contain the name aoss.
I think this wild guess is spot onâto me it seems very likely this is the crux of the issue.
aoss
appears to be a wrapper script for using the ALSA/OSS compatibility library. I donât know much about it, but I know that OSS is an alternative to ALSA and when you install it you are supposed to blacklist ALSA modules and stuffâotherwise they will compete with each other and introduce conflicts. See here: Open Sound System - ArchWiki
Is OSS installed, or some version of it? Itâs an AUR package.
paru -Q | grep oss
Is the OSS service running?
systemctl status oss.service
I think you should try to get all that OSS/aoss
stuff off of your system and go back to straight Pipewire, then try to troubleshoot from there.
Laptop System: ASUSTeK product: ASUS TUF Gaming A17 FA706ICB_FA706ICB v: 1.0 serial: <superuser required> Mobo: ASUSTeK model: FA706ICB v: 1.0 serial: <superuser required> UEFI: American Megatrends v: FA706ICB.307 date: 12/28/2022
Is this a newly released CPU or NVidia card? How long has this model been manufactured?
If the answer is New, then try different kernels or just wait a bit longer for one that incorporates the new hardware.
