Vibrant-cli doesn't work
I'm following this tutorial on how to change saturation:
I had the following conversation with the terminal:
[[email protected] ~]$ xrandr | grep connected
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
HDMI1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
[[email protected] ~]$ xrandr | grep primary
[[email protected] ~]$ vibrant-cli
libvibrant version 1.0.2
Usage: vibrant-cli OUTPUT [SATURATION]
[[email protected] ~]$ pamac-manager
(pamac-manager:57764): Gdk-CRITICAL **: 17:08:23.320: gdk_window_set_cursor: assertion 'GDK_IS_WINDOW (window)' failed
[[email protected] ~]$ vibrant-cli eDP1
Cannot find output eDP1 in the list of supported outputs, it either does not exist or is not supported
[[email protected] ~]$ vibrant-cli eDP-1
Cannot find output eDP-1 in the list of supported outputs, it either does not exist or is not supported
[[email protected] ~]$ vibrant-cli eDP 1
Cannot find output eDP in the list of supported outputs, it either does not exist or is not supported
[[email protected] ~]$ vibrant-cli eDP1 1
[[email protected] ~]$ vibrant-cli eDP1 0
When the guy in the video runs "vibrant-cli OUTPUT [SATURATION]", it works perfectly fine. But for me it doesn't work for some reason. How do I solve this issue?
inxi -Faz
System:    Kernel: 5.10.60-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
           parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=8d05eb79-30ef-4c21-92f0-c8c7c8baee18 rw
           [email protected] quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
           Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0
Machine:   Type: Laptop System: Acer product: Aspire A315-56 v: V1.15 serial: <filter>
           Mobo: IL model: Sleepy_IL v: V1.15 serial: <filter> UEFI: Insyde v: 1.15 date: 07/13/2020
Battery:   ID-1: BAT1 charge: 47.6 Wh (100.0%) condition: 47.6/47.8 Wh (99.5%) volts: 12.5 min: 11.2 model: LGC AP18C8K
           type: Li-ion serial: N/A status: Full
CPU:       Info: Dual Core model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake family: 6 model-id: 7E (126)
           stepping: 5 microcode: A6 cache: L2: 4 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 9523
           Speed: 1179 MHz min/max: 400/1200 MHz Core speeds (MHz): 1: 1179 2: 1143 3: 1184 4: 1161
Graphics:  Device-1: Intel Iris Plus Graphics G1 vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
           chip-ID: 8086:8a56 class-ID: 0300
           Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-7:3 chip-ID: 0408:a061 class-ID: 0e02
           Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver: loaded: intel unloaded: modesetting
           alternate: fbdev,vesa display-ID: :0.0 screens: 1
           Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
           OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 21.2.1 direct render: Yes
Audio:     Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
           alternate: snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
           Sound Server-1: ALSA v: k5.10.60-1-lts running: yes
           Sound Server-4: PulseAudio v: 15.0 running: yes
           Sound Server-5: PipeWire v: 0.3.33 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
           v: kernel port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
           Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lite-On driver: ath10k_pci v: kernel
           port: 4000 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
           IF-ID-2: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Bluetooth: Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-10:4
           chip-ID: 04ca:3015 class-ID: e001
           Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
           address: <filter>
Drives:    Local Storage: total: 238.47 GiB used: 94.79 GiB (39.7%)
           ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: RBUSNS8154P3256GJ1 size: 238.47 GiB block-size:
           physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: E8FK12.3 temp: 45.9 C
Partition: ID-1: / raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 94.79 GiB (39.8%) fs: btrfs dev: /dev/nvme0n1p2
           maj-min: 259:2
           ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
           maj-min: 259:1
           ID-3: /home raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 94.79 GiB (39.8%) fs: btrfs dev: /dev/nvme0n1p2
           maj-min: 259:2
           ID-4: /var/log raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 94.79 GiB (39.8%) fs: btrfs
           ID-5: /var/tmp raw-size: 238.21 GiB size: 238.21 GiB (100.00%) used: 94.79 GiB (39.8%) fs: btrfs
           ID-1: swap-1 type: zram size: 7.56 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors:   System Temperatures: cpu: 27.8 C mobo: N/A
Info:      Processes: 259 Uptime: 23m wakeups: 2 Memory: 7.56 GiB used: 2.56 GiB (33.9%) Init: systemd v: 249 tool: systemctl
           Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1748 lib: 385 Shell: Bash v: 5.1.8
           running-in: xfce4-terminal inxi: 3.3.06
It seems pretty clear that the issue is this:
Are you sure it supports the intel driver? The project page only references AMD and nvidia.
You could try using the modesetting driver instead of the intel and see if there is any difference.
Compatibility
vibrant supports most modern GPUs.
AMD GPUs
  • Your card needs to be supported by the AMD Display Code kernel driver
NVIDIA GPUs
  • Currently only the NVIDIA proprietary driver is supported
  • Support is handled by libXNVCtrl, which should be bundled with most installations of the driver
Confirmed working
  • NVIDIA GeForce GTX 660
  • Radeon RX 5700 XT
  • Radeon RX 5600 XT
  • Radeon VII
  • Radeon RX Vega 56
  • Radeon RX 580
  • Radeon RX 470
  • Radeon R9 270
*dGPUs
(Mistake by Vibrant devs)
And yeah, as already mentioned,
Neither of these are supported. So, contact vibrant developers for help.
