Kernel: 5.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=904ce709-4fe2-4a30-bde7-34679644f277 rw [email protected]
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 info: latte-dock
Type: Desktop System: Dell product: XPS 8940 v: N/A
Mobo: Dell model: 0K3CM7 v: A00 serial: <superuser required> UEFI: Dell
v: 2.5.1 date: 03/29/2022
Info: model: 11th Gen Intel Core i7-11700 bits: 64 type: MT MCP
arch: Rocket Lake family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x50
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4800:4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 801 2: 801 3: 801 4: 801
5: 800 6: 801 7: 800 8: 800 9: 800 10: 800 11: 801 12: 800 13: 800
14: 801 15: 801 16: 800 bogomips: 79872
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: Dell
driver: i915 v: kernel ports: active: HDMI-A-2
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:4c8a
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-12:5 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: LED TV serial: <filter>
built: 2016 res: 1920x1080 hz: 60 dpi: 69 gamma: 1.2
size: 708x398mm (27.87x15.67") diag: 1321mm (52") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
OpenGL: renderer: Mesa Intel Graphics (RKL GT1) v: 4.6 Mesa 22.0.2
direct render: Yes
Device-1: Intel vendor: Dell driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f1c8 class-ID: 0403
Device-3: Corsair HS70 Pro Wireless Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:10 chip-ID: 1b1c:0a4f
Sound Server-1: ALSA v: k5.17.5-zen1-1-zen running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Rivet Networks driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:2600 class-ID: 0200
bus-ID: 1-14:7 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 60.81 GiB (12.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC711 NVMe 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 41002131 temp: 27.9 C scheme: GPT
used: 60.81 GiB (12.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 15.3 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 27.8 C pch: 38.0 C mobo: N/A
Fan Speeds (RPM): cpu: 786 fan-2: 1024
Processes: 346 Uptime: 49m wakeups: 0 Memory: 15.3 GiB
used: 2.85 GiB (18.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1427 lib: 371 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-05-04
Last full system update: 2022-05-06 ↻
