Hello.
arthur@hp2 in ~
λ garuda-inxi
Kernel: 5.16.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=c4c19518-b086-4a0d-86b1-6b98a7a5fc2e rw rootflags=subvol=@
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
v: 059A100000204610000020100 serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 1697 v: KBC Version 16.24
serial: <superuser required> BIOS: Hewlett-Packard v: F.44 date: 11/14/2011
ID-1: BAT0 charge: 35.4 Wh (100.0%) condition: 35.4/35.4 Wh (100.0%)
volts: 12.4 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Full
Info: model: AMD Athlon II P360 bits: 64 type: MCP arch: K10
family: 0x10 (16) model-id: 6 stepping: 3 microcode: 0x10000C8
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 256 KiB
desc: d-2x64 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
Speed (MHz): avg: 1250 high: 1700 min/max: 800/2300 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1700 2: 800
bogomips: 9177
Flags: ht lm nx pae sse sse2 sse3 sse4a svm
Type: spec_store_bypass status: Not affected
mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Device-1: AMD RS880M [Mobility Radeon HD 4225/4250] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu bus-ID: 01:05.0
chip-ID: 1002:9712 class-ID: 0300
Device-2: Alcor Micro HP Webcam-101 type: USB driver: uvcvideo
bus-ID: 2-2:2 chip-ID: 058f:a001 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: gnome-shell driver:
loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :1 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 270x203mm (10.6x8.0")
s-diag: 338mm (13.3")
Monitor-1: VGA-0 res: 1024x768 hz: 60
Monitor-2: LVDS res: 1024x768 hz: 60 dpi: 76 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
Device-1: AMD SBx00 Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Device-2: AMD RS880 HDMI Audio [Radeon HD 4200 Series]
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 01:05.1
chip-ID: 1002:970f class-ID: 0403
Sound Server-1: ALSA v: k5.16.5-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 2000 bus-ID: 02:00.0
Device-2: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: Hewlett-Packard U98Z062.12 802.11bgn driver: ath9k v: kernel
bus-ID: 03:00.0 chip-ID: 168c:002b class-ID: 0280
driver: btusb v: 0.8 bus-ID: 4-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 447.13 GiB used: 33.95 GiB (7.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
type: SSD serial: <filter> rev: 0101 scheme: MBR
ID-1: / raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
used: 33.95 GiB (7.6%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
ID-3: /var/log raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
ID-4: /var/tmp raw-size: 447.13 GiB size: 447.13 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.51 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.8 C mobo: 0.0 C
Processes: 238 Uptime: 1h 30m wakeups: 1 Memory: 7.51 GiB
used: 2.71 GiB (36.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1653 lib: 371 Shell: fish
v: 3.3.1 running-in: alacritty inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-01-16
Last full system update: 2022-02-03
arthur@hp2 in ~ took 2s
λ
And I used pacdiff for the first time. Results follow.
sudo pacdiff --find
[sudo] password for arthur:
==> pacnew file found for /etc/pacman.d/mirrorlist
:: (V)iew, (S)kip, (R)emove pacnew, (O)verwrite with pacnew, (Q)uit: [v/s/r/o/q] o
renamed '/etc/pacman.d/mirrorlist.pacnew' -> '/etc/pacman.d/mirrorlist'
==> pacnew file found for /etc/sudoers
renamed '/etc/sudoers.pacnew' -> '/etc/sudoers'
Then I ran garuda-update and got no merge warnings.
My question . Is this the right thimg to do? I am an arch newby btw
