Hi guys, total Garuda (and thus Arch) newbie here.
I've been distro hopping a LOT ever since I expressed dissatisfaction with Windows 11, version 22H2, and to an extent, Windows 10 as well. I've been hopping between Ubuntu (official) and Fedora (Nobara). Finally decided to give Garuda a shot, and I must say, I'm very impressed.
Enough of that though, I approach yalls with a question. Has anyone gotten AMD AMF encoders to work on their copies of OBS? If so, can you please detail how you did it? Currently I'm using GStreamer's VAAPI plugin and I'm still not satisfied, having fairly poor quality at 25 Mbps bitrate (and I do not know how to add CQP to the encoder settings, as the window still insists on inputting bitrate despite selecting CQP).
garuda-inxi incoming!
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=137f0cc6-ef53-4347-883c-dfbc08ad2800 rw rootflags=subvol=@
resume=UUID=79b5222c-979f-4715-ad36-c660f42ebf3b loglevel=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4403
date: 04/28/2022
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3838 high: 4850 min/max: 2200/4850 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3648 2: 3800
3: 3601 4: 3800 5: 3865 6: 3800 7: 3800 8: 3800 9: 4850 10: 3800 11: 3800
12: 3851 13: 3601 14: 3800 15: 3800 16: 3800 bogomips: 121604
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
active: DP-1,DP-2,HDMI-A-1 empty: DP-3 bus-ID: 07:00.0 chip-ID: 1002:73bf
Device-2: Logitech CrystalCam type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 5-3.3:4 chip-ID: 046d:0894 class-ID: 0102 serial: <filter>
Screen-1: 0 s-res: 7040x1440 s-dpi: 96 s-size: 1862x381mm (73.31x15.00")
s-diag: 1901mm (74.83")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,center
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2021 res: 2560x1440
dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
Monitor-2: DP-2 mapped: DisplayPort-1 pos: right model: Samsung LC27G5xT
serial: <filter> built: 2021 res: 2560x1440 hz: 144 dpi: 93 gamma: 1.2
size: 698x393mm (27.48x15.47") diag: 685mm (27") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-3: HDMI-A-1 mapped: HDMI-A-0 pos: left model: Acer XZ320Q X
serial: <filter> built: 2020 res: 1920x1080 dpi: 70 gamma: 1.2
size: 698x392mm (27.48x15.43") diag: 801mm (31.5") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 14.0.6 DRM 3.48 6.0.8-zen1-1-zen) direct render: Yes
bus-ID: 1-1:2 gen: 4 chip-ID: 046d:0aaa class-ID: 0300 speed: 16 GT/s
serial: <filter> lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:ab28
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Logitech G PRO X Gaming Headset type: USB
Device-4: Logitech Blue Microphones type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2:5 chip-ID: 046d:0ab7
Device-5: Logitech CrystalCam type: USB driver: snd-usb-audio,uvcvideo
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:4
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 3.88 TiB used: 894.75 GiB (22.5%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 model: PCIe SSD size: 953.87 GiB
type: SSD serial: <filter> rev: ECFM22.6 temp: 33.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
type: SSD serial: <filter> rev: 0107 scheme: GPT
ID-1: / raw-size: 188.89 GiB size: 188.89 GiB (100.00%)
used: 28.55 GiB (15.1%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 608 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 188.89 GiB size: 188.89 GiB (100.00%)
ID-4: /var/log raw-size: 188.89 GiB size: 188.89 GiB (100.00%)
ID-5: /var/tmp raw-size: 188.89 GiB size: 188.89 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.25 GiB used: 1.5 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 58.1 C mobo: N/A gpu: amdgpu temp: 52.0 C
mem: 56.0 C
Processes: 425 Uptime: 39m wakeups: 0 Memory: 31.25 GiB
used: 7.26 GiB (23.2%) Init: systemd v: 252 default: graphical
pkgs: 1985 libs: 557 tools: gnome-software,octopi,pamac,paru Shell: fish
v: 3.5.1 default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-11
Last full system update: 2022-11-12
Looking forward to joining this community, and discussing with yalls!
