Hi, im trying to use a ramdisk mounted on /mnt/ramdisk with bcache (probably is the wrong way) but it gives me an error saying that the mountpoint is a folder . How can i correctly set a ramdisk with bcache? Thanks for the help
Could this help?
https://wiki.archlinux.org/title/Bcache
Edit: sorry, I see no references to ramdisk...
Thanks for the help but isnt the usage of bcache the problem. I need to make a partition in the ram as a normal disk to use bcache. At the moment i can only use tmpfs and that isnt compatible with bcache (as far as i know)
