❯ inxi -Faz
Kernel: 5.15.3-2-cacule x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cacule
root=UUID=5b2b9a7e-a0aa-40d4-b82f-9d0b92912fe3 rw rootflags=subvol=@
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 info: latte-dock
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
Mobo: Dell model: 0D53F5 v: A00 serial: <superuser required> UEFI: Dell
v: 2.16.0 date: 08/18/2021
ID-1: BAT0 charge: 12.9 Wh (100.0%) condition: 12.9/41.4 Wh (31.1%)
volts: 17.0 min: 14.8 model: SMP DELL VN3N047 type: Li-ion serial: <filter>
status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
Info: model: Intel Core i5-7200U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check family: 6 model-id: 0x8E (142)
stepping: 9 microcode: 0xEA
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2178 high: 2553 min/max: 400/3100 scaling:
driver: intel_pstate governor: performance cores: 1: 2038 2: 2553 3: 2507
4: 1617 bogomips: 21623
Type: l1tf
Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
Radeon 520 Mobile]
vendor: Dell driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
chip-ID: 1002:6660 class-ID: 0380
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02 serial: <filter>
Display: wayland server: X.Org 1.21.1.4 compositor: kwin_wayland driver:
loaded: ati,intel,radeon unloaded: modesetting alternate: fbdev,vesa
display-ID: :1 screens: 1
s-diag: 414mm (16.3")
Monitor-1: XWAYLAND0 res: 1366x768 hz: 60 dpi: 102
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.3
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
Sound Server-1: ALSA v: k5.15.3-2-cacule running: yes
Sound Server-4: PipeWire v: 0.3.43 running: yes
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 02:00.0
chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-8:5
chip-ID: 0cf3:e009 class-ID: e001
Local Storage: total: 931.51 GiB used: 130.47 GiB (14.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 3D scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 14.57 GiB (14.6%)
used: 42.4 MiB (4.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 41.31 GiB (41.3%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 14.57 GiB (14.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.43 GiB used: 1.4 MiB (0.0%)
ID-2: swap-2 type: partition size: 6 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda11 maj-min: 8:11
System Temperatures: cpu: 52.0 C pch: 49.0 C mobo: 49.0 C gpu: radeon
temp: 43.0 C
Fan Speeds (RPM): cpu: 0
Processes: 272 Uptime: 12h 1m wakeups: 33 Memory: 11.43 GiB
used: 3.97 GiB (34.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1583 pacman: 1577 lib: 396 flatpak: 6
Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.11
When I plug in my iPhone, usbmuxd starts automatically, and my phone starts charging, but USB tethering and file transfer won’t work. So naturally, I would try replugging my iPhone; nothing would change, the phone charges but still no USB tethering and file transferring, and usbmuxd would still be running even after unplugging.
Then if I kill usbmuxd, everything starts working instantly.
Now, if I unplug my iPhone, usbmuxd would kill itself, and it starts automatically when I plug it in again.
It’s just the first time usbmuxd won’t work; you just have to kill it the first time, and everything starts working fine.
https://archlinux.org/packages/extra/x86_64/usbmuxd/
usbmuxd stands for “USB multiplexing daemon”. This daemon is in charge of multiplexing connections over USB to an iOS device.
So from what I know, it’s basically udev rule that lets you connect to your iPhone.
Everything was working fine some days back; the problem just started a few days ago.
I have a very similar issue in my Void Linux installation, and I had reported the issue a few days ago, which is still not fixed:
please have a look here: USB tethering not working, might be due to a bug in 'usbmux' package. · Issue #34458 · void-linux/void-packages · GitHub
It is a long thread, you could go through it for context, and by the end of the thread, I think we have narrowed it down to the actual issue, which I have posted here too, but the problem still remains unsolved.
We could report it to the package developer if this is the same issue.
Thank you.
