Kernel: 5.19.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3a439420-4cae-41a4-9b15-52bd3be85c41 rw rootflags=subvol=@
resume=UUID=594941bc-f076-4141-a1a9-1eac23ee7732 loglevel=3
Type: Laptop System: HP product: HP Laptop 15-di2xxx
Mobo: HP model: 86B3 v: 88.30 serial: <superuser required> UEFI: Insyde
v: F.36 date: 02/03/2021
ID-1: BAT1 charge: 34.2 Wh (100.3%) condition: 34.1/40.9 Wh (83.4%)
volts: 12.9 min: 11.3 model: Hewlett-Packard PABAS0241231 type: Li-ion
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP arch: skylake
note: check gen: core 10 family: 6 model-id: 0xA6 (166) stepping: 0
microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1515 high: 2100 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 950 2: 2100 3: 2100
4: 2100 5: 900 6: 2100 7: 973 8: 900 bogomips: 33599
Device-1: Intel Comet Lake UHD Graphics vendor: Hewlett-Packard
chip-ID: 8086:9bca class-ID: 0300
Device-2: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04f2:b67f class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 model: AU Optronics 0x38ed built: 2017 res: 1920x1080
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.19.6-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A modules: rtw88_8723de
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
chip-ID: 10ec:d723 class-ID: 0280
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 1.14 TiB used: 44.26 GiB (3.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: ADHA0102
temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: RTM2
ID-1: / raw-size: 230.17 GiB size: 230.17 GiB (100.00%) used: 41.27 GiB
(17.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 230.17 GiB size: 230.17 GiB (100.00%) used: 41.27
GiB (17.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 230.17 GiB size: 230.17 GiB (100.00%) used: 41.27
ID-5: /var/tmp raw-size: 230.17 GiB size: 230.17 GiB (100.00%) used: 41.27
ID-1: swap-1 type: zram size: 3.64 GiB used: 1.02 GiB (28.1%)
ID-2: swap-2 type: partition size: 8.01 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 64.0 C pch: 54.0 C mobo: N/A
Processes: 248 Uptime: 34m wakeups: 1 Memory: 3.64 GiB used: 2.7 GiB
(74.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pacman: 1492 lib: 422
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-09-01
Last full system update: 2022-09-02
So basically I wished to unflash the USB I used for installing Garuda. So I goggle a bit and found that following command will help-
df
sudo umount /dev/sdb1
sudo mkfs.ntfs /dev/sdb1
So I did all this. I don't know whether the USB got unflashed or not but instead it's now not being detected by the system. USB is not being read and is not showing. Have I damaged something ? What's the solution to this ? It's a 16 GB Hp USB. Please help me because at present moment it's the sole USB I have and I need it for some other work.
