USB need reinsert every boot
Hi guys,
Since two days all my usb devices need to get reinserted into the pc to get properly recognised. Not a clue why that should happen, i tested them also on my work pc running another linux distro.
All my USB devices are cable ones and in an older version of garuda worked well, i performed a recent install.
here is the garuda-inxi output
Kernel: 6.4.7-zen1-3-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=9e8d85e0-82ca-4ebe-9992-f6be305d20c2 rw rootflags=subvol=@
Type: Desktop Mobo: Gigabyte model: B650 AORUS ELITE AX v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F4
date: 03/22/2023
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 5
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 4185 high: 4840 min/max: 3000/5049 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 4200 2: 4025
3: 4200 4: 3290 5: 4200 6: 4200 7: 4200 8: 4417 9: 4840 10: 4200 11: 4200
12: 4200 13: 4200 14: 4200 15: 4200 16: 4200 bogomips: 134147
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
Device-2: AMD Raphael vendor: Gigabyte driver: amdgpu v: kernel
gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-4, DP-5,
DP-6, HDMI-A-2 bus-ID: 12:00.0 chip-ID: 1002:164e class-ID: 0300
temp: 35.0 C
Device-3: 2M UVC CAMERA NexiGo N60 FHD Webcam
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 5-1.1:5 chip-ID: 1d6c:0103 class-ID: 0102
Screen-1: 0 s-res: 3000x2005 s-dpi: 96 s-size: 791x529mm (31.14x20.83")
s-diag: 952mm (37.46")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: bottom-l model: Huawei SSN-24
built: 2022 res: 1080x1920 hz: 60 dpi: 93 gamma: 1.2
size: 296x527mm (11.65x20.75") diag: 604mm (23.8") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,top-right
model: Samsung LC24RG50 serial: <filter> built: 2021 res: 1920x1080 hz: 60
dpi: 92 gamma: 1.2 size: 532x304mm (20.94x11.97") diag: 613mm (24.1")
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.52 6.4.7-zen1-3-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 12:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: C-Media TONOR TC30 Audio Device
lanes: 1 mode: 1.1 bus-ID: 1-3.2:6 chip-ID: 0d8c:0134 class-ID: 0300
Device-5: 2M UVC CAMERA NexiGo N60 FHD Webcam
API: ALSA v: k6.4.7-zen1-3-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.76 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: down mac: <filter>
bus-ID: 0f:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp15s0 state: up mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:7 chip-ID: 0e8d:0616
Local Storage: total: 931.51 GiB used: 57.27 GiB (6.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHPP41-1000GM size: 931.51 GiB block-size: physical: 512 B
fw-rev: 51060A20 temp: 39.9 C scheme: GPT
used: 57.27 GiB (6.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 44.9 C mobo: 29.0 C
GPU: device: amdgpu temp: 45.0 C mem: 38.0 C fan: 0 watts: 7.00
device: amdgpu temp: 36.0 C
Processes: 396 Uptime: 23m wakeups: 0 Memory: total: 32 GiB note: est.
available: 30.5 GiB used: 3.61 GiB (11.8%) Init: systemd v: 254
pm: pacman pkgs: 1866 libs: 548 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.28
System install date:     2023-07-26
Last full system update: 2023-08-04
Hoping for some help here i'm not really fond of how to debug it in linux :smile:
So what have you researched? What have you tried? (Don't wanna play 64-Questions Game.)
Have you tried other kernels? If so, which ones?
Not a fix, but this will usually restart all devices on the USB bus:
#!/bin/bash
#reset all of USB1/2/3 ports
for i in /sys/bus/pci/drivers/[uoex]hci_hcd/*:*; do
  [ -e "$i" ] || continue
  echo "${i##*/}" > "${i%/*}/unbind"
  echo "${i##*/}" > "${i%/*}/bind"
done
Make the script executable and it should hopefully restart your USB devices without requiring removing/re-plugging. You can even create a desktop startup file and place it in your dock (etc) for an instant way of refreshing your USB devices.
Chances are, a different kernel will fix this as @Bro already mentioned.
switching to lts did it thanks :slight_smile:
