Hello.
I have a USB wireless logitech mouse and when I download files it become very irregular and jerky. But on the other side the mouse pad moves normally and is not affected. Is there any way to gives more priority to the mouse ???
I'm on a ASUS Vivobook laptop brand new that I wiped Windoze for Garuda.
inxi -Faz
╰─λ inxi -Fxxxaz
Kernel: 5.15.7-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: initrd=\amd-ucode.img initrd=\initramfs-linux-zen.img
rd.luks.name=86691f1a-15a7-4cc6-823e-08eab8fb14b4=luks-86691f1a-15a7-4cc6-823e-08eab8fb14b4
root=/dev/mapper/luks-86691f1a-15a7-4cc6-823e-08eab8fb14b4
rootflags=subvol=@ rd.luks.options=discard rw
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA
Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: X513UA.305 date: 03/12/2021
ID-1: BAT0 charge: 38.9 Wh (100.0%) condition: 38.9/42.1 Wh (92.5%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Not charging cycles: 5
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
serial: <filter> charge: 100% (should be ignored) rechargeable: yes status:
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1603 high: 2575 min/max: 1400/4370 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1397 2: 1397
3: 1397 4: 1396 5: 1676 6: 1397 7: 1397 8: 1396 9: 1397 10: 1397 11: 1397
12: 2068 13: 2575 14: 1393 15: 1764 16: 2213 bogomips: 57494
Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
Device-2: Quanta USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-3:3 chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.7-zen1-1-zen LLVM 13.0.0)
v: 4.6 Mesa 21.3.1 direct render: Yes
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x bus-ID: 03:00.5
Device-3: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.41 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 01:00.0
chip-ID: 8086:2723 class-ID: 0280
bus-ID: 3-2:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 953.87 GiB used: 366.87 GiB (38.5%)
model: PC SN530 SDBPNPZ-1T00-1002 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21106000 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 937.07 GiB size: 937.07 GiB (100.00%)
used: 366.76 GiB (39.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-86691f1a-15a7-4cc6-823e-08eab8fb14b4
ID-2: /boot raw-size: 260 MiB size: 256 MiB (98.46%)
used: 118.9 MiB (46.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 937.07 GiB size: 937.07 GiB (100.00%)
ID-4: /var/log raw-size: 937.07 GiB size: 937.07 GiB (100.00%)
ID-5: /var/tmp raw-size: 937.07 GiB size: 937.07 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.1 GiB used: 3.5 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.54 GiB used: 0 KiB (0.0%)
mapped: luks-1436414a-f251-47a7-bf5f-6ba83c40e119
System Temperatures: cpu: 48.0 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (RPM): cpu: 0
Processes: 395 Uptime: 1h 49m wakeups: 434 Memory: 15.1 GiB
used: 4.26 GiB (28.2%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1701 lib: 383 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.10
Thank you for any hints,
Bernard
