Hello everyone, i’m trying to make my second monitor working on my laptop but i’m not having any success.
First of all my
Kernel: 5.18.14-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=0537531b-0a1b-492b-8543-6ca7cf4284eb rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: ASUSTeK product: ROG Strix G531GT_G531GT v: 1.0
Mobo: ASUSTeK model: G531GT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G531GT.308 date: 02/01/2021
ID-1: BAT0 charge: 39.0 Wh (100.0%) condition: 39.0/50.5 Wh (77.2%)
volts: 12.5 min: 12.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging
ID-2: hidpp_battery_0 charge: 88% condition: N/A volts: 4.1 min: N/A
gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xD (13) microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 904 high: 952 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 843 2: 900 3: 900 4: 926
5: 902 6: 952 7: 937 8: 900 9: 900 10: 900 11: 894 12: 900
bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f91 class-ID: 0300
Device-3: DisplayLink ASUSTEK MB169B+ type: USB driver: N/A bus-ID: 2-4:3
chip-ID: 17e9:ff0b class-ID: fe01 serial: <filter>
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: Najing CEC Panda 0x0036 built: 2018
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
v: 4.6 Mesa 22.1.3 direct render: Yes
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Sound Server-1: ALSA v: k5.18.14-zen1-1-zen running: yes
driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.38 TiB used: 10.07 GiB (0.7%)
model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size: physical: 512 B
rev: P1MA0V4 temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LX015-1U7172
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM1
used: 10.07 GiB (2.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C pch: 47.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2800
Processes: 277 Uptime: 1h 8m wakeups: 3 Memory: 15.48 GiB
used: 2.93 GiB (18.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1216 lib: 308
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-07-26
Last full system update: 2022-07-26
Hardware
Second Monitor
The monitor giving me problem is an ASUS MB169B+.
Machine
Asus ROG Strix G G531
CPU: Intel(R) Core™ i7-9750H CPU @ 2.60GHz
Graphic card: NVIDIA GeForce GTX 1650
Bios American Megatrends version 308 (already checked and it’s upgraded to latest version)
Nvidia driver
| NVIDIA-SMI 515.57 Driver Version: 515.57 CUDA Version: 11.7 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| N/A 37C P0 7W / N/A | 5MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 630 G /usr/lib/Xorg 4MiB |
Procedure followed
1-Downloaded the kde dragonized version though the installer,verified the checksum and created the bootable driver with rufus.
2-Gone into the bios disabled the secure boot and set my SATA controller to AHCI.
3-Installed Garuda with the default option and allowed the nvidia driver (i’m not trying to dual boot there is only garuda os on my pc).
4-Installed pamac and used to install displaylink and evdi.
5-Gone into /etc/X11/xorg.conf.d and created the 20-evdi.conf file where i copy and pasted from the arch wikia displaylink article
Section "OutputClass"
Identifier "DisplayLink"
MatchDriver "evdi"
Driver "modesetting"
Option "AccelMethod" "none"
EndSection
and rebooted the system.
6- Then
xrandr --listproviders
return me
Providers: number : 2
Provider 0: id: 0x42 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 1 associated providers: 1 name:modesetting
Provider 1: id: 0x26b cap: 0x2, Sink Output crtcs: 4 outputs: 1 associated providers: 1 name:NVIDIA-G0
after this i tried following the guide
xrandr --setprovideroutputsource 1 0
but my monitor is still black.
Also tried
xrandr --setprovideroutputsource 0 1
that return me
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 35 (RRSetProviderOutputSource)
Value in failed request: 0x26b
Serial number of failed request: 16
Current serial number in output stream: 17
My monitor is working because when i plug it into the usb port it turn on and show me the asus logo and when i ran
lsusb
Bus 002 Device 003: ID 17e9:ff0b DisplayLink ASUSTEK MB169B+
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0b05:1866 ASUSTek Computer, Inc. N-KEY Device
Bus 001 Device 005: ID 046d:c539 Logitech, Inc. Cordless Mouse Receiver
Bus 001 Device 003: ID 8087:0aaa Intel Corp. Bluetooth 9460/9560 Jefferson Peak (JfP)
Bus 001 Device 004: ID 046d:c545 Logitech, Inc. USB Receiver
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
What i’m doing wrong? Thanks for the help
