Update problems (conflicting files and read errors)
I just installed Garuda as a fresh install and I’m getting a bunch of errors every time and no matter what options I pick the update ends in failure.
error: could not read db 'extra' (Truncated input file (needed 1024 bytes, only 0 available))
error: could not parse package description file 'haskell-hie-bios-0.11.0-70/desc' from db 'extra'
resolving dependencies...
:: There are 2 providers available for nvidia-utils=545.29.06:
:: Repository chaotic-aur
1) nvidia-utils-beta  2) nvidia-utils-nvlax
Enter a number (default=1): 1
:: There are 2 providers available for dbus-units:
:: Repository core
1) dbus-broker-units  2) dbus-daemon-units
:: nvidia-utils-beta and nvidia-utils are in conflict. Remove nvidia-utils? [y/N] y
:: chaotic-kf5-dummy and kirigami-addons5 are in conflict (kirigami-addons). Remove kirigami-addons5? [y/N] y
:: installing icu (74.2-1) breaks dependency 'libicuuc.so=73-64' requiredby gspell
:: installing icu (74.2-1) breaks dependency 'libicuuc.so=73-64' requiredby harfbuzz-icu
:: removing kirigami-addons5 breaks dependency 'kirigami-addons5' required by kdeconnect
:: removing nvidia-utils breaks dependency 'nvidia-utils=535.113.01' required by nvidia-dkms
:: installing icu (74.2-1) breaks dependency 'libicuuc.so=73-64' requiredby raptor
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
Without garuda-inxi this request will be moved to 412 Precondition Failed
My bad. I’ve been messing with some things and tried garuda-update remote fullfix and that ended up working partially. I did manage to at least get my graphics drivers updated so my resolution isn’t all messed up now. Now I just can’t install any new packages.
My inxi:
Kernel: 6.7.0-zen3-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0412b07d-c105-4744-b28d-289c2d5b2c41 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_wayland vt: 1
Type: Desktop System: iBUYPOWER product: INTEL v: N/A
Mobo: ASUSTeK model: PRIME Z790-P WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1604
date: 12/15/2023
Info: model: 13th Gen Intel Core i7-13700KF bits: 64 type: MST AMCP
microcode: 0x11F
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 837 high: 1100 min/max: 800/5300:5400:4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 1100 4: 800
5: 800 6: 800 7: 1100 8: 800 9: 1099 10: 800 11: 800 12: 800 13: 800
14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 798
23: 800 24: 800 bogomips: 164044
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: PNY driver: nvidia
v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:2684 class-ID: 0300
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: DP-1 res: 2560x1440 size: N/A modes: N/A
x11: drv: zink inactive: device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB display-ID: :1.0
API: Vulkan v: 1.3.274 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 545.29.06
device-ID: 10de:2684 surfaces: xcb,xlib,wayland
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
Device-2: NVIDIA AD102 High Definition Audio vendor: PNY
bus-ID: 01:00.1 chip-ID: 10de:22ba class-ID: 0403
Device-3: Blue Microphones Yeti Stereo Microphone
lanes: 1 mode: 1.1 bus-ID: 1-11.4:10 chip-ID: b58e:9e84 class-ID: 0300
API: ALSA v: k6.7.0-zen3-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.1 status: active with: 1: pipewire-pulse
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 06:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0026
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 16.43 TiB used: 10.49 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 731100WD temp: 37.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Corsair model: MP600 PRO XT
size: 7.28 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFM51.3 temp: 33.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST8000VN0022-2EL112
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SC61 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 model: USB DISK 3.0 size: 58.24 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 307.24 GiB size: 307.24 GiB (100.00%)
used: 10.46 GiB (3.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:8
used: 26.8 MiB (27.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 307.24 GiB size: 307.24 GiB (100.00%)
ID-4: /var/log raw-size: 307.24 GiB size: 307.24 GiB (100.00%)
ID-5: /var/tmp raw-size: 307.24 GiB size: 307.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.15 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 27.0 C mobo: N/A
Processes: 422 Uptime: 20m wakeups: 0 Memory: total: 32 GiB
available: 31.15 GiB used: 3.2 GiB (10.3%) Init: systemd v: 255
pm: pacman pkgs: 1221 libs: 349 tools: octopi,paru Shell: fish v: 3.7.0
Garuda (2.6.22-1):
System install date:     2024-01-23
Last full system update: 2024-01-23
Did you read
and the risks about remote commands?
Yes I read all of that before I even tried the command.
This can be closed. It turns out it was just a mirror issue. The US mirrorlist is just down at the moment it seems. I switched to UK mirrors and was able to install things just fine.
Hmm. Worked for me this morning too - after it didn’t, exact same thing, yesterday - but by now it doesn’t work anymore.
Fehler: Konnte Datei 'extra.db' nicht von sg.mirrors.cicku.me übertragen : transfer closed with 366986 bytes remaining to read
warning: lilv: local (0.24.24-1) is newer than extra (0.24.22-1)
warning: python-toolz: local (0.12.1-1) is newer than extra (0.12.0-3)
warning: serd: local (0.32.2-1) is newer than extra (0.32.0-1)
warning: xdg-utils: local (1.2.0r28+g9b7d253-1) is newer than extra (1.2.0r25+g0f49cf5-1)
 there is nothing to do
What’s wrong with the mirrors lately?
