Hello, I'm using since a few Weeks GAruda Linux with a Win 10 Dualboot and I'm very happy with this Distribution. However now after some Days I started Garuda and I had around 460 Updates. After starting this Error Massage comes:
Auflösung der Abhängigkeit fehlgeschlagen libcanberra=0.30+2+ggc0620e4-3 Auflösung der Abhängigkeit fehlgeschlagen libcanberra=0.30+2+ggc0620e4-3
Yes it is two times mentioned in the Errorbox.
I'm Updating with Discover. With the Internal Updatetool, everything seems to be ok. However, nothing is updated after this Error.
Please can you help me with this Error? Unchecking the libcanberra Line and/or pacman just causes the Error, wich tells me, its not working.
Thanks for helping!
As a general rule, the primary update tool for Arch-distros is 'pacman'. Give it a try, and see what it says with regards to errors.
Pacman is not starting and the pre installed "add or remove Software Tool" also doesn't work
So...does pacman issue an error or just do nothing? Errors are usually meaningful.
i tiype in the search Panel Pacman, then there is the "Pacman ausführen" Entry, click on it and nothing happens.
Please read about how to update your arch-based distro. When you have thoroughly understood the wiki about how to update your system...try it.
https://wiki.archlinux.org/title/Pacman#Upgrading_packages
Now it started via Console, but had also an Error, what should i do, or what was my mistake?
LANG=C
[] × sudo pacman -Syu
[sudo] Passwort für *****:
Warnung: Konfigurations-Datei /etc/pacman.conf, Zeile 34: Direktive »%« in Sektion »TotalDownload« wird nicht er
kannt.
:: Paketdatenbanken werden synchronisiert …
core ist aktuell
extra ist aktuell
community ist aktuell
multilib ist aktuell
chaotic-aur 1244,1 KiB 2,01 MiB/s 00:01 [-------------------------------------] 100%
:: Vollständige Systemaktualisierung wird gestartet …
:: libcanberra-pulse durch extra/libcanberra ersetzen? [J/n] j
Abhängigkeiten werden aufgelöst …
Nach in Konflikt stehenden Paketen wird gesucht …
Warnung: Entferne 'archlinux-appstream-data' aus der Ziel-Liste, da es mit 'archlinux-appstream-data-pamac' in K
onflikt steht
:: garuda-boot-options und grub-customizer stehen miteinander in Konflikt. grub-customizer entfernen? [j/N] j
:: garuda-common-settings und systemd-swap stehen miteinander in Konflikt. systemd-swap entfernen? [j/N] j
:: archlinux-appstream-data-pamac und archlinux-appstream-data stehen miteinander in Konflikt. archlinux-appstre
am-data entfernen? [j/N] j
Pakete (472) accounts-qml-module-0.7-4 akonadi-calendar-21.04.2-1 akonadi-contacts-21.04.2-1
akonadi-import-wizard-21.04.2-1 akonadi-mime-21.04.2-1 akonadi-notes-21.04.2-1
akonadi-search-21.04.2-1 alembic-1.8.2-1 alsa-card-profiles-1:0.3.31-1 alsa-lib-1.2.5.1-3
alsa-plugins-1:1.2.5-2 alsa-topology-conf-1.2.5.1-1 alsa-ucm-conf-1.2.5.1-1
android-tools-31.0.0-4 aom-3.1.1-1 appstream-0.14.4-1 appstream-qt-0.14.4-1
archlinux-appstream-data-20210423-1 [Entfernung] archlinux-appstream-data-pamac-20210612-1
archlinux-keyring-20210616-1 ark-21.04.2-1 at-spi2-core-2.40.2-1 attica-5.83.0-1 audit-3.0.2-1
baloo-5.83.0-1 baloo-widgets-21.04.2-1 beautyline-20210621-1 bind-9.16.18-1 blas-3.10.0-1
bleachbit-4.4.0-1 blender-17:2.93.1-2 bluedevil-1:5.22.3-1 bluez-5.59-2 bluez-cups-5.59-2
bluez-hid2hci-5.59-2 bluez-libs-5.59-2 bluez-plugins-5.59-2 bluez-qt-5.83.0-1
bluez-utils-5.59-2 boost-libs-1.76.0-1 breeze-5.22.3-1 breeze-icons-5.83.0-1
ca-certificates-20210603-1 ca-certificates-mozilla-3.67-1 ca-certificates-utils-20210603-1
calendarsupport-21.04.2-1 cblas-3.10.0-1 ceph-libs-15.2.12-2 chaotic-keyring-20210617-1
chaotic-mirrorlist-20210620-1 clang-12.0.0-1 colord-1.4.5-4 compiler-rt-12.0.0-1 cuda-11.3.1-1
cups-filters-1.28.9-1 darktable-2:3.6.0-1 deepin-desktop-base-2:2021.5.07-1
deepin-qt5integration-5.1.12-1 discover-5.22.3-1 dolphin-21.04.2-1 dolphin-plugins-21.04.2-1
downgrade-10.1.0-1 dtkcommon-5.5.3-1 dtkcore-1:5.4.15-1 dtkgui-5.5.2-1 dtkwidget-5.5.7-1
editorconfig-core-c-0.12.5-1 elfutils-0.185-1 enchant-2.3.0-1 eventviews-21.04.2-1
evince-40.2-1 exiv2-0.27.4-2 ffmpeg-2:4.4-4 ffmpegthumbs-21.04.2-1 firedragon-89.0.2-1
firefox-89.0.2-1 flatpak-1.11.2-1 fontconfig-2:2.13.94-1 fprintd-1.92.0-1
frameworkintegration-5.83.0-1 fuse-common-3.10.4-1 fuse3-3.10.4-1 fwupd-1.6.1-2
fwupd-efi-1.1-1 fzf-0.27.2-1 game-devices-udev-0.14-1 garuda-assistant-1.0.5-1
garuda-boot-options-1.0.1-1 garuda-common-settings-1.4.0-1 garuda-dr460nized-1.5.2-1
garuda-fish-config-1.3.4-1 garuda-gamer-1.0.1-1 garuda-hooks-1.0.6-2 garuda-welcome-1.0.5-1
gd-2.3.2-4 gdal-3.3.0-1 gdbm-1.20-1 gegl-0.4.30-4 geoip-database-20210622-1 gimp-2.10.24-5
git-2.32.0-1 glib2-2.68.3-1 glslang-11.5.0-1 glu-9.0.2-1 gmic-2.9.7-5 gnome-desktop-1:40.2-1
gnupg-2.2.28-2 gnuplot-5.4.2-1 gnutls-3.7.2-2 go-2:1.16.5-1 go-tools-4:0.1.4-1 gpgme-1.16.0-1
gptfdisk-1.0.8-1 grantleetheme-21.04.2-1 graphviz-2.47.3-1 groff-1.22.4-6 grub-2:2.06-1
grub-customizer-5.1.0-2 [Entfernung] gst-plugins-bad-1.18.4-8 gst-plugins-bad-libs-1.18.4-8
gupnp-1.2.7-1 hdparm-9.62-1 hexer-hobu-1.4.0-6 hunspell-en_us-2020.12.07-3 hwids-20210613-1
hwinfo-21.75-1 iana-etc-20210624-1 imagemagick-7.1.0.2-2 imath-3.0.5-1
incidenceeditor-21.04.2-1 inetutils-2.0-1 intel-ucode-20210608-1 iproute2-5.13.0-1
jasper-2.0.32-1 kaccounts-integration-21.04.2-1 kaccounts-providers-21.04.2-1
kactivities-5.83.0-1 kactivities-stats-5.83.0-1 kactivitymanagerd-5.22.3-1 karchive-5.83.0-1
kate-21.04.2-1 kauth-5.83.0-1 kbookmarks-5.83.0-1 kcalc-21.04.2-1 kcalendarcore-5.83.0-1
kcalutils-21.04.2-1 kcmutils-5.83.0-1 kcodecs-5.83.0-1 kcompletion-5.83.0-1 kconfig-5.83.0-1
kconfigwidgets-5.83.0-1 kcontacts-1:5.83.0-1 kcoreaddons-5.83.0-1 kcrash-5.83.0-1
kdbusaddons-5.83.0-1 kde-cli-tools-5.22.3-1 kde-gtk-config-5.22.3-1 kdeclarative-5.83.0-1
kdeconnect-21.04.2-1 kdecoration-5.22.3-1 kded-5.83.0-1 kdegraphics-thumbnailers-21.04.2-1
kdelibs4support-5.83.0-1 kdenlive-21.04.2-2 kdepim-addons-21.04.2-1 kdeplasma-addons-5.22.3-1
kdesu-5.83.0-1 kdialog-21.04.2-1 kdnssd-5.83.0-1 kdsoap-2.0.0-1
kdsoap-ws-discovery-client-git20200927-2 kemoticons-5.83.0-1 kfilemetadata-5.83.0-1
kglobalaccel-5.83.0-1 kguiaddons-5.83.0-1 kholidays-1:5.83.0-1 khotkeys-5.22.3-1
ki18n-5.83.0-1 kiconthemes-5.83.0-1 kidentitymanagement-21.04.2-1 kidletime-5.83.0-1
kimageformats-5.83.0-4 kimap-21.04.2-1 kinfocenter-5.22.3-1 kinit-5.83.0-1 kio-5.83.0-1
kio-extras-21.04.2-3 kio-gdrive-21.04.2-1 kipi-plugins-21.04.2-1 kirigami2-5.83.0-1
kitemmodels-5.83.0-1 kitemviews-5.83.0-1 kitinerary-21.04.2-2 kjobwidgets-5.83.0-1
kjs-5.83.0-1 kldap-21.04.2-1 kmailtransport-21.04.2-1 kmbox-21.04.2-1 kmenuedit-5.22.3-1
kmime-21.04.2-1 knewstuff-5.83.0-1 knotifications-5.83.0-1 knotifyconfig-5.83.0-1
konsole-21.04.2-1 kontactinterface-21.04.2-1 kpackage-5.83.0-1 kparts-5.83.0-1
kpeople-5.83.0-1 kpimtextedit-21.04.2-1 kpkpass-21.04.2-1 kpmcore-21.04.2-1 kpty-5.83.0-1
kquickcharts-5.83.0-1 krita-4.4.5-2 krita-plugin-gmic-2.9.7-5 krunner-5.83.0-1
kscreen-5.22.3-1 kscreenlocker-5.22.3-1 kservice-5.83.0-1 ksmtp-21.04.2-1 ksysguard-5.22.0-1
ksystemstats-5.22.3-1 ktexteditor-5.83.0-1 ktextwidgets-5.83.0-1 ktnef-21.04.2-1
kunitconversion-5.83.0-1 kvantum-theme-sweet-git-r194.87f6464-1 kwallet-5.83.0-1
kwallet-pam-5.22.3-1 kwayland-5.83.0-1 kwayland-integration-5.22.3-1 kwayland-server-5.22.3-1
kwidgetsaddons-5.83.0-1 kwin-5.22.3-1 kwindowsystem-5.83.0-1 kxmlgui-5.83.0-1 lapack-3.10.0-1
latte-dock-git-0.9.91.r132.g92aec503-1 layer-shell-qt-5.22.3-1 lib32-libelf-0.185-1
lib32-libldap-2.4.59-1 lib32-libx11-1.7.2-1 lib32-libxcrypt-4.4.23-1 lib32-llvm-libs-12.0.0-2
lib32-mesa-21.1.4-1 lib32-ocl-icd-2.3.0-1 lib32-util-linux-2.37-1
lib32-vulkan-icd-loader-1.2.182-1 lib32-zstd-1.5.0-2 libaccounts-glib-1.25-4
libaccounts-qt-1.16-3 libakonadi-21.04.2-1 libavif-0.9.2-1 libcanberra-0.30+2+gc0620e4-5
libcanberra-pulse-0.30+2+gc0620e4-3 [Entfernung] libcap-2.50-2 libcerf-1:1.17-1 libcmis-0.5.2-8
libcolord-1.4.5-4 libdrm-2.4.107-1 libedit-20210522_3.1-1 libelf-0.185-1 libfprint-1.92.0-1
libgit2-1:1.1.1-1 libgravatar-21.04.2-1 libgusb-0.3.7-1 libhandy-1.2.3-1 libixion-0.16.1-6
libkdcraw-21.04.2-1 libkdepim-21.04.2-1 libkexiv2-21.04.2-1 libkgapi-21.04.2-1
libkipi-21.04.2-1 libkleo-21.04.2-1 libksba-1.6.0-1 libkscreen-5.22.3-1 libksieve-21.04.2-1
libksysguard-5.22.3-1 libldap-2.4.59-1 liblouis-3.18.0-1 libmfx-21.2.3-1 libmm-glib-1.16.6-1
libnice-0.1.18-2 libnm-1.32.2-1 libogg-1.3.5-1 liborcus-0.16.1-7 libp11-kit-0.24.0-1
libpamac-aur-11.0.0-1 libpcap-1.10.1-1 libphonenumber-8.12.25-1 libplacebo-3.120.3-2
libqmi-1.28.6-1 libreoffice-fresh-7.1.4-1 librsvg-2:2.50.7-1 libva-2.12.0-1 libvips-8.11.2-1
libwpe-1.10.1-1 libx11-1.7.2-1 libxcrypt-4.4.23-1 libxnvctrl-465.31-1 linux-zen-5.12.14.zen1-1
linux-zen-headers-5.12.14.zen1-1 llvm-libs-12.0.0-2 m4-1.4.19-1 mailcommon-21.04.2-1
mailimporter-21.04.2-1 man-db-2.9.4-2 man-pages-5.12-1 mariadb-10.5.11-1
mariadb-clients-10.5.11-1 mariadb-libs-10.5.11-1 mbedtls-2.26.0-1 memtest86+-5.31b-1
mesa-21.1.4-1 messagelib-21.04.2-1 mhwd-nvidia-465.31-1 milou-5.22.3-1
mkinitcpio-busybox-1.33.1-1 modemmanager-1.16.6-1 modemmanager-qt-5.83.0-1 mono-6.12.0.122-1
mpg123-1.28.0-1 mtools-1:4.0.31-1 mujs-1.1.3-1 netpbm-10.73.34-1 nettle-3.7.3-1
networkmanager-1.32.2-1 networkmanager-qt-5.83.0-1 nextcloud-client-3.2.3-1 nfs-utils-2.5.4-1
nfsidmap-2.5.4-1 nm-cloud-setup-1.32.2-1 noto-color-emoji-fontconfig-1.0.0-1 nspr-4.32-1
nss-3.67-1 nvidia-settings-465.31-1 obs-studio-27.0.1-1 ocl-icd-2.3.0-1 okular-21.04.2-1
opencolorio-2.0.1-2 opencolorio1-1.1.1-3 opencv-4.5.3-1 openexr-3.0.5-1 openimageio-2.2.15.1-4
openldap-2.4.59-1 openmp-12.0.0-1 openmpi-4.1.1-2 openshadinglanguage-1.11.14.0-3
opensubdiv-3.4.4-2 openvdb-8.1.0-1 openvpn-2.5.3-1 openxr-1.0.17-1 p11-kit-0.24.0-1
pace-1.4.1.1-2 pacman-6.0.0-3 pacman-contrib-1.4.0-4 pamac-aur-10.1.3-1 pambase-20210605-2
pango-1:1.48.7-1 partitionmanager-21.04.2-1 paru-1.7.3-1 pcre-8.45-1 pdal-2.2.0-3
perl-alien-build-2.41-1 perl-libwww-6.55-1 pimcommon-21.04.2-1 pipewire-1:0.3.31-1
plasma-browser-integration-5.22.3-1 plasma-desktop-5.22.3-1 plasma-disks-5.22.3-1
plasma-firewall-5.22.3-1 plasma-framework-5.83.0-1 plasma-integration-5.22.3-1
plasma-nm-5.22.3-1 plasma-pa-5.22.3-1 plasma-systemmonitor-5.22.3-1 plasma-thunderbolt-5.22.3-1
plasma-vault-5.22.3-1 plasma-workspace-5.22.3-1 plasma5-applets-window-appmenu-0.7.0-1
plasma5-applets-window-title-0.7.0-1 plymouth-git-0.9.5.r84.ge554475-4 polkit-kde-agent-5.22.3-1
polkit-qt5-0.114.0-1 poppler-21.07.0-1 poppler-glib-21.07.0-1 poppler-qt5-21.07.0-1
postgresql-libs-13.3-3 powerdevil-5.22.3-1 print-manager-21.04.2-1 printer-support-1-4
prison-5.83.0-1 profile-sync-daemon-6.44-2 protobuf-3.17.3-1 ptex-2.4.0-1
pulseaudio-alsa-1:1.2.5-2 purpose-5.83.0-1 pystring-1.1.3.git1-1 python-3.9.6-1
python-docutils-0.17.1-1 python-gdal-3.3.0-1 python-idna-3.2-1 python-matplotlib-3.4.2-1
python-pillow-8.3.0-1 python-pip-20.3.4-1 python-psycopg2-2.9.1-1
python-qscintilla-qt5-2.13.0-1 python-reportlab-3.5.68-1 python-resolvelib-0.5.5-1
python-setuptools-1:57.1.0-1 python-urllib3-1.26.6-1 python-xlib-0.31-1 qgis-3.20.0-2
qgpgme-1.16.0-1 qqc2-desktop-style-5.83.0-1 qscintilla-qt5-2.13.0-1 qt5-3d-5.15.2+kde+r25-1
qt5-base-5.15.2+kde+r207-1 qt5-declarative-5.15.2+kde+r29-1 qt5-script-5.15.5-2
qt5-tools-5.15.2+kde+r17-2 qt5-wayland-5.15.2+kde+r28-1 qt5-webengine-5.15.5-1 rnnoise-0.4.1-1
rubberband-1.9.2-1 ruby-irb-1.3.6-1 rubygems-3.2.21-1 samba-4.14.5-1 sddm-kcm-5.22.3-1
shaderc-2021.1-1 signal-desktop-5.7.1-1 signon-kwallet-extension-21.04.2-1 smbclient-4.14.5-1
sof-firmware-1.8-1 solid-5.83.0-1 sonnet-5.83.0-1 spectacle-21.04.2-1 sqlite-3.36.0-1
sshfs-3.7.2-1 sstp-client-1:1.0.15-1 starship-0.55.0-1 stellarium-0.21.1-1 sudo-1.9.7.p1-1
sweet-kde-git-r194.87f6464-1 syndication-5.83.0-1 syntax-highlighting-5.83.0-1
systemd-swap-4.4.0-2 [Entfernung] systemsettings-5.22.3-1 telegram-desktop-2.8.4-3
texinfo-6.8-1 threadweaver-5.83.0-1 timeshift-20.11.1+4+gd437358-1 unarj-2.65-1
unrar-1:6.0.7-1 upower-0.99.12-2 util-linux-2.37-3 util-linux-libs-2.37-3 vlc-3.0.16-2
vte-common-0.64.2-2 vte3-0.64.2-2 vulkan-icd-loader-1.2.182-1 vulkan-tools-1.2.182-1
whois-5.5.10-1 whoogle-git-0.5.4_r348.g694642c-1 wireless-regdb-2021.04.21-1
wpebackend-fdo-1.10.0-1 xapp-2.2.2-1 xdg-desktop-portal-kde-5.22.3-1
xf86-input-libinput-1.1.0-1 xfsprogs-5.12.0-1 xkeyboard-config-2.33-1 zram-generator-0.3.2-1
Gesamtgröße des Downloads: 0,09 MiB
Gesamtgröße der installierten Pakete: 10638,59 MiB
Größendifferenz der Aktualisierung: 363,00 MiB
:: Installation fortsetzen? [J/n] j
:: Pakete werden empfangen …
libcanberra-0.30+2+gc0620e4-5-x86_64 91,6 KiB 152 KiB/s 00:01 [-------------------------------------] 100%
(468/468) Schlüssel im Schlüsselbund werden geprüft [-------------------------------------] 100%
Benötigte Schlüssel werden heruntergeladen …
:: PGP Schlüssel 0706B90D37D9B881, »Pedro Henrique Lara Campos <[email protected] >« importieren? [J/n] j
(468/468) Paket-Integrität wird überprüft [-------------------------------------] 100%
Fehler: beautyline: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: PGP-Schlüssel 45ECA705E3897524654A37880706B90D37D9B881 importieren? [J/n] j
Fehler: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" konnte nicht entfernt abgerufen werden
:: Datei /var/cache/pacman/pkg/beautyline-20210621-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigte
s Paket (PGP-Signatur)).
Soll die Datei entfernt werden? [J/n] j
Fehler: downgrade: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/downgrade-10.1.0-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes P
Fehler: firedragon: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/firedragon-89.0.2-1-x86_64.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigt
es Paket (PGP-Signatur)).
Soll die Datei entfernt werden? [J/n] n
Fehler: garuda-assistant: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/garuda-assistant-1.0.5-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschädi
gtes Paket (PGP-Signatur)).
Fehler: garuda-hooks: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/garuda-hooks-1.0.6-2-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes
Fehler: garuda-common-settings: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/garuda-common-settings-1.4.0-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder be
schädigtes Paket (PGP-Signatur)).
Fehler: garuda-fish-config: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/garuda-fish-config-1.3.4-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschä
Fehler: kvantum-theme-sweet-git: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/kvantum-theme-sweet-git-r194.87f6464-1-any.pkg.tar.zst ist beschädigt (Ungültiges
oder beschädigtes Paket (PGP-Signatur)).
Fehler: sweet-kde-git: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/sweet-kde-git-r194.87f6464-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder besc
Fehler: garuda-dr460nized: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/garuda-dr460nized-1.5.2-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschäd
Fehler: latte-dock-git: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/latte-dock-git-0.9.91.r132.g92aec503-1-x86_64.pkg.tar.zst ist beschädigt (Ungülti
ges oder beschädigtes Paket (PGP-Signatur)).
Fehler: mhwd-nvidia: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/mhwd-nvidia-465.31-1-any.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes
Fehler: paru: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/paru-1.7.3-1-x86_64.pkg.tar.zst ist beschädigt (Ungültiges oder beschädigtes Pake
t (PGP-Signatur)).
Fehler: plymouth-git: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/plymouth-git-0.9.5.r84.ge554475-4-x86_64.pkg.tar.zst ist beschädigt (Ungültiges o
Fehler: whoogle-git: Schlüssel "45ECA705E3897524654A37880706B90D37D9B881" ist unbekannt
:: Datei /var/cache/pacman/pkg/whoogle-git-0.5.4_r348.g694642c-1-x86_64.pkg.tar.zst ist beschädigt (Ungültiges o
Fehler: Der Vorgang konnte nicht durchgeführt werden (Ungültiges oder beschädigtes Paket)
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
Thanks for the formatting change.
LANG=C was for the terminal not in the forum (e.g. LANG=C sudo pacman -Syu
, or just LANG=C
for the entire terminal session). No worries anyway, I'm almost sure you have the issue addressed in the linked tutorial.
Follow it and it should solve your issue.
THX a lot! ...
Now I started this:
If you have any other errors, you can clear out the pacman keyring and start fresh:
sudo rm -fr /etc/pacman.d/gnupg
sudo pacman-key --init
sudo pacman-key --populate archlinux chaotic
sudo pacman -Syy archlinux-keyring chaotic-keyring
sudo pacman -Syu
It actuall works all the keys are refreshed, but now the Question ... Yes or No?
╭─david@Forces in ~ took 21s
╰─λ LANG=C sudo pacman -Syu
warning: config file /etc/pacman.conf, line 34: directive 'TotalDownload' in section 'options' not recognized.
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n]
filo
7 July 2021 13:01
11
I don't know and have these packages, but I always assume Y in these cases (also default)
Thanks a lot, now everything works fine!
filo
7 July 2021 13:09
13
Last but not least, welcome!
system
Closed
9 July 2021 13:10
14
