Hi there
I had no issues updating my Garuda system during the last year or so. Today this message came up:
libnautilus-extension and libnautilus-extension-typeahead are in conflict
The update will halt and I have to exit. I couldn't find any solutions so I'm posting it here for some advise on how to proceed.
Thank you in advance
Stephane
Kernel: 6.0.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=596af91a-fe87-415d-9545-c6711cedc266 rw rootflags=subvol=@
Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop Mobo: BESSTAR TECH model: UM700 v: V1.0
serial: <superuser required> UEFI-[Legacy]: American Megatrends
v: AF5NV701.25 date: 12/15/2020
Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64
stepping: 1 microcode: 0x8108102
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2206 high: 2517 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2300 2: 2517
3: 2300 4: 2300 5: 2300 6: 2300 7: 1332 8: 2300 bogomips: 36727
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 05:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 50.0 C
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.4
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :1 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Acer KG271 G serial: <filter>
built: 2021 res: 1920x1080 hz: 75 dpi: 82 gamma: 1.2
OpenGL: renderer: AMD Radeon Vega 10 Graphics (raven LLVM 14.0.6 DRM 3.48
6.0.6-zen1-1-zen) v: 4.6 Mesa 22.2.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp3x
v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_sof_amd_renoir
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3
Sound API: ALSA v: k6.0.6-zen1-1-zen running: yes
Sound Server-1: JACK v: 1.9.21 running: no
Sound Server-2: PulseAudio v: 16.1 running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
IF-ID-1: eno1 state: down mac: <filter>
bus-ID: 3-2:2 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 685.61 GiB used: 574.19 GiB (83.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3256B-A01
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: EDFK0S03
temp: 49.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
type: SSD serial: <filter> rev: 041 scheme: GPT
ID-1: / raw-size: 251.22 GiB size: 251.22 GiB (100.00%) used: 143.51 GiB
(57.1%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /home raw-size: 251.22 GiB size: 251.22 GiB (100.00%) used: 143.51
GiB (57.1%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-3: /var/log raw-size: 251.22 GiB size: 251.22 GiB (100.00%) used: 143.51
ID-4: /var/tmp raw-size: 251.22 GiB size: 251.22 GiB (100.00%) used: 143.51
ID-1: swap-1 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.4 C mobo: N/A gpu: amdgpu temp: 50.0 C
Processes: 332 Uptime: 57m wakeups: 0 Memory: 15.33 GiB used: 4.34 GiB
(28.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1688
libs: 506 tools: pamac,paru pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.22
Garuda (2.6.9-1):
System install date: 2021-03-26
Last full system update: 2022-10-31
Snapshots: Timeshift
