Update fails: invalid or damaged package
But even with the chaotic keys updated got the same error. Downloading the package and installing it worked but not though the normal pacman update.
as i see its different - installed is the the git version that gives the error .. https://aur.archlinux.org/protontricks-git.git
regularcoder link is different its the non git version ..
here u see both versions AUR (en) - Search Criteria: protontricks
u can change to no git version or wait till nico has fix it
Just installed protontricks-git no issues.
With yay aswell as makepkg
https://aur.archlinux.org/cgit/aur.git/snapshot/protontricks-git.tar.gz
==> Installing package protontricks-git with pacman -U...
loading packages...
resolving dependencies...
Packages (1) protontricks-git-1.6.1.dev1+g4ab6784-1
Total Installed Size:  0.20 MiB
DId purge the existing protontricks
at me same error ... only if i use https://aur.archlinux.org/cgit/aur.git/snapshot/protontricks-git.tar.gz
makepkg -si
then it works ... on pacman or paru / yay it gives pgp error
Super wierd.I made and installed with yay both the stable and git version of proton. and no issues
Already done, same error.
@all: I’ll wait until @dr460nf1r3 tells us that he’d updated the package or gives another advice.
Manually install, as i advised tempest, and it worked for him so it most probably work for you.
I dont think its a package error
Thank you for your help but I’ll wait for @dr460nf1r3 to get his work done.
Maybe he needs someone with this problem.
if anyone need it now they can follow the advice of regularCoder it will work fine without problems .
but i think its a package error .
if anyone want update the sytem without protontrick use
sudo pacman -Syu --ignore protontricks-git
LIke whhy???
sorry typo .. early at the morning ... need more coffe :grinning_face_with_smiling_eyes: :coffee:
Good morning guys :wink: The package is fixed!
Thank you for your work!
At first I had the same error, after a reboot the update ran without any problems.
still having the issue...
try
 update
so it will refresh your keyrings before the update starts then it should work
╰─λ update
Detected Paru, using it to update the system..
Refreshing mirrorlists..
################# Arch Linux mirrorlist generated by Reflector #################
# With:       reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When:       2021-08-15 10:18:30 UTC
# From:       https://archlinux.org/mirrors/status/json/
# Retrieved:  2021-08-15 10:14:44 UTC
# Last Check: 2021-08-15 09:42:39 UTC
Server = https://mirror.chaoticum.net/arch/$repo/os/$arch
Server = https://dist-mirror.fem.tu-ilmenau.de/archlinux/$repo/os/$arch
Server = https://mirror.pseudoform.org/$repo/os/$arch
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
Checking for keyring update before starting full system update..
:: Synchronising package databases...
core is up to date
extra is up to date
community is up to date
chaotic-aur is up to date
multilib is up to date
warning: archlinux-keyring-20210802-1 is up to date -- skipping
warning: chaotic-keyring-20210617-1 is up to date -- skipping
there is nothing to do
Packages (1) protontricks-git-1.6.0.r1.g4ab6784-1
Total Download Size:   0,06 MiB
Total Installed Size:  0,20 MiB
Net Upgrade Size:      0,00 MiB
:: Retrieving packages...
protontricks-git-1.6.0.r1.g4ab6784-1-any        59,4 KiB  87,3 KiB/s 00:01 [###########################################] 100%
(1/1) checking keys in keyring                                              [###########################################] 100%
(1/1) checking package integrity                                            [###########################################] 100%
error: protontricks-git: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is invalid
:: File /var/cache/pacman/pkg/protontricks-git-1.6.0.r1.g4ab6784-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
error: failed to commit transaction (invalid or corrupted package (PGP signature))
Still no luck, tried it before through GUI with refreshing the keyrings
Please try manually downloading and building the package, as i have suggested. Scroll up
You might have hit the CDN mirror of Chaotic which only syncs every 4 hours - just try again please in this case.
@dr460nf1r3 that seems to have been the issue. Now resolved. Thanks
