You can try today's beta ISO: Index of /garuda/iso/garuda/dr460nized/220130/
Audio works on that one, so went with a fresh reinstall. Thanks TNE. Thank you @Bro for the suggestions. Glad I managed to avoid the pain of a bios update this time.
Interesting. There was 4 package removals and 2 additions (didn't include the nvidia package in my count, and I might have missed something) over the last release of dr460nized compared to this beta version. Most of them are audio related (no surprised jack2 is removed).
Removed:
celt
, jack2
, zita-alsa-pcmi
, zita-resampler
Added:
linux-firmware-whence
, oniguruma
Given the reports (and what audio hardware they are running), I am going to go out on a limb and say some of the updated audio packages need that additional firmware package and that is why its only breaking for some installations?
ran garuda-update today and rebooted. All is working and I have sound again! Dont know what made things work today!
I haven't been on my laptop in a few days. I just ran another update and rebooted. Again no audio device found.... I wish I knew more of how to diagnose this.
Kernel: 5.16.11-1-cacule x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-cacule
root=UUID=00b33177-335b-466d-8a5b-e5bad5669f19 rw rootflags=subvol=@
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.3 info: latte-dock wm: kwin_x11
vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 22.9 Wh (58.9%) condition: 38.9/51.6 Wh (75.5%)
volts: 11.1 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: N/A
family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2597 high: 2601 min/max: 800/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 2600 2: 2599 3: 2562
4: 2600 5: 2600 6: 2601 7: 2601 8: 2600 9: 2601 10: 2600 11: 2600
12: 2600 bogomips: 62469
Type: l1tf
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
driver: i915 v: kernel ports: active: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus-ID: 1-13:5
chip-ID: 04f2:b695 class-ID: 0e02
loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
s-diag: 582mm (22.9")
Monitor-1: eDP1 mapped: eDP-1 model: AU Optronics built: 2019
res: 1920x1080 hz: 120 dpi: 143 gamma: 1.2 size: 340x190mm (13.4x7.5")
Sound Server-1: ALSA v: k5.16.11-1-cacule running: yes
driver: btusb v: 0.8 bus-ID: 1-14:6 chip-ID: 8087:0aaa class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 1.38 TiB used: 551.19 GiB (39.1%)
model: PC SN520 SDAPNUW-512G-1032 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD
serial: <filter> rev: 20140000 temp: 50.9 C scheme: GPT
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 73.24 GiB size: 73.24 GiB (100.00%)
used: 56.96 GiB (77.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 557 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 73.24 GiB size: 73.24 GiB (100.00%)
ID-4: /var/log raw-size: 73.24 GiB size: 73.24 GiB (100.00%)
ID-5: /var/tmp raw-size: 73.24 GiB size: 73.24 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C pch: 61.0 C mobo: N/A
Processes: 369 Uptime: 3m wakeups: 1 Memory: 15.47 GiB
used: 2.71 GiB (17.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1812 lib: 550 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-01-25
Last full system update: 2022-03-06
EDIT
â°âλ sudo dmesg | grep nvidia
[ 3.820597] nvidia: loading out-of-tree module taints kernel.
[ 3.820610] nvidia: module license 'NVIDIA' taints kernel.
[ 3.829573] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 3.845292] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[ 3.845881] nvidia 0000:01:00.0: enabling device (0000 -> 0003)
[ 3.845977] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 3.896967] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 510.54 Tue Feb 8 04:34:06 UTC 2022
[ 3.898844] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 3.898846] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 3.912053] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 3.920547] nvidia-uvm: Loaded the UVM driver, major device number 508.
â°âλ sudo dmesg | grep audio
[ 4.254484] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 4.335885] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.335889] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.335890] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x15/0x0/0x0/0x0/0x0)
[ 4.335892] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 4.335893] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.335894] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 4.335896] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
A recent update I tried to do today on one of my machines also has an issue with no sound sources detected in the KDE UI, and I wanted to see if this is similar to your issue. (had to use Snapper
to get the system stable for now)
I do hear sound with speaker-test -c2
. FireDragon starts slowly, and so do videos on webpages, but they do seem to eventually play with sound.
Since something seems to be holding up the audio detection process, I have tried changing out Pipewire related packages so it would match what the latest KDE dragonized gaming ISO has listed but no luck: pipewire-media-session
(instead of wireplumber
) and pipewire-v4l2
(instead of the git
version). Considering your System install date is so new and that you seem to have the same issues is making me scratch my head even more.
I've tried searching for any recent bug reports on Pipewire related packages though the Arch website and Pipewire's and turned up nothing so I am not quite sure what is at fault. Feels like I am missing something simple here, and now that I think about it I should try to see what FireDragon is trying to tell me (will get back to that later if necessary; taking a break from troubleshooting this at the moment)
(from the time the sound worked last)
Kernel: 5.15.25-1-lts x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=5dd98b26-dc7c-430f-a350-12d07b397ada
rw rootflags=subvol=@ quiet
cryptdevice=UUID=c60784ec-fd67-4a32-8b35-c79d27b73bac:luks-c60784ec-fd67-4a32-8b35-c79d27b73bac
root=/dev/mapper/luks-c60784ec-fd67-4a32-8b35-c79d27b73bac splash rd.udev.log_priority=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7A33 v: 2.0 serial: <superuser required>
Mobo: Micro-Star model: X370 SLI PLUS (MS-7A33) v: 2.0 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: 3.H0 date: 01/22/2019
Device-1: sony_controller_battery_ac:fd:93:fc:7a:08 model: N/A serial: N/A charge: N/A
status: Full
Info: model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001137
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 768 KiB
desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2737 high: 2994 min/max: 1550/3000 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 2557 2: 2776 3: 2578 4: 2747 5: 2980
6: 2733 7: 2560 8: 2564 9: 2994 10: 2724 11: 2716 12: 2727 13: 2697 14: 2927 15: 2744 16: 2780
bogomips: 95985
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 29:00.0
chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X: loaded: nvidia
gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.9x11.9") s-diag: 610mm (24")
Monitor-1: DP-2 res: 1920x1080 dpi: 92 size: 531x299mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 29:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 2b:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: SteelSeries ApS Arctis 5 type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-13:3 chip-ID: 1038:12aa class-ID: 0300 serial: <filter>
Device-4: JMTek LLC. USB PnP Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 3-1:2 chip-ID: 0c76:122e class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.25-1-lts running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 21:00.0
IF: enp33s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 25:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp37s0 state: up mac: <filter
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:4 chip-ID: 8087:0029
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
Local Storage: total: 2.16 TiB used: 195.72 GiB (8.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SV300S37A120G size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: BBF0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD10EZEX-00BN5A0 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 750 EVO 250GB size: 232.89 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q
scheme: MBR
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: Extreme 55AE size: 931.48 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 3001 scheme: MBR
ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 187.94 GiB (80.7%) fs: btrfs
dev: /dev/dm-0 maj-min: 254:0 mapped: luks-c60784ec-fd67-4a32-8b35-c79d27b73bac
ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 187.94 GiB (80.7%) fs: btrfs
ID-3: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 187.94 GiB (80.7%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: luks-c60784ec-fd67-4a32-8b35-c79d27b73bac
ID-4: /var/tmp raw-size: 232.88 GiB size: 232.88 GiB (100.00%) used: 187.94 GiB (80.7%)
ID-1: swap-1 type: zram size: 15.63 GiB used: 1.5 MiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 34 C
Processes: 417 Uptime: 11h 46m wakeups: 2 Memory: 15.64 GiB used: 5.36 GiB (34.3%) Init: systemd
v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1974 pacman: 1965 lib: 554
flatpak: 9 Client: shell wrapper v: 5.1.16-release inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2021-08-18
Last full system update: 2022-02-28
Failed units: dev-binderfs.mount systemd-networkd-wait-online.service
I havenât ran nVidia since it was spelled ânVidiaâ but have you tried different kernels?
My installation is actually over a year old. In my trials of fixing this issue last time, I ran a command that I found on this forum and while it didnât install a brand new system, it did change my initial install date.
Yes I have tried zen and lts kernel as well. Same result.
Still updating daily with no change in audio. Always rolling back to last working configuration.
Have you tried installing Wireplumber yet? (And reboot.)
Yes, with the same result.
So audio works...but if you take the update and reboot it is broken, right?
Can you post the package list from the update?
So audio worksâŠbut if you take the update and reboot it is broken, right?
Before the update audio works and the devices are listed in audio settings of the latte dock. After the update there is no audio, and no devices are listed in the audio settings of the latte dock.
There are so many to list as I have been rolling back after the whole no audio thing.
Packages (362) ansible-5.4.0-3 ark-21.12.3-1 baloo-widgets-21.12.3-1 bat-0.20.0-1 bluedevil-1:5.24.3-1
breeze-5.24.3-1 ca-certificates-mozilla-3.76-1 candy-icons-git-r795.6503d27-1
containerd-1.6.1-1 curl-7.82.0-1 dbus-1.14.0-1 dhclient-4.4.3-1 discount-2.2.7-2
docker-1:20.10.13-1 docker-compose-2.3.3-1 dolphin-21.12.3-1 dolphin-plugins-21.12.3-1
downgrade-11.1.0-1 dxvk-mingw-git-1.10.r27.g5f4fc562-1 expat-2.4.7-1 fakeroot-1.28-1
faudio-22.03-1 ffmpeg-2:5.0-5 ffmpegthumbs-21.12.3-1 firedragon-98.0-1 fmt-8.1.1-2
fscrypt-0.3.3-1 gamemode-1.6.1-2 garuda-common-settings-2.5.6-2 garuda-icons-r31.a81a057-1
garuda-wallpapers-r71.331d113-1 glslang-11.8.0-2 goverlay-git-0.8.1.r0.ge955035-1
gpgme-1.17.1-1 gst-libav-1.20.0-3 gst-plugin-pipewire-1:0.3.48-1 gst-plugins-bad-1.20.0-3
gst-plugins-bad-libs-1.20.0-3 gst-plugins-base-1.20.0-3 gst-plugins-base-libs-1.20.0-3
gst-plugins-good-1.20.0-3 gst-plugins-ugly-1.20.0-3 gst-rtsp-server-1.20.0-3
gstreamer-1.20.0-3 gstreamer-vaapi-1.20.0-3 gtk-update-icon-cache-1:4.6.1-3
gtk3-1:3.24.33-1 gwenview-21.12.3-1 harfbuzz-4.0.1-1 harfbuzz-icu-4.0.1-1 hwdata-0.357-1
imagemagick-7.1.0.27-1 intel-compute-runtime-22.09.22577-1 intel-gmmlib-22.0.3-1
intel-graphics-compiler-1:1.0.10409-1 intel-media-driver-22.2.2-1
kaccounts-integration-21.12.3-1 kaccounts-providers-21.12.3-1 kactivitymanagerd-5.24.3-1
kamera-21.12.3-1 kate-21.12.3-1 kcalc-21.12.3-1 kde-cli-tools-5.24.3-1
kde-gtk-config-5.24.3-1 kdeconnect-21.12.3-1 kdecoration-5.24.3-1
kdegraphics-thumbnailers-21.12.3-1 kdeplasma-addons-5.24.3-1 kdialog-21.12.3-1
kget-21.12.3-2 khotkeys-5.24.3-1 kinfocenter-5.24.3-1 kio-extras-21.12.3-1
kio-gdrive-21.12.3-1 kipi-plugins-21.12.3-1 kmahjongg-21.12.3-1 kmenuedit-5.24.3-1
konsole-21.12.3-1 kpmcore-21.12.3-1 krdc-21.12.3-1 krfb-21.12.3-1 kscreen-5.24.3-1
kscreenlocker-5.24.3-1 ksystemstats-5.24.3-1 ktorrent-21.12.3-1 kvantum-1.0.1-1
kvantum-theme-sweet-git-r247.6b137c9-1 kwallet-pam-5.24.3-1 kwayland-integration-5.24.3-1
kwayland-server-5.24.3-1 kwin-5.24.3-1 latte-dock-git-0.10.6.r182.g3f90a49b-1
layer-shell-qt-5.24.3-1 lib32-at-spi2-atk-2.38.0-2 lib32-brotli-1.0.9-4 lib32-curl-7.82.0-1
lib32-dbus-1.14.0-1 lib32-dbus-glib-0.112-2 lib32-expat-2.4.7-1 lib32-faudio-22.03-1
lib32-gamemode-1.6.1-2 lib32-glew1.10-1.10.0-5 lib32-harfbuzz-4.0.1-1
lib32-libappindicator-gtk2-12.10.0-13 lib32-libcurl-compat-7.82.0-1
lib32-libcurl-gnutls-7.82.0-1 lib32-libgcrypt15-1.5.6-7 lib32-libgudev-237-2
lib32-libidn11-1.33-2 lib32-libmodplug-0.8.9.0-4 lib32-libnm-1.36.2-1
lib32-libproxy-0.4.17-2 lib32-libpsl-0.21.1-2 lib32-librsvg-2:2.52.7-1
lib32-libtheora-1.1.1-13 lib32-libtiff4-3.9.7-5 lib32-libtirpc-1.3.2-2
lib32-libva-mesa-driver-21.3.7-2 lib32-libvdpau-1.4-2 lib32-libwrap-7.6.31-3
lib32-mesa-21.3.7-2 lib32-mesa-vdpau-21.3.7-2 lib32-nss-3.76-1 lib32-opencl-mesa-21.3.7-2
lib32-openssl-1.0-1.0.2.u-2 lib32-orc-0.4.32-2 lib32-pango-1:1.50.5-1
lib32-pipewire-1:0.3.48-1 lib32-pipewire-jack-1:0.3.48-1 lib32-rest-0.8.1-4
lib32-sdl2-2.0.20-2 lib32-sdl2_image-2.0.5-2 lib32-sqlite-3.38.0-1 lib32-systemd-250.4-1
lib32-vkd3d-1.3-1 lib32-vulkan-icd-loader-1.3.207-1 lib32-vulkan-intel-21.3.7-2
lib32-vulkan-mesa-layers-21.3.7-2 lib32-vulkan-radeon-21.3.7-2 libass-0.15.2-2
libbluray-1.3.0-2 libcurl-compat-7.82.0-1 libcurl-gnutls-7.82.0-1 libgcrypt15-1.5.6-6
libgphoto2-2.5.29-1 libgusb-0.3.10-2 libheif-1.12.0-3 libinih-53-2 libisl-0.24-4
libkdcraw-21.12.3-1 libkdegames-21.12.3-1 libkexiv2-21.12.3-1 libkgapi-21.12.3-1
libkipi-21.12.3-1 libkmahjongg-21.12.3-1 libksane-21.12.3-1 libkscreen-5.24.3-1
libksysguard-5.24.3-1 libktorrent-21.12.3-1 liblouis-3.21.0-1 libmfx-22.1.0-1
libnm-1.36.2-1 libosinfo-1.10.0-1 libplacebo-4.192.1-2 libreoffice-fresh-7.3.1-1
libretro-beetle-pce-1102-2 libretro-beetle-pce-fast-1159-2 libretro-beetle-psx-2599-2
libretro-beetle-psx-hw-2599-2 libretro-beetle-supergrafx-939-2 libretro-blastem-2052-2
libretro-bsnes-1:1226-2 libretro-bsnes-hd-50-2 libretro-bsnes2014-1:577-2
libretro-citra-6981-2 libretro-core-info-1.10.0-2 libretro-desmume-6338-2
libretro-dolphin-33006-2 libretro-duckstation-2105-2 libretro-flycast-4481-2
libretro-gambatte-958-2 libretro-genesis-plus-gx-1882-2 libretro-kronos-7016-2
libretro-mame-git-82349.1f6e6075e96-1 libretro-melonds-1989-2 libretro-mesen-2903-2
libretro-mesen-s-916-3 libretro-mgba-8143-2 libretro-mupen64plus-next-1:374-2
libretro-nestopia-1:73-2 libretro-overlays-210-2 libretro-parallel-n64-5223-2
libretro-picodrive-1263-2 libretro-play-6906-2 libretro-ppsspp-31606-2
libretro-retrodream-1104-2 libretro-sameboy-1720-2 libretro-scummvm-93204-2
libretro-shaders-slang-882-2 libretro-snes9x-2043-2 libretro-yabause-3334-2
librewolf-extension-bitwarden-1.56.6-1 librewolf-extension-localcdn-2.6.23-1
librewolf-ublock-origin-1.41.8-1 librsvg-2:2.52.7-1 libva-2.13.0-2
libva-intel-driver-2.4.1-2 libva-mesa-driver-21.3.7-2 libvdpau-1.4-2 libvirt-1:8.1.0-4
libvirt-python-1:8.1.0-1 libvorbis-1.3.7-3 libvpx-1.11.0-2 libwrap-7.6.31-3
libxmlb-0.3.7-1 libxnvctrl-510.54-2 linux-firmware-20220309.cd01f85-1
linux-firmware-whence-20220309.cd01f85-1 llvm-libs-13.0.1-2
luajit-2.1.0.beta3.r391.g8b8304f1-1 lutris-0.5.9.1-5 mercurial-6.1-2 mesa-21.3.7-2
mesa-vdpau-21.3.7-2 mhwd-db-garuda-git-1:r62.889aefa-4 milou-5.24.3-1 mpv-1:0.34.1-4
mtools-1:4.0.38-1 networkmanager-1.36.2-1 networkmanager-fortisslvpn-1.4.0-1
networkmanager-openconnect-1.2.8-1 networkmanager-openvpn-1.8.18-1
networkmanager-pptp-1.2.10-1 networkmanager-vpnc-1.2.8-1 nextcloud-client-2:3.4.3-1
nm-cloud-setup-1.36.2-1 nss-3.76-1 nvidia-settings-510.54-2 okular-21.12.3-1
opencl-mesa-21.3.7-2 openfortivpn-1.17.1-2 osinfo-db-20220214-1 pacman-6.0.1-4
pango-1:1.50.5-1 partitionmanager-21.12.3-1 perl-alien-build-2.47-1
pipewire-alsa-1:0.3.48-1 pipewire-common-git-0.3.48.r65.gcec88987-1
pipewire-common-v4l2-git-0.3.48.r65.gcec88987-1 pipewire-jack-1:0.3.48-1
pipewire-pulse-1:0.3.48-1 pipewire-zeroconf-1:0.3.48-1 plasma-browser-integration-5.24.3-1
plasma-desktop-5.24.3-1 plasma-disks-5.24.3-1 plasma-firewall-5.24.3-1
plasma-integration-5.24.3-1 plasma-nm-5.24.3-1 plasma-pa-5.24.3-1
plasma-systemmonitor-5.24.3-1 plasma-thunderbolt-5.24.3-1 plasma-vault-5.24.3-1
plasma-wayland-session-5.24.3-1 plasma-workspace-5.24.3-1
plasma5-theme-sweet-git-r23.ff4c02f-1 plymouth-git-22.02.122.r20.g76c1bb6-1 polkit-0.120-5
polkit-kde-agent-5.24.3-1 poppler-22.03.0-1 poppler-glib-22.03.0-1 poppler-qt5-22.03.0-1
powerdevil-5.24.3-1 ppsspp-assets-1.12.3-2 print-manager-21.12.3-1
proton-ge-custom-bin-1:GE_Proton7_9-1 protontricks-git-1.8.0.r2.gc3aab67-1
python-cairo-1.21.0-1 python-fonttools-4.30.0-1 python-more-itertools-8.12.0-1
python-numpy-1.22.3-1 python-pycurl-7.45.0-1 qgpgme-1.17.1-1 qpdf-10.6.3-1
qt5-base-5.15.3+kde+r133-1 qt5-charts-5.15.3+kde+r0-1 qt5-declarative-5.15.3+kde+r20-1
qt5-graphicaleffects-5.15.3+kde+r0-1 qt5-imageformats-5.15.3+kde+r0-1
qt5-location-5.15.3+kde+r0-1 qt5-multimedia-5.15.3+kde+r0-1
qt5-quickcontrols-5.15.3+kde+r0-1 qt5-quickcontrols2-5.15.3+kde+r4-1
qt5-sensors-5.15.3+kde+r0-1 qt5-speech-5.15.3+kde+r1-1 qt5-svg-5.15.3+kde+r12-1
qt5-tools-5.15.3+kde+r1-1 qt5-translations-5.15.3+kde+r2-1 qt5-wayland-5.15.3+kde+r40-1
qt5-webchannel-5.15.3+kde+r3-1 qt5-webengine-5.15.8-10 qt5-webkit-5.212.0alpha4-12
qt5-websockets-5.15.3+kde+r3-1 qt5-x11extras-5.15.3+kde+r0-1 qt5-xmlpatterns-5.15.3+kde+r0-1
rare-git-1.8.7.r55.gf5a9d86-1 rav1e-0.4.1-2 retroarch-1.10.0-4
retroarch-assets-glui-1:405-2 retroarch-assets-ozone-1:405-2 retroarch-assets-xmb-1:405-2
rtmpdump-1:2.4.r99.f1b83c1-2 sddm-kcm-5.24.3-1 seabios-1.16.0-1 shaderc-2022.1-2
signon-kwallet-extension-21.12.3-1 signond-8.61-1 skanlite-21.12.3-1 soundtouch-2.3.1-2
spectacle-21.12.3-1 spirv-tools-2022.1-1 starship-1.4.2-1 steam-native-runtime-1.0.0.70-3
steamtinkerlaunch-9.2-1 sudo-1.9.10-1 svt-av1-0.9.0-2 svt-hevc-1.5.1-2
sweet-cursor-theme-git-r247.6b137c9-1 sweet-kde-git-r247.6b137c9-1 systemd-250.4-1
systemd-libs-250.4-1 systemd-sysvcompat-250.4-1 systemsettings-5.24.3-1
telegram-desktop-3.6.0-1 tlp-1.5.0-5 ttf-iosevka-nerd-2.1.0-2
ungoogled-chromium-99.0.4844.51-1 unrar-1:6.1.6-1 upower-0.99.17-1 usb_modeswitch-2.6.1-3
vdpauinfo-1.4-2 ventoy-bin-1.0.71-1 virt-install-4.0.0-1 virt-manager-4.0.0-1 vkd3d-1.3-1
vulkan-headers-1:1.3.207-1 vulkan-icd-loader-1.3.207-1 vulkan-intel-21.3.7-2
vulkan-mesa-layers-21.3.7-2 vulkan-radeon-21.3.7-2 vulkan-swrast-21.3.7-2
vulkan-tools-1.3.207-1 wine-staging-7.4-1 wireless-regdb-2022.02.18-1 wireplumber-0.4.8-2
wlroots-0.15.1-3 x264-3:0.164.r3081.19856cc-2 x265-3.5-3 xdg-desktop-portal-kde-5.24.3-1
xxhash-0.8.1-2 yay-11.1.2-1 zimg-3.0.3-2 zstd-1.5.2-3
You mean this command?
curl https://iso.builds.garudalinux.org/iso/garuda/dr460nized/xxxxxx/garuda-dr460nized-linux-zen-xxxxxx.pkgs.txt | grep -Eo '^[^ ]+' | paru -Syu --needed -
(replace URL with current package list for the flavor of Garuda you have)
If so, have your tried it again recently? I ask this, because my issues were fixed with a new install on a separate drive. Considering this, I then thought this script should fix the issues on the original install, and it did work (after resolving package conflicts).
Also, it didnât change my initial âSystem Install Dateâ, so I wonder if it is the same command you tried?
No it was not that command. Honestly, I donât remember. I am going to try this command today though.
curl https://iso.builds.garudalinux.org/iso/garuda/dr460nized/220308/garuda-dr460nized-linux-zen-220308.pkgs.txt | grep -Eo '^[^ ]+' | paru -Syu --needed -
I had to work my way through some conflicts. After this update and a reboot I now have audio.
I assigned the solution to @Kayo, since we mark as solution the post providing the steps or suggestion to fix the problem, not the final implementation.
IIRC, my mistake, sorry for that.
This is more for future reference, as the issue is solved. Instead of using the last date of the iso build...
curl https://iso.builds.garudalinux.org/iso/latest/garuda/dr460nized/latest.pkgs.txt | grep -Eo '^[^ ]+' | paru -Syu --needed -
