This morning I went to do updates to my box (sudo pacman -Syu) just to get off a fresh start to the day. When I came across:
╭─joshua@Dr460nized in ~
╰─λ sudo pacman -Syu
[sudo] password for joshua:
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
resolving dependencies...
:: poppler-git and poppler are in conflict. Remove poppler? [y/N] y
:: removing poppler breaks dependency 'poppler=21.07.0' required by poppler-qt5
pacman -Qs poppler
local/poppler 21.07.0-3
PDF rendering library based on xpdf 3.0
local/poppler-data 0.4.10-1
Encoding data for the poppler PDF rendering library
local/poppler-glib 21.07.0-3
Poppler glib bindings
local/poppler-qt5 21.07.0-3
Poppler Qt5 bindings
Thanks for all the responses, I meant to add more to the thread after I accidently posted, then saw a post from a team member to read the FAQ, then saw the thread deleted, I read the FAQ couldn't find anything about this, then saw the thread was back haha. I'm so confused!
Anyways, I tried to install poppler-git with pacman and wasn't able to do so. I then tried to remove poppler but too much is dependant on it to remove so that didn't work either. So tried to update poppler itself and it wouldn't because it's conflicting with poppler-git which I don't understand because it's not installed.
One reason could be that since poppler-qt requires a certain version and, potentially, his repo doesn’t have that version it is asking to install poppler-git.
Did you try updating your mirrorlist as recommended above?
I don’t think so, because it isn’t installed. Also, it provides poppler so I don’t think the output would be terrible illuminating.
Another would be to remove poppler-qt5, let it install poppler-git and then fix it afterwards. After the fact it should be easier to find what is demanding poppler-git.
I researched what poppler-qt5 is and even tried to remove it as well, but once again it yells at me that there are too many dependants...
I'm working on my mirror list atm in between work issues to see if that could be a fix.
But, yeah I want to understand this situation so I know more about the system, how things work, and know how to take care of other similar issues I might run into in the future.
Missed what part? Something is trying to install poppler-git. However, that would require removing poppler which it can’t do because poppler-qt5 requires a certain version. So removing poppler-qt5 would be one suggestion.
Now I'm really confused... I opened up my mirrorlist but didn't change anything at all yet. Decided to do a pacman -Syu for I don't know... The 10th time, and it worked... No longer barking about any poppler-git/poppler conflictions...
Maybe there was a mirror that was having issues like was suggested?? I dunno... But I wish I understood it better before it decided to fix itself...
