Unresolvable package conflict between blas64-openblas and cblas
Trying to do a garuda-update, and running into the following error:
warning: reflector-simple: local (2.0-1.1) is newer than garuda (2.0-1)
resolving dependencies...
:: blas64-openblas and cblas64 are in conflict. Remove cblas64? [y/N]
n
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
I'm unable to remove cblas64, but if I try, I get the following:
:: blas64-openblas and cblas64 are in conflict. Remove cblas64? [y/N] y
y
:: blas64-openblas and lapack64 are in conflict. Remove lapack64? [y/N] y
y
:: installing openblas (0.3.23-3) breaks dependency 'blas' required by cblas
:: installing openblas (0.3.23-3) breaks dependency 'blas' required by lapack
I'm not sure how to proceed. I'm not sure what programs I'm using depend on cblas or openblas.
Here's the output of garuda-inxi:
Kernel: 6.3.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=6936ea14-a4b6-4fa3-b3eb-56beaef0e2aa rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 427637U v: ThinkPad W520
Mobo: LENOVO model: 427637U serial: <superuser required>
UEFI-[Legacy]: LENOVO v: 8BET41WW (1.21 ) date: 03/30/2011
ID-1: BAT0 charge: 58.6 Wh (100.0%) condition: 58.6/86.6 Wh (67.7%)
volts: 12.5 min: 11.1 model: SANYO 45N1001 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-2720QM bits: 64 type: MT MCP arch: Sandy Bridge
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2509 high: 3300 min/max: 800/3300 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1107 2: 1260 3: 3300
4: 1913 5: 3300 6: 3300 7: 3300 8: 2596 bogomips: 35086
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
vendor: Lenovo driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1 empty: VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
Device-2: NVIDIA GF108GLM [Quadro 1000M] vendor: Lenovo driver: nouveau
v: kernel non-free: series: 390.xx+ status: legacy-active (EOL~late 2022)
arch: Fermi code: GF1xx process: 40/28nm built: 2010-16 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 ports: active: none empty: DP-1, DP-2, DP-3,
LVDS-2, VGA-2 bus-ID: 01:00.0 chip-ID: 10de:0dfa class-ID: 0300
temp: 45.0 C
Device-3: Chicony Lenovo Integrated Camera (0.3MP) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.6:6
chip-ID: 04f2:b217 class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: i965,nouveau gpu: i915 display-ID: :0
Monitor-1: LVDS-1 mapped: LVDS1 model: Lenovo 0x40b2 built: 2009
res: 1920x1080 hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48")
API: OpenGL v: 3.3 Mesa 23.1.2 renderer: Mesa Intel HD Graphics 3000 (SNB
GT2) direct-render: Yes
vendor: Lenovo ThinkPad T520 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GF108 High Definition Audio vendor: Lenovo
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
API: ALSA v: k6.3.7-zen1-1-zen status: kernel-api with: aoss
Server-1: JACK v: 1.9.22 status: off tools: N/A
Server-2: PipeWire v: 0.3.71 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 6080 bus-ID: 00:19.0 chip-ID: 8086:1502
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
chip-ID: 8086:0085 class-ID: 0280
Local Storage: total: 3.17 TiB used: 231 GiB (7.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 480GB
tech: SSD serial: <filter> fw-rev: 04RL scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: One Touch HDD
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B type: USB
fw-rev: 1707 scheme: GPT
ID-1: / raw-size: 447.13 GiB size: 1.35 TiB (308.33%) used: 231 GiB (16.8%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 447.13 GiB size: 1.35 TiB (308.33%)
used: 231 GiB (16.8%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-3: /var/log raw-size: 447.13 GiB size: 1.35 TiB (308.33%)
ID-4: /var/tmp raw-size: 447.13 GiB size: 1.35 TiB (308.33%)
ID-1: swap-1 type: zram size: 31.24 GiB used: 8.2 MiB (0.0%) priority: 100
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nouveau temp: 46.0 C
Fan Speeds (RPM): cpu: 3058
Processes: 284 Uptime: 1h 14m wakeups: 1 Memory: available: 31.24 GiB
used: 4.25 GiB (13.6%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 2540 libs: 584 tools: pamac,paru,trizen,yay Shell: fish v: 3.6.1
default: Zsh v: 5.9 running-in: yakuake inxi: 3.3.27
System install date:     2021-05-04
Last full system update: 2023-06-13
Relevant software:       timeshift NetworkManager mkinitcpio
https://archlinux.org/news/openblas-0323-2-update-requires-manual-intervention/
That worked! Thank you so much!
