Unjustified CPU usage on Garuda KDE Dr460nized
╭─gg@gg in ~
╰─λ garuda-inxi
root=UUID=8f3d3c6d-6e01-46ac-9f3d-24646ce0f484 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Desktop Mobo: MSI model: H270-A PRO (MS-7A71) v: 1.0
UEFI: American Megatrends v: 5.00 date: 05/22/2017
Info: model: Intel Core i3-6100 bits: 64 type: MT MCP arch: Skylake-S
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 3700 min/max: 800/3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 3700 2: 3700 3: 3700 4: 3700 bogomips: 29598
Device-1: NVIDIA GP104 [GeForce GTX 1080] vendor: Micro-Star MSI
driver: nvidia v: 555.58 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-06; EOL~2026-12-xx) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-2021 ports: active: none off: HDMI-A-1
empty: DP-1, DP-2, DP-3, DVI-D-1 bus-ID: 0000:01:00.0 chip-ID: 10de:1b80
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
s-diag: 610mm (24")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled model: Asus VG248
serial: <filter> built: 2021 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
max: 1920x1080 min: 640x480
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1080/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1080 driver: nvidia v: 555.58 device-ID: 10de:1b80
surfaces: xcb,xlib
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 0000:00:1f.3
Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:10f0
API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000
bus-ID: 0000:02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Hardware-1: Intel SATA Controller [RAID mode] driver: intel_nvme_remap
v: N/A port: f020 bus-ID: 0000:00:17.0 chip-ID: 8086:2822 rev:
class-ID: 0104
Local Storage: total: 1.39 TiB used: 542.85 GiB (38.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX6000LNP
size: 476.94 GiB block-size: physical: 512 B logical: 512 B tech: SSD
serial: <filter> fw-rev: VC0S036H temp: 45.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA050
tech: HDD rpm: 7200 serial: <filter> fw-rev: A750 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: TeamGroup model: T253512GB
tech: SSD serial: <filter> fw-rev: 0A0 scheme: MBR
ID-1: / raw-size: 136.98 GiB size: 136.98 GiB (100.00%)
used: 49.35 GiB (36.0%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 25.8 MiB (26.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 136.98 GiB size: 136.98 GiB (100.00%)
ID-4: /var/log raw-size: 136.98 GiB size: 136.98 GiB (100.00%)
ID-5: /var/tmp raw-size: 136.98 GiB size: 136.98 GiB (100.00%)
ID-1: swap-1 type: zram size: 39.14 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.2 C mobo: N/A gpu: nvidia temp: 57 C
Memory: total: 40 GiB available: 39.14 GiB used: 6.29 GiB (16.1%)
Processes: 293 Power: uptime: 1h 4m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 15.61 GiB services: org_kde_powerdevil,
Packages: 2036 pm: pacman pkgs: 2023 libs: 548 tools: octopi,pamac,paru
pm: flatpak pkgs: 13 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date:     2024-06-25
Last full system update: 2024-07-02 ↻
this my system
OS: Garuda Linux x86_64
Host: MS-7A71 (1.0)
Kernel: Linux 6.9.7-zen1-1-zen
Packages: 2023 (pacman)[stable], 15 (flatpak)
Shell: fish 3.7.1
Resolution: 1920x1080
DE: KDE Plasma 6.1.1
WM: KWin (X11)
WM Theme: Breeze
Theme: Breeze (Dark) [QT], Sweet-Dark [GTK2/3/4]
Icons: Flat-Remix-Black-Light [QT], Flat-Remix-Black-Light [GTK2/3/4]
Terminal: konsole 24.5.1
Terminal Font: FiraCode Nerd Font Mono 12
CPU: Intel(R) Core™ i3-6100 (4) @ 3.70 GHz
GPU: NVIDIA GeForce GTX 1080 [Discrete]
Memory: 6473 MiB / 40075 MiB
it’s a bad setup the cpu is a bit old but still the thing is every time the system starts it is allways over 24% core 0 is allways over 81% so istarted diggin to find what task was taking that much all the time for my serprise it does not dhow up on top or htop or any other system monitor antil i used mpstat
the output from mpstat -P 0 is as it follows
Linux 6.9.7-zen1-1-zen (gg-arch) 02 جويلية, 2024 x86_64 (4 CPU)
CET 02:51:02 م CPU %usr %nice %sys %iowait %irq %soft %steal %guest %gnice %idle
CET 02:51:02 م 0 1.89 0.31 82.03 0.01 0.37 0.24 0.00 0.00 0.00 15.14
  • %steal - % CPU usage being forced to wait for a hypervisor handling other virtual processors.
    %steal is at 82.03% from my understanding it is reseved for some program
    / can some tell me how to undo this reservation thin and or at least explain why is it donne in the first place
and thankyou guys for taking the time to read this.
Hello. Please list the full garuda-inxi output (why the tag was placed as it was missing). Also please do not remove tags unless they are no longer relevant. Thank you.
Also, please do not keep on changing things mods put in place, or the thread might end up in 4xx Client Error pretty quickly.
from the garuda-inxi i can see that you have an intel 6100 and a realtek network adapter. the kernel has many vulnerabilities that it must mitigate when it comes to that processor which could be causing the unexplained load. also your realtek network “card” uses the cpu to process network traffic, AND its running at 100mb/s right now and not full gig so something may be wrong there.
AND a very important bit is that you need to reboot as you have installed updates.
Reboot.
Desktop: KDE Plasma v: 6.1.1 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: MSI model: H270-A PRO (MS-7A71) v: 1.0 serial: <filter>
uuid: 00000000-0000-0000-0000-309c23227fe5 UEFI: American Megatrends v: 5.00
date: 05/22/2017
Info: model: Intel Core i3-6100 socket: U3E1 bits: 64 type: MT MCP
arch: Skylake-S gen: core 6 level: v3 note: check built: 2015
process: Intel 14nm family: 6 model-id: 0x5E (94) stepping: 3
microcode: 0xF0
Speed (MHz): avg: 3699 high: 3700 min/max: 800/3700 base/boost: 3700/8300
scaling: driver: intel_pstate governor: powersave volts: 1.1 V
ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 3700 4: 3698 bogomips: 29598
Display: unspecified server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
s-diag: 610mm (24")
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu
surfaces: xcb,xlib
Server-2: PipeWire v: 1.2.0 status: n/a (root, process) with:
class-ID: 0104
Local Storage: total: 1.39 TiB used: 543.19 GiB (38.3%)
serial: <filter> fw-rev: VC0S036H temp: 47.9 C scheme: GPT
SMART: yes health: PASSED on: 354d 5h cycles: 984
read-units: 107,955,327 [55.2 TB] written-units: 32,531,361 [16.6 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA050 family: 3.5"
DT01ACA... Desktop HDD size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
serial: <filter> fw-rev: A750 temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 343d 8h cycles: 4482
size: 476.94 GiB block-size: physical: 512 B logical: 512 B sata: 3.2
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0A0 temp: 27 C
scheme: MBR
SMART: yes state: enabled health: PASSED on: 5d 23h cycles: 44
read: 7.6 MiB written: 7.4 MiB
used: 49.7 GiB (36.3%) fs: btrfs block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18
used: 25.8 MiB (26.9%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
maj-min: 8:18
maj-min: 8:18
maj-min: 8:18
System Temperatures: cpu: 44.2 C mobo: N/A gpu: nvidia temp: 56 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 36%
Memory: total: 40 GiB available: 39.14 GiB used: 6.55 GiB (16.7%)
Processes: 328 Power: uptime: 7m states: freeze,mem,disk suspend: deep
Packages: 2037 pm: pacman pkgs: 2023 libs: 548 tools: octopi,pamac,paru
pm: flatpak pkgs: 14 Compilers: clang: 17.0.6 gcc: 14.1.1
Shell: garuda-inxi (sudo) default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.35
Windows dual boot:       Yes
it’s done still the same result
Looks like you are still on the original version of the BIOS. I would update to the most recent version:
https://www.msi.com/Motherboard/H270-A-PRO/support
With the upgrade to Plasma 6 many older KDE widgets have become problematic. You may want to try selectively uninstalling any widgets you’ve installed.
it’s not the widjets or any other app some things is using the cpu but it does not show on the system
top, htop?
How do you know this if you have not selectively uninstalled your widgets?
Widgets often will not be identified as the culprit when checking usage statistics, they often evade detection as the source of the problem.
Perhaps you should not be so dismissive of those attempting to help you!
I have more important things to do today than wasting my time with a user that ignores suggestions put to them by volunteers attempting to help them.
Good luck, but you’re on your own now as far as I’m concerned.
Everything, and I really mean everything, can be shown. You just have to look in the right places. I like the view in btop++ for general use, and it’s conveniently in repo already: btop.
Increase your refresh rate, then sort by average CPU, see which things are jumping around. Once you identify what the process is, you can find out why. In order to reduce the number of processes moving around, as well as to help sort the root of the cause, you should absolutely follow the suggestion above and ensure you remove extra widgets.
There’s a lot more programs available for these uses too
https://wiki.archlinux.org/title/List_of_applications/Utilities#Task_managers
You really should update your BIOS before anything else. You are on the factory release, BEFORE the first release they made public!!
@Kayo good eyes
because widgets are a part of the system if any of them was using the processor it will show as task it will show on top, htop or sys monitor what ever is using this
is just reserving it for some app as it is explained on %steal type of work
i just updated BIOS now i lost grub-loader it boots directly to windows i am looking for a way to reinstall it
that actually solved the problem thanks man
To clarify, was it something about widgets / etc in the first part of @Technetium’s post or the later part about updating the BIOS that solved the issue? Future forum searchers might want to know :wink:
In short, answer yes it did.
Apparently not it was bios update problem I never updated bios the moment I updated bios the problem disappeared.
And one more thing, what made you think it was a widget problem, I Would love to hear you approach.
Just that whole post was marked as a solution, is all. The BIOS update suggestion was already made prior. I’ll mark that as the solution, thanks for the clarification.
