Hey there.
I've recently installed unity hub alongside the editor.
When trying to edit a script, I get this error from the official C# extension:
[fail]: OmniSharp.MSBuild.ProjectLoader
This project targets .NET version that requires reference assemblies that are not installed (e.g. .NET Framework). The most common solution is to make sure Mono is fully updated on your machine (https://mono-project.com/download/) and that you are running the .NET Framework build of OmniSharp (e.g. 'omnisharp.useModernNet': false in C# Extension for VS Code).
[warn]: OmniSharp.MSBuild.ProjectManager
Failed to load project file '/home/mooninorbit/My project/Mirror.CompilerSymbols.csproj'.
/usr/share/dotnet/sdk/6.0.106/Microsoft.Common.CurrentVersion.targets(1217,5): Error: This project targets .NET version that requires reference assemblies that are not installed (e.g. .NET Framework). The most common solution is to make sure Mono is fully updated on your machine (https://mono-project.com/download/) and that you are running the .NET Framework build of OmniSharp (e.g. 'omnisharp.useModernNet': false in C# Extension for VS Code).
When making a console app, everything works normally and the extension doesn't complain.
What can be the cause?
I have the latest dotnet version installed, is that maybe causing the issue?
