Ungoogled chromium CBCM is not enabled
I upgraded the other day but did not try ungoogled chromium until now. I am getting this error.
chromium %u
[36518:36518:0512/173558.292571:ERROR:chrome_browser_cloud_management_controller.cc(162)] Cloud management controller initialization aborted as CBCM is not enabled.
[36518:36528:0512/173558.974269:ERROR:ev_root_ca_metadata.cc(285)] Failed to register OID: 0
The browser will load but it will not connect to any websites whether local or on the internet. I was not logged into the browser when in use. All articles that I found indicate that I need to create a token from the admin page of google. I don’t have an enterprise account as those help articles have indicated. There is nothing listed in the comments on the aur for ungoogled-chromium about my error. please help.
Kernel: 6.3.1-1-tt arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-tt
root=UUID=fee12699-5d85-4ddb-bae0-daf333cf53d5 rw rootflags=subvol=@
loglevel=3 quiet splash ibt=off
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 43.1 Wh (98.0%) condition: 44.0/51.6 Wh (85.4%)
volts: 11.9 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 3 MiB desc: 12x256 KiB
L3: 144 MiB desc: 12x12 MiB
Speed (MHz): avg: 3437 high: 4303 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 4151 2: 4300 3: 2600
4: 2600 5: 2600 6: 4300 7: 4302 8: 4303 9: 2600 10: 2600 11: 2600 12: 4299
bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-3: Chicony HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:3 chip-ID: 04f2:b695
class-ID: 0e02
Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.3.1-1-tt status: kernel-api with: aoss type: oss-emulator
tools: N/A
vendor: Micro-Star MSI driver: r8168 v: 8.051.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
Local Storage: total: 1.38 TiB used: 865.69 GiB (61.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1032 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20140000 temp: 40.9 C scheme: GPT
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
used: 104.99 GiB (71.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-4: /var/log raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 343.1 MiB (2.2%)
System Temperatures: cpu: 71.0 C pch: 45.0 C mobo: N/A
Processes: 380 Uptime: 9h 11m wakeups: 39482 Memory: available: 15.47 GiB
used: 5.22 GiB (33.7%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1789 libs: 507 tools: octopi,paru Shell: fish v: 3.6.1
running-in: konsole inxi: 3.3.27
System install date:     2022-07-14
Last full system update: 2023-05-12
Please, edit your post.
Try to find the Chromium directory in ~/.config and move it to a backup like this person: Brave crashes on start - Desktop Support - Brave Community
If you need the configs, copy them back piecemeal with the bisection method so you can identify what file or files are causing the issue.
Seems to be unrelated, I’m also getting this and pages load just fine - this is right after installation.
Not loading means which error exactly?
I archived the original config folder and deleted the contents. Right away all pages started reloading..... not sure what caused the errors. but seems to be working well now.
