After you do that, run sudo pacman -Syy lib32-libcap
Then you should be able to run:
sudo pacman -Syu
sudo pacman -Syu
error: failed to synchronize all databases (no servers configured for repository)
Can I see your revised pacman.conf?
$ pacman -Syyu , after doing the following:
After running reflector-simple to select the best package mirrors.
First, install it: $ pacman -S reflector-simple
Then, run it from a terminal: reflector-simple
Save it, then run: $ pacman -Syyu and then please report back.
regards
EDITED: Thanks to @dalto for lessening the confusion.
That won’t work until he fixes his broken pacman.conf and fixes the issue with lib32-libcap
Right. I kinda put that first because of the 'u.' I'll revise it. Thanks for mentioning it. I get stuff bass-ackwards sometimes.
For reference, he doesn't need to resort his mirrors again. That error is caused by this:
[multilib-testing]
#Include = /etc/pacman.d/mirrorlist
The repo is enabled but the mirrors are commented out.
LOL, isn't it usually just the small things? Good catch.
regards
