Hey there,
I have a weird problem right now: Whenever I try to configure my system to use anything surround-related my audio just dies until I switch back. I tried rebooting with surround, but that didn't work. The only way to get an analog audio output currently is to use "Analog Stereo Output" or duplex.
The problem now is, that I can only enable my system to use the audio input and output at the same time when using surround sound (Digital Stereo also doesn't work at all...)
What am I doing wrong?
Thanks!
System Info:
System: Kernel: 5.14.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2a555427-5d35-463f-8011-b023a855b928 rw rootflags=subvol=@ loglevel=3 quiet
splash lsm=lockdown,yama,apparmor,bpf
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 2 dm: Ly
Machine: Type: Desktop System: Gigabyte product: AX370-Gaming 3 v: N/A serial: <filter>
Mobo: Gigabyte model: AX370-Gaming 3-CF v: x.x serial: <filter>
UEFI-[Legacy]: American Megatrends v: F50a date: 11/27/2019
CPU: Info: 6-Core model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ family: 17 (23)
model-id: 8 stepping: 2 microcode: 800820D cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 86224
Speed: 4101 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz): 1: 4101
2: 4102 3: 4111 4: 4117 5: 4130 6: 4099 7: 4111 8: 4100 9: 4094 10: 4110 11: 4123
12: 4088
Graphics: Device-1: AMD Baffin [Radeon RX 550 640SP / RX 560/560X] vendor: ASUSTeK driver: amdgpu
v: kernel bus-ID: 08:00.0 chip-ID: 1002:67ff class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-3:4
chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 3600x1200 s-dpi: 96 s-size: 952x317mm (37.5x12.5")
s-diag: 1003mm (39.5")
Monitor-1: HDMI-A-0 res: 1680x1050 hz: 60 dpi: 90 size: 474x296mm (18.7x11.7")
diag: 559mm (22")
Monitor-2: DVI-D-0 res: 1920x1200 hz: 60 dpi: 99 size: 495x310mm (19.5x12.2")
diag: 584mm (23")
OpenGL:
renderer: Radeon RX 560 Series (POLARIS11 DRM 3.42.0 5.14.12-zen1-1-zen LLVM 12.0.1)
v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X] vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel v: kernel
bus-ID: 0a:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: C-Media USB Microphone type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-2:3 chip-ID: 0d8c:9700 class-ID: 0300 serial: <filter>
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo bus-ID: 3-3:4
Sound Server-1: ALSA v: k5.14.12-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.38 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
driver: r8169 v: kernel port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Drives: Local Storage: total: 2.96 TiB used: 1.49 TiB (50.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB size: 232.89 GiB
rev: 1B6Q scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD20EFRX-68EUZN0
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: 0A82 scheme: GPT
Partition: ID-1: / raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 70.02 GiB (35.8%)
ID-2: /home raw-size: 736.18 GiB size: 736.18 GiB (100.00%) used: 121.03 GiB (16.4%)
fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-3: /var/log raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 70.02 GiB (35.8%)
ID-4: /var/tmp raw-size: 195.31 GiB size: 195.31 GiB (100.00%) used: 70.02 GiB (35.8%)
ID-1: swap-1 type: zram size: 31.3 GiB used: 2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 47.1 C mobo: N/A gpu: amdgpu temp: 36.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1420
Info: Processes: 381 Uptime: 17m wakeups: 0 Memory: 31.3 GiB used: 5.8 GiB (18.5%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1
Packages: 2084 apt: 0 pacman: 2077 lib: 471 snap: 7
Client: Unknown Client: garuda-assistant inxi: 3.3.06
