I had successfully installed Garuda KDE on my laptop. But when I tried to restore a snapshot, it didn't booted again .
It said "Reboot immediately", and when rebooted it gave an error.
( I was able to see grub, but when I entered on the Garuda Linux entry, it gave an error(sorry, but I don't remember that)).
Since I dual booted it with windows earlier , I deleted the partition which I made during installation (root, grub, and swap)
I again made the pendrive bootable and tried to install it again,
But this time, after choosing "boot with open source drivers"
It shows the following :
(As I am a new user, I can't post the photo)
ERROR: /dev/disk/by-label/GARUDA_DR460NIZED_TALON' device did not show up after 30 seconds. Falling back to interactive prompt
You can try to fix the problem manually, log out when you are finished sh: can't access tty; job control turned off
[rootfs ]#
I tried using different pendrives too(samsung, SanDisk),
Made them bootable with different softwares too (Balena Etcher, Rufus, Ventoy).
I am on a HP laptop "HP-Probook 640 G2"
Processor - "Intel Core i7"
On the latest bios.
My previous distribution's neofetch:-
OS: Arch Linux x86_64
Host: HP ProBook 640 G2
Kernel: 6.0.2-arch1-1
Uptime: 6 mins
Packages: 1066 (pacman)
Shell: zsh 5.9
Resolution: 1366x768
DE: GNOME 42.5
WM: Mutter
W Theme: Adwaita Theme: Kali-Dark [GTK2/3]
Icons: Adwaita [GTK2/3]
Terminal: gnome-terminal
CPU: Intel 17-6500U (4) @ 3.400GHz
GPU: Intel Skylake GT2 [HD Graphics 520]
Memory: 1437M1B / 3175MiB
I have disabled Fastboot in BIOS,
also disabled fast start-up here "Control Panel\Hardware and Sound\Power Options\System Settings" in Windows.
I know 4 gb ram is less, but it was working fine and also I doesn't need any extra apps, only a browser, bitwarden, and VLC.
